* | removed assert() for stat on non-devices. Now it returns -1. This | Joel Sherrill | 1997-01-08 | 1 | -2/+1 | |
| | | | | makes gnat pass about 55 more tests in the acvc. | |||||
* | added some casts to reduce warnings reported by users with Microtec C++ | Joel Sherrill | 1997-01-08 | 4 | -28/+35 | |
| | | | | compiler. | |||||
* | added type definitions for all supported task entry formats | Joel Sherrill | 1997-01-08 | 2 | -2/+12 | |
* | Suggested changes from Mark Jordan which eliminate warnings and errors | Joel Sherrill | 1996-12-02 | 8 | -16/+22 | |
| | | | | | | | | he received using the Microtec C++ compiler. Most of these are either missing casts from/to (void *), heavy handed use of enumerated types, or simply assumed conversions. There is at least one actual bug in an error path in thread.c in which the wrong argument was passed to _Thread_Stack_Free and was not being caught by gcc. | |||||
* | Changes to reflect new revision of erc32 per Jiri Gaisler's suggestions. | Joel Sherrill | 1996-12-02 | 5 | -38/+52 | |
| | | | | This is current as of sis 2.6. | |||||
* | minor changes to eliminate warnings from C++ compilers per user suggesstions. | Joel Sherrill | 1996-12-02 | 1 | -4/+4 | |
* | Replacement for the sis bsp which supports the simulator and real | Joel Sherrill | 1996-12-02 | 4 | -0/+1184 | |
| | | | | | hardware. From Jiri Gaisler <jgais@wd.estec.esa.nl>. Supports sis 2.6 and later. | |||||
* | New bsp for the erc32/sis from Jiri Gaisler <jgais@wd.estec.esa.nl> which | Joel Sherrill | 1996-12-02 | 2 | -0/+273 | |
| | | | | | | runs on either the real hardware or the sparc instruction simulator. This bsp requires sis version 2.6 or later. This bsp supercedes the sis bsp. | |||||
* | Updates from Derrick Ostertag <ostertag@transition.com> to fix bug in | Joel Sherrill | 1996-12-02 | 4 | -15/+48 | |
| | | | | interrupt handling. | |||||
* | Update from Chris Johns <cjohns@awa.com.au> to add better support for | Joel Sherrill | 1996-12-02 | 3 | -22/+56 | |
| | | | | 68000 class CPUs. | |||||
* | Added asserts for unhandled conditions which need to result in error | Joel Sherrill | 1996-11-08 | 3 | -2/+25 | |
| | | | | | | statuses being returned to gnat runtime in order for it to raise use_errors. This was needed to identify the places in gnat's runtime which needed to be addressed. | |||||
* | added ENOSYS support | Joel Sherrill | 1996-10-15 | 2 | -0/+2 | |
* | updated to format of 3.6.0 | Joel Sherrill | 1996-10-15 | 2 | -42/+102 | |
* | updated to format of 3.6.0 console drivers | Joel Sherrill | 1996-10-15 | 1 | -51/+111 | |
* | updated to format of 3.6.0 clock drivers | Joel Sherrill | 1996-10-15 | 1 | -24/+83 | |
* | added support for cpu time used field in tcb | Joel Sherrill | 1996-10-15 | 1 | -0/+16 | |
* | added cpu time used field to tcb | Joel Sherrill | 1996-10-15 | 2 | -0/+2 | |
* | added i386ex from Erik Ivanenko | Joel Sherrill | 1996-10-15 | 1 | -0/+3 | |
* | new file | Joel Sherrill | 1996-10-15 | 1 | -0/+8 | |
* | reference to Force CPU-386 removed. | Joel Sherrill | 1996-10-15 | 1 | -3/+20 | |
| | | | | added standard comments about driver entries. | |||||
* | initial version from Erik | Joel Sherrill | 1996-10-15 | 10 | -0/+1038 | |
* | patches to erc32.h to correct handling of timer mirror from Jiri Gaisler. | Joel Sherrill | 1996-10-14 | 2 | -6/+6 | |
* | i386_nofp cpu model entry incorrectly had floating point enabled. | Joel Sherrill | 1996-10-01 | 1 | -1/+1 | |
* | changed INLINE to inline since INLINE is no longer defined by RTEMS | Joel Sherrill | 1996-09-30 | 2 | -2/+2 | |
* | fixed incorrect placement of CPU_STRUCTURE_ALIGNMENT macro. | Joel Sherrill | 1996-09-30 | 1 | -2/+2 | |
* | changed version string to 3.6.0 | Joel Sherrill | 1996-09-30 | 2 | -2/+2 | |
* | changed stack size of posix initialization threads to double the minimum | Joel Sherrill | 1996-09-30 | 1 | -0/+3 | |
| | | | | stack size so more of acvc would pass. | |||||
* | updated for Release 3.6.0 to reflect status of posix threads. | Joel Sherrill | 1996-09-30 | 1 | -3/+14 | |
* | data and control addresses were swapped for channel a of the scc | Joel Sherrill | 1996-09-27 | 1 | -2/+2 | |
* | added missing word in ACKNOWLEDGEMENTS | Joel Sherrill | 1996-09-20 | 1 | -1/+2 | |
* | new files | Joel Sherrill | 1996-09-18 | 3 | -0/+205 | |
* | new files submitted by Craig Lebakken (lebakken@minn.net) and Derrick Ostertag | Joel Sherrill | 1996-09-18 | 19 | -0/+1951 | |
| | | | | (ostertag@transition.com) | |||||
* | added cast | Joel Sherrill | 1996-09-18 | 1 | -1/+1 | |
* | address arithmetic changed to be more portable | Joel Sherrill | 1996-09-18 | 1 | -3/+7 | |
* | new test submitted by Craig Lebakken (lebakken@minn.net) and Derrick Ostertag | Joel Sherrill | 1996-09-18 | 3 | -0/+230 | |
* | new files submitted by Craig Lebakken (lebakken@minn.net) and Derrick Ostertag | Joel Sherrill | 1996-09-18 | 8 | -0/+3027 | |
* | pointer arithmetic reworked to be more portable | Joel Sherrill | 1996-09-18 | 2 | -16/+16 | |
* | casts added to numerous arguments, prototypes corrected, and | Joel Sherrill | 1996-09-18 | 20 | -44/+54 | |
| | | | | proper include files added. | |||||
* | dummy function added to satisfy ANSI | Joel Sherrill | 1996-09-18 | 4 | -0/+40 | |
* | modified to support non-GNU compilers and to use calloc rather than | Joel Sherrill | 1996-09-18 | 2 | -6/+40 | |
| | | | | malloc for per-thread reentrancy structure allocation. | |||||
* | added malloc_walk | Joel Sherrill | 1996-09-18 | 2 | -8/+70 | |
| | | | | miscellaneous corrections in casting. | |||||
* | added prototype for malloc_walk | Joel Sherrill | 1996-09-18 | 3 | -0/+3 | |
* | loop to clear workspace memory changed to use sizeof rather than | Joel Sherrill | 1996-09-18 | 1 | -1/+1 | |
| | | | | hardcoded 4 to be compatible with CPUs with 64-bit ints | |||||
* | corrected prototype of _Objects_Get_next | Joel Sherrill | 1996-09-18 | 1 | -1/+1 | |
* | uses address object rather than direct pointer arithmetic | Joel Sherrill | 1996-09-18 | 1 | -2/+3 | |
* | OBJECTS_NAME_ALIGNMENT definition changed to use sizeof rather than | Joel Sherrill | 1996-09-18 | 2 | -4/+4 | |
* | MP_PACKET_MINIMUN_HETERO_CONVERSION definition changed to use sizeof | Joel Sherrill | 1996-09-18 | 2 | -2/+4 | |
| | | | | rather than hardcoded 4 to be compatible with CPUs with 64-bit ints | |||||
* | modified declaration of CORE_message_queue_Buffer_control to avoid use | Joel Sherrill | 1996-09-18 | 2 | -22/+8 | |
| | | | | of GNU C extension | |||||
* | use address object to avoid direct pointer arithmetic | Joel Sherrill | 1996-09-18 | 6 | -6/+6 | |
* | corrected white space problems | Joel Sherrill | 1996-09-18 | 1 | -60/+62 | |
| | | | | added CPU_STRUCTURE_ALIGNMENT to default context structures |
