* irq/irq_init.c, motorola/motorola.c: Support for MTX603e.
* README.mtx603e: New file.
* bsp_specs: Added crtbegin,crtend objects so C++ global objects
constructors/destructors run correctly.
* startup/linkcmds: Increased code length and updated the ctor/dtor
sections to handle crtbegin, crtend objects.
* network/network.c: Fix inconsistency in prototyping.
* compilers/gcc-target-default.cfg: Make build variants work
for user applications.
* monitor/mon-commands.c: Removed warnings for RTEMS_UNIX.
* psx01/psx01.scn, psx02/psx02.scn, psx03/psx03.scn, psx04/psx04.scn,
psx05/psx05.scn, psx06/psx06.scn, psx07/psx07.scn, psx08/psx08.scn,
psx09/psx09.scn, psx10/psx10.scn, psx11/psx11.scn, psx12/psx12.scn:
Per PR239 update the IDs in the various screens.
* sp02/sp02.scn, sp15/sp15.scn, sp16/sp16.scn, sp20/sp20.scn,
sp22/sp22.scn, sp23/sp23.scn, sp25/sp25.scn, sp31/sp31.scn: Per PR239
update the IDs in the screens.
* configure.ac: Use test "$RTEMS_BSP_FAMILY" != "bare" to setup
HAS_LIBBSP conditional (Solaris/bash incompatibility fix).
* capture/Makefile.am: Remove AUTOMAKE_OPTIONS.
* serdbg/Makefile.am: Remove AUTOMAKE_OPTIONS.
* serdbg/serdbgio.c: Add #include <unistd.h>.
* shell/Makefile.am: Add RTEMS_LIBSHELL conditional.
* wrapup/Makefile.am: Add RTEMS_LIBSHELL conditional.
* configure.ac: Check for stdio assignments.
* network/network.c: Removed warning per Jay's suggestion.
* include/.cvsignore: Corrected.
* network/.cvsignore: New file.
* acinclude.m4: Added edb7312.
* New BSP.
* .cvsignore, ChangeLog, Makefile.am, bsp_specs, configure.ac, README,
times, clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c,
console/.cvsignore, console/Makefile.am, console/uart.c,
include/ep7312.h, irq/.cvsignore, irq/Makefile.am, irq/bsp_irq_asm.S,
irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, network/Makefile.am,
network/network.c, start/.cvsignore, start/Makefile.am,
start/start.S, startup/.cvsignore, startup/Makefile.am,
startup/bspstart.c, startup/exit.c, startup/linkcmds,
timer/.cvsignore, timer/Makefile.am, timer/timer.c,
wrapup/.cvsignore, wrapup/Makefile.am: New file.
* irq/irq_asm.S, irq/irq_init.c: Fixes a bug with handling the
situation where we are processing an IRQ, and we receive an FIQ.
* network/cs8900.c: I don't know why we have to SelfST register
twice on the EDB7312, but it doesn't work on the EDB7312 if we don't.
* Makefile.inc.in: Remove RTEMS_USE_GCC272, RTEMS_LIBC_DIR.
* compilers/gcc-target-default.cfg: Remove obsolete reference to
src/libxil/Makefile.
Comment out LD_PATHS from LDFLAGS (Now implicitly handled by gcc
-spec).
* compilers/gcc-target-default.cfg: Add -qrtems-debug handling.
* rtems/Makefile.am: Reworked.
* sapi/Makefile.am: Reworked.
* rel.am: New.
* configure.ac: Only symlink leaf.cfg.
* startup/linkcmds: Include all .rodata* sections.
* Makefile.am: Merge in include/Makefile.am.
* TOOL_TARGETS: Updated.
* PROBLEMS, README, REQUIRES, TESTED, UPDATE_HELP: Removed
since they were obsolete.
* configure.ac: Remove references to Templates.
Use local AC_CONFIG_LINKS.
* README: Relocated from make/
* directory.cfg: Ditto.
* lib.cfg: Ditto.
* compilers/gcc-target-default.cfg: Ditto.
* startup/bspstart.c: Add empty H8BD_Install_IRQ so the port will have
a routine to call.
* Makefile.am: Use "'"-quotes to pass args to bsp.mak.
* configure.ac: Use "'"-quotes for args to RTEMS_CONFIG_SUBDIRS.
Fix braino in comment on "exec".
Extend --enable-ada handling.
* startup/bspstart.c: Remove ramStart to eliminate warning.
* configure.ac: Unconditionally check for CXX (Hack to bug in
autoconf > 2.54).
* src/_servtgt.c: Removed warning by adding support for ITRON
tasks and rolling multiple loops into 1.
* src/m68k/rdbg_f.c: Removed warning.
* console/console.c, network/network.c: Removed warnings.
* irq/irq.c: Removed warnings.
* network/network.c: Removed warnings.
* pppd/auth.c, rtems_webserver/uemf.h: Removed warnings.
* mpc8260/console-generic/console-generic.c, mpc8260/cpm/dpram.c,
mpc8260/exceptions/raw_exception.c,
mpc8xx/exceptions/raw_exception.c: Removed warnings.
* console/i8042.c: Removed warnings.
* console/console.c, irq/irq.c, network/if_hdlcsubr.c,
network/if_hdlcsubr.h, network/network.c, vectors/vectors_init.c:
Removed warnings.
* clock/clock.c: Removed warnings.
* console/console.c: Removed warnings.
* console/sci.c, spurious/spinit.c: Removed warnings.
* console/console.c, i2c/i2cdrv.c, nvram/nvram.c, startup/bspstart.c,
tod/ds1307.c: Removed warnings.
* console/console.c, console/m340uart.c: Removed warnings.
* console/console.c, network/ne2000.c: Removed warnings.
* mongoosev/Makefile.am: TMPINSTALL_FILES -> PREINSTALL_FILES.
* mongoosev/Makefile.am: Merge-in mongoosev/include/Makefile.am.
Install include/mongoose-v.h.
* mongoosev/include/Makefile.am: Remove.
* console/console.c, start/start.c: Removed warnings.
* Makefile.am: Use mkinstalldirs instead of mkdir.
