* | score: Refactor SMP cache manager support | Sebastian Huber | 2015-04-20 | 1 | -172/+51 |
* | Rename or1ksim BSP to generic_or1k | Hesham ALMatary | 2015-04-19 | 24 | -255/+255 |
| | | | | | | | or1ksim BSP was initially named after or1ksim simulator, and it was intented to only run there. But now it can also run on QEMU, jor1k and real FPGA boards without modifications. It makes more sense to give it a new generic name like generic_or1k. | ||||
* | LEON3: gptimer drvmgr init simplified wrt boot | Daniel Hellstrom | 2015-04-17 | 1 | -40/+6 |
* | LEON3: move timer variable to where initialized | Daniel Hellstrom | 2015-04-17 | 2 | -5/+2 |
* | LEON3: simplify amba initialization | Daniel Hellstrom | 2015-04-17 | 1 | -7/+2 |
* | LEON3: clock irq always same as timer instance | Daniel Hellstrom | 2015-04-17 | 1 | -10/+1 |
| | | | | | | The leon.h already contains the definition of LEON3_CLOCK_INDEX and irq must always follow that when separate IRQ is supported by the HW. The definitions are resued from leon.h. | ||||
* | DRVMGR: remove struct driver registration func | Daniel Hellstrom | 2015-04-17 | 2 | -6/+6 |
* | DRVMGR: renamed RES_EMPTY to DRVMGR_RES_EMPTY | Daniel Hellstrom | 2015-04-17 | 2 | -2/+2 |
* | DRVMGR: KEY_TYPE now a enum drvmgr_kt | Daniel Hellstrom | 2015-04-17 | 23 | -78/+78 |
* | DRVMGR: renamed info_dev to get_info_dev | Daniel Hellstrom | 2015-04-17 | 1 | -1/+1 |
* | DRVMGR: change name of freq_get to get_freq | Daniel Hellstrom | 2015-04-17 | 1 | -1/+1 |
* | sparc bsps: updated license to rtems.org | Daniel Hellstrom | 2015-04-17 | 92 | -92/+92 |
* | leon3,ngmp: cpucounter initialization use proper names | Daniel Hellstrom | 2015-04-17 | 1 | -2/+3 |
| | | | | | | To be merged with "leon3,ngmp: simplify cpucounter initialization" .. as an affect of previous patch, the next must be updated too. | ||||
* | leon3: timer config updated to use proper naming | Daniel Hellstrom | 2015-04-17 | 2 | -7/+7 |
| | | | | To be merged with "leon3: make timer initialization configurable" | ||||
* | LEON: converted LEON4-N2X to BSD header | Daniel Hellstrom | 2015-04-17 | 1 | -4/+4 |
* | LEON: converted PCI peripherals to BSD header | Daniel Hellstrom | 2015-04-17 | 5 | -24/+24 |
* | LEON: converted AT697,GRPCi,GRPCI2,PCIF to BSD header | Daniel Hellstrom | 2015-04-17 | 4 | -40/+31 |
* | LEON: move driver headers to bsp/ directory | Daniel Hellstrom | 2015-04-17 | 58 | -432/+432 |
* | MCTRL: fix build warnings in MCTRL driver | Daniel Hellstrom | 2015-04-17 | 6 | -0/+38 |
* | AMBAPP GRLIB: fix build warnings | Daniel Hellstrom | 2015-04-17 | 1 | -0/+3 |
* | LEON2: fix build warnings | Daniel Hellstrom | 2015-04-17 | 1 | -22/+11 |
* | AMBAPP_BUS: fix build warnings | Daniel Hellstrom | 2015-04-17 | 1 | -23/+18 |
* | LEON CONS: fix build warnings | Daniel Hellstrom | 2015-04-17 | 1 | -1/+1 |
* | GR-TMTC-1553: fix build warnings | Daniel Hellstrom | 2015-04-17 | 2 | -12/+16 |
* | GR-RASTA-TMTC: fix build warnings | Daniel Hellstrom | 2015-04-17 | 2 | -17/+20 |
* | GR-RASTA-SPW-ROUTER: fix build warnings | Daniel Hellstrom | 2015-04-17 | 2 | -11/+11 |
* | GR-RASTA-IO: fix build warnings | Daniel Hellstrom | 2015-04-17 | 2 | -17/+16 |
* | GR-RASTA-ADCDAC: fix build warnings | Daniel Hellstrom | 2015-04-17 | 2 | -15/+16 |
* | GR-LEON4-N2X: fix build warnings | Daniel Hellstrom | 2015-04-17 | 2 | -12/+14 |
* | GR_701: fix build warnings | Daniel Hellstrom | 2015-04-17 | 2 | -13/+14 |
* | GRGPIO: fix buld warnings | Daniel Hellstrom | 2015-04-17 | 1 | -9/+9 |
* | GPIOLIB: fix build warnings | Daniel Hellstrom | 2015-04-17 | 1 | -10/+5 |
* | GRADCDAC: fix build warnings | Daniel Hellstrom | 2015-04-17 | 1 | -2/+2 |
* | GENIRQ: fix build warnings | Daniel Hellstrom | 2015-04-17 | 1 | -1/+6 |
* | GRPWM: fix build warnings | Daniel Hellstrom | 2015-04-17 | 1 | -6/+12 |
* | SPWCUC: fix build warnings | Daniel Hellstrom | 2015-04-17 | 1 | -2/+2 |
* | SPICTRL: fix build warnings | Daniel Hellstrom | 2015-04-17 | 1 | -10/+19 |
* | GRSPW router: fix build warnings | Daniel Hellstrom | 2015-04-17 | 2 | -13/+28 |
* | GRSPW_PKT: fix build warnings | Daniel Hellstrom | 2015-04-17 | 2 | -1/+4 |
* | TLIB: fix build warnings | Daniel Hellstrom | 2015-04-17 | 1 | -0/+13 |
* | TLIB Clock: fix build warnings | Daniel Hellstrom | 2015-04-17 | 1 | -1/+2 |
* | GRASCS: fix build warnings | Daniel Hellstrom | 2015-04-17 | 1 | -1/+1 |
* | GRCTM: fix build warnings | Daniel Hellstrom | 2015-04-17 | 2 | -1/+4 |
* | GRTM: fix build warnings | Daniel Hellstrom | 2015-04-17 | 2 | -4/+9 |
* | GRTC: fix build warnings | Daniel Hellstrom | 2015-04-17 | 2 | -16/+16 |
* | LEON: GRPCI2 driver warning fixes | Daniel Hellstrom | 2015-04-17 | 1 | -10/+11 |
* | LEON: I2CMST driver warnings fixes | Daniel Hellstrom | 2015-04-17 | 2 | -1/+4 |
* | LEON: OCCAN driver warnings fixes | Daniel Hellstrom | 2015-04-17 | 1 | -2/+5 |
* | LEON: B1553BRM driver warnings fixes | Daniel Hellstrom | 2015-04-17 | 2 | -3/+8 |
* | LEON: B1553RT driver warnings fixes | Daniel Hellstrom | 2015-04-17 | 2 | -4/+6 |
