* shared/irq/irq.c, shared/irq/irq.h, shared/irq/irq_asm.S: Add shared
interrupt support to i386.
* irq/irq.c, network/if_1GHz/POSSIBLEBUG: Removed.
PR1395/bsps
* Updated the changes from RTEMS-4.8.0, which were made since Oct. 2007.
* network/if_1GHz/if_wm.c: fixed some bugs in the 1GHz driver.
* pci/pci_interface.c:
+ Enabled PCI "Read", "Read Line", and "Read Multiple"
+ Agressive Prefetch to improve the performance of the PCI based
applications (e.g. 1GHz NIC).
* irq/BSP_irq.c : Replaced the irq/irq.c, and used GT_GPP_Value
register to monitor the cause of the level sensitive interrupts.
This unique solution solves various bugs in the 1GHz network drivers
Fixed bugs in compute_pic_masks_from_prio()
* pci/pci.c : Updated it to be consistent with the original pci.c
* written by Eric Valette. There is no change in its function.
* irq/irq_init.c : set defaultIrq->next_handler to be 0
* for BSP_SHARED_HANDLER_SUPPORT.
PR1395/bsps
PR 1409/bsps
* gdbstub/rtems-stub-glue.c: Print object names correctly.
* new-exceptions/bspsupport/irq_supp.h: Split routine to allow bsps
with nonstandard/non-existant pics to call with interrupts off.
* Makefile.am, README, configure.ac, preinstall.am, PCI_bus/PCI.c,
PCI_bus/PCI.h, PCI_bus/flash.c, PCI_bus/universe.c, console/85c30.c,
console/85c30.h, console/console.c, console/consolebsp.h,
console/tbl85c30.c, include/bsp.h, include/coverhd.h, include/gen2.h,
include/irq-config.h, include/tm27.h, irq/FPGA.c, irq/irq.h,
irq/irq_init.c, start/start.S, startup/Hwr_init.c,
startup/bspstart.c, timer/timer.c, tod/tod.c: Updated and tested with
the latest powerpc isr source
* irq/no_pic.c: New file.
* irq/irq.c, startup/genpvec.c, startup/setvec.c, startup/vmeintr.c: Removed.
correct some init values for HSC_CM01 boards
PR 1392/bsps
* libchip/i2c/spi-memdrv.c: SPI Memory driver. Fix but where writes
over multiple pages results in extra data being written.
PR 1385/cpukit
* mpc5xx/irq/irq_asm.S: When the type rtems_boolean was switched to the
C99 bool, the size changed from 4 bytes to 1 byte. The interrupt
dispatching code accesses two boolean variables for scheduling
purposes and the assembly implementations of this code did not get
updated.
PR 1385/cpukit
* shared/irq/irq_asm.S: When the type rtems_boolean was switched to the
updated.
PR 1385/cpukit
* irq/irq_asm.S: When the type rtems_boolean was switched to the C99
updated.
PR 1385/cpukit
* startup/exception.S: When the type rtems_boolean was switched to the
updated.
* include/bsp.h: Added missing include.
PR 1391/bsps
* startup/spurious.c: Format was %d but had leading 0x.
* include/tm27.h: Add include rtems/powerpc/powerpc.h
This version matches the trunk.
* startup/bspstart.c: removed legacy code (inherited
from old mvme2307 BSP) -- for testing trapping into
PPCBug -- which is irrelevant on this BSP.
Removed warning about SPRG0 having been reassigned
-- this BSP is OK.
* bootcard.c: use aligned heap_start (instead of
original heap_start) when calculating default heap
size (to take into account loss due to alignment).
robust against erroneous external exception disable times.
PR 1375/bsps
* clock/clock.c: Correct implementation of nanoseconds since last tick
handler.
PR 1390/bsps
* startup/linkcmds: Fix sections so C++ global constructors and
destructors work with late model (>= 4.3) gcc versions.
PR 1380/bsps
* include/bsp.h: Switch to English comments.
* Makefile.am: Remove unnecessary copy of cpu_asm.S
* console/Modif_cpu_asm.S: Removed.
PR 1386/bsps
* shared/start.S: Stack space not correctly initialized. Causes
failures on unoptimized applications.
PR 1371/bsps
* network/network.c: mvme167 network driver buggy.
PR 1370/bsps
* console/console.c: mvme167 console driver BSP_output_char fails to
convert \n -> \n\r
PR 1352/bsps
* shared/console/reboot.c, shared/motorola/motorola.c: Include support
for mvme2600/mvme2700.
PR 1369/bsps
* Makefile.am, configure.ac: Fix name clashes when using MC68040 fpsp
floating-point emulation.
* bsp_specs: Remove stray % from '*startfile:' having crept in
previous patch.
PR 1354/bsps
* network/network.c: In some cases it can occur that an empty mbuf is
put on the descriptor chain. (We found it especially then when
transmitting fragmented IP Packets.) Since the actual buffer
descriptor pointer will be incremented after every inserted mbuf
(txBd = sc->txBdBase + sc->txBdHead;) even if m->m_len of the current
mbuf was zero. This leads to the bug.
* libchip/i2c/spi-sd-card.c: Fixed RTEMS_BLKDEV_CAPABILITIES ioctl
which caused invalid multiple block writes.
PR 1358/bsps
* clock/clock.c: Fix time-access bug in uc5282 BSP.
PR 1350/bsps
* network/lan91c11x.c: Do not write 65th element into 64 element array.
PR 1349/bsps
* startup/bspstart.c: Add missing volatile on UART access pointer.
* bsp_specs: Backport from CVS-HEAD.
* psim-shared, runtest-bottom: Tidy up more bugs.
* psim-bottom, psim-gdb-bottom, psim-gdb-top.in, psim-shared,
psim-top.in: Clean up and works better. Uses argv[0] to override
configured target name.
PR 1344/bsps
* clock/ckinit.c: Committed code was not final. Corrections.
* psim-bottom, psim-gdb-bottom, psim-shared, psim-top.in: Add ability
to force psim configuration to include System V IPC devices even when
the test does not appear to be multiprocessing. This is used by some
RTEMS application developers for system simulation and could be used
to simulate a framebuffer if a UNIX process mirrored the buffer.
Michael South <msouth@msouth.org>
PR 1344/bsps
* cpuModel.h: Add use of TSC for nanoseconds granularity. i8254 is very
slow on some systems. TSC use is auto-detected by default.
PR 1344/bsps
* configure.ac, clock/ckinit.c, timer/timer.c: Add use of TSC for
nanoseconds granularity. i8254 is very slow on some systems. TSC use
PR 1345/Ada
* rtems.ads: RTEMS boolean type is now C99 bool which is not an
unsigned32.
PR 1339/Ada
* rtems.adb, rtems.ads: Re-add IO Manager to Ada binding.
change strategy to determine MAC address
function within a critical section for printk() compatibility.
PR 1332: call BSP_uart_termios_set()/BSP_uart_intr_ctrl()
only from 'firstOpen' and only if this is a serial console.
