PR 781/rtems_misc
* libchip/serial/ns16550_p.h: Fix baud rate calculation
* score603e/Makefile.am, score603e/configure.ac,
score603e/console/console.c, score603e/include/bsp.h,
score603e/include/gen2.h, score603e/include/tm27.h,
score603e/startup/bspstart.c: Update score603e to new exception model
NOTE: These modifications have not been tested on hardware.
* acinclude.m4: Initial release of ep1a bsp
* ep1a/Makefile.am, ep1a/bsp_specs, ep1a/configure.ac,
ep1a/console/alloc360.c, ep1a/console/console.c,
ep1a/console/console.h, ep1a/console/init68360.c,
ep1a/console/m68360.h, ep1a/console/mc68360_scc.c,
ep1a/console/ns16550cfg.c, ep1a/console/ns16550cfg.h,
ep1a/console/rsPMCQ1.c, ep1a/console/rsPMCQ1.h, ep1a/include/bsp.h,
ep1a/irq/irq.c, ep1a/irq/irq_init.c, ep1a/pci/no_host_bridge.c,
ep1a/start/start.S, ep1a/startup/bspstart.c, ep1a/startup/linkcmds,
ep1a/vme/vmeconfig.c: New files.
* mcf5206/include/mcfuart.h: Reformatted.
* s3c2400/clock/clockdrv.c: Eliminate warning.
* console/uart.h: Eliminate tabs.
* startup/bspstart.c: Eliminate warnings.
* clock/clock.c: Eliminate warning for duplicate definition of
PPC_Set_decrementer.
* startup/idtmem.S: Eliminate warnings and be more consistent with
other MIPS assembly.
* clock/clockdrv.c: Add include of rtems/bspIo.h.
* include/tm27.h: Delete TX3904 code and leave stub.
* network/network.c: Eliminate warnings.
* startup/bspclean.c: Add include of rtems/bspIo.h. Reformat.
* network/network.c: Change int to rtems_id to eliminate warning.
* startup/alloc360.c: Eliminate warnings.
* pci/pcibios.c: Reformatted.
* 3c509/3c509.c, wd8003/wd8003.c: Eliminate warnings.
* startup/bspstart.c: Add include rtems/bspIo.h to eliminate warning.
* network/network.c: Add include rtems/bspIo.h to eliminate warning.
PR 779/bsp
* clock/p_clock.c: Add parameter to powerpc exception handler routines
PR 779/bsp
* mpc5xx/console-generic/console-generic.c, mpc5xx/irq/irq.c,
mpc5xx/irq/irq.h, mpc5xx/irq/irq_init.c: Add parameter to powerpc
interrupt handler routines
PR 779/bsp
* clock/p_clock.c, console/console.c, console/uart.c, console/uart.h,
irq/irq.c, irq/irq.h, irq/irq_init.c:
powerpc: add parameter to new exception interrupt handlers
* libchip/serial/ns16550.c:
Fixed warnings generated in various powerpc configurations
* libchip/serial/ns16550.c: Modified
ISR to work with PPC new exception processing
* irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c: Added parameter
to irq handler
* clock/ckinit.c, console/console.c, console/ps2_mouse.c,
console/serial_mouse.c, timer/timer.c: Added parameter to irq handler
* network/network.c: Fix warnings.
* GT64260/GT64260TWSI.c, GT64260/GT64260TWSI.h, irq/GT64260Int.c,
network/GT64260eth.c, pci/pci.c, startup/bspclean.c,
startup/reboot.c: Fix warnings.
* clock/clock.c: Fix multiple defined warning
* mpc6xx/clock/c_clock.c, mpc6xx/clock/c_clock.h,
mpc8260/console-generic/console-generic.c: add parameter to new
exception interrupt handlers in powerpc bsps
PR 779/bsp
* vmeUniverse/vmeUniverse.c: add parameter to new exception interrupt
PR 779/bsp
* irq/irq.c, irq/irq.h, irq/irq_init.c: add parameter to new exception
PR 779/bsp
* irq/irq.c, irq/irq.h, irq/irq_init.c, network/GT64260eth.c: add
parameter to new exception interrupt handlers in powerpc bsps
PR 779/bsp
* clock/p_clock.c, irq/irq.c, irq/irq.h, irq/irq_init.c,
network/network.c: add parameter to new exception interrupt handlers
in powerpc bsps
PR 779/bsp
* irq/irq.c, irq/irq.h: add parameter to new exception
PR 779/bsp
* startup/linkcmds: add missing section to link cmds
PR 778/bsps
* include/bsp.h, include/gen2.h, startup/FPGA.c, startup/Hwr_init.c,
startup/bspstart.c, tod/tod.c:
modify SCORE_.. to BSP_.. for externally used define's.
PR 777/bsps
* include/bsp.h: Add a Processor_Synchronize command in bsp.h
* au1x00/.cvsignore: New file.
* include/.cvsignore: Fixed typo.
* network/network.c: Now compiles with GCC 4.0.
* libchip/network/dec21140.c, libchip/network/elnk.c,
libchip/network/if_fxp.c: Continue PCI API unification. All use
pci_find_device(). Network drivers manufacture a signature since all
calls have not been converted yet.
* vmeUniverse/README.porting, vmeUniverse/vmeUniverse.c: Continue PCI
API unification. All use pci_find_device().
* pci/pci.c, pci/pci.h, pci/pcifinddevice.c: Continue PCI API
unification. All use pci_find_device(). Also reformat to remove tabs.
