* configure.ac: Remove check for libbsp/${RTEMS_CPU}.
Add dependency tracking for *.cfgs.
* Makefile.am: Add dependency tracking for *.cfg.
* libchip/rtc/mc146818a.c: Don't include <bsp.h>
(Thanks to Lars Munch <lars@segv.dk> for catching this).
* rtems/score/cpu.h: Add doxygen preamble.
* rtems/score/powerpc.h: Add doxygen preamble.
* rtems/score/ppc.h: Add doxygen preamble.
* rtems/score/types.h: Add doxygen preamble.
PR 697/bsps
* flashentry/flashentry.S: Fix broken comments
(Patch by Thomas.Doerfler@imd-systems.de)
* startup/linkcmds: Add .gnu.linkonce.b.*.
PR 707/make_build
* configure.ac: Add --enable-rpcgen.
* start/start.S: Reflect new header locations.
PR 700/rtems_misc
* libnetworking/rtems_webserver/asp.c,
libnetworking/rtems_webserver/balloc.c,
libnetworking/rtems_webserver/cgi.c,
libnetworking/rtems_webserver/default.c,
libnetworking/rtems_webserver/ej.h,
libnetworking/rtems_webserver/ejIntrn.h,
libnetworking/rtems_webserver/ejlex.c,
libnetworking/rtems_webserver/ejparse.c,
libnetworking/rtems_webserver/emfdb.c,
libnetworking/rtems_webserver/emfdb.h,
libnetworking/rtems_webserver/form.c,
libnetworking/rtems_webserver/handler.c,
libnetworking/rtems_webserver/h.c,
libnetworking/rtems_webserver/license.txt,
libnetworking/rtems_webserver/Makefile.am,
libnetworking/rtems_webserver/md5c.c,
libnetworking/rtems_webserver/md5.h,
libnetworking/rtems_webserver/mime.c,
libnetworking/rtems_webserver/misc.c,
libnetworking/rtems_webserver/NOTES,
libnetworking/rtems_webserver/ringq.c,
libnetworking/rtems_webserver/rom.c,
libnetworking/rtems_webserver/rtems_webserver.h,
libnetworking/rtems_webserver/security.c,
libnetworking/rtems_webserver/sock.c,
libnetworking/rtems_webserver/socket.c,
libnetworking/rtems_webserver/sockGen.c,
libnetworking/rtems_webserver/sym.c,
libnetworking/rtems_webserver/uemf.c,
libnetworking/rtems_webserver/uemf.h,
libnetworking/rtems_webserver/um.c,
libnetworking/rtems_webserver/um.h,
libnetworking/rtems_webserver/umui.c,
libnetworking/rtems_webserver/url.c,
libnetworking/rtems_webserver/value.c,
libnetworking/rtems_webserver/wbase64.c,
libnetworking/rtems_webserver/webcomp.c,
libnetworking/rtems_webserver/webmain.c,
libnetworking/rtems_webserver/webpage.c,
libnetworking/rtems_webserver/webrom.c,
libnetworking/rtems_webserver/webs.c,
libnetworking/rtems_webserver/websda.c,
libnetworking/rtems_webserver/websda.h,
libnetworking/rtems_webserver/webs.h,
libnetworking/rtems_webserver/websSSL.c,
libnetworking/rtems_webserver/websSSL.h,
libnetworking/rtems_webserver/websuemf.c,
libnetworking/rtems_webserver/wsIntrn.h:
Remove (Moved to cpukit/http).
PR 700/rtems_misc
* configure.ac, libnetworking/Makefile.am, wrapup/Makefile.am:
Remove libnetworking/rtems_webserver.
* Makefile.am: Fix network_CPPFLAGS. Reformat.
* network/GT64260eth.c: Properly prototype GT64260eth_err().
* alocal/check-custom-bsp.m4: Reflect new location of bspkit*cfg.
* network/GT64260eth.c: Remove ether_sprintf.
* startup/bspstart.c: Remove warnings for variables only used when
certain conditionals are enabled..
* Makefile.am: Add missing network_CPPFLAGS.
* librdbg/src/i386/rdbg_f.c, librdbg/src/m68k/rdbg_cpu_asm.S
librdbg/src/m68k/rdbg_f.c: Use POSIX fixed size types.
* startup/bspstart.c: Use POSIX fixed size types.
* libnetworking/rtems_servers/ftpd.c: Use POSIX fixed size types.
* libchip/rtc/mc146818a.c, libchip/rtc/mc146818a.h,
libchip/rtc/mc146818a_ioreg.c: Use POSIX fixed size types.
* mpc5xx/clock/clock.c, mpc5xx/include/mpc5xx.h
mpc5xx/timer/timer.c: Use POSIX fixed size types.
* clock/ckinit.c, include/mcf5272.h, timer/timer.c:
Use POSIX fixed-size types.
* timer/timer.c: Use POSIX fixed-size types.
* include/bsp.h, network/network.c, startup/bspstart.c,
startup/init5272.c: Use POSIX fixed-size types.
* Makefile.am: Build networking.rel conditionally.
Reformat. Cosmetics.
* wrapup/Makefile.am: Build networking.rel conditionally.
* startup/bspstart.c: Eliminate RTEMS fixed size types.
* aclocal/enable-bare.m4: New (moved from aclocal).
* startup/bspstart.c: Remove BSP_build_date.
* GT64260/Makefile.am, clock/Makefile.am, console/Makefile.am,
include/Makefile.am, irq/Makefile.am, network/Makefile.am,
pci/Makefile.am, start/Makefile.am, startup/Makefile.am,
tod/Makefile.am, vectors/Makefile.am, vme/Makefile.am:
Remove (obsolete).
* configure.ac: Adaptations to rtems-4.7.
* Makefile.am, wrapup/Makefile.am: Reworked.
* start/preload.S, include/bsp.h, vectors/exceptionhandler.c,
startup/bspstart.c: Misc. adaptations to rtems-4.7.
* configure: Remove (Bogus).
* include/tm27.h: New (Stub).
* README, configure.ac, GT64260/Makefile.am, include/bsp.h,
irq/Makefile.am, irq/irq.c, irq/irq.h, irq/irq_init.c,
network/GT64260ethreg.h, pci/pci.c, startup/bspstart.c: CVS Id string
and license corrected.
* GT64260/Makefile.in, clock/Makefile.in, console/Makefile.in,
include/Makefile.am, include/Makefile.in, irq/Makefile.in,
network/Makefile.in, pci/Makefile.in, start/Makefile.in,
startup/Makefile.in, vectors/Makefile.in, vme/Makefile.in,
wrapup/Makefile.in: Removed.
