This field is unused except for special case simulator clock drivers.
In these places use an alternative. Add and use
_Thread_Set_global_exit_status() and _Thread_Get_global_exit_status().
Eliminate copy and paste. Use the _Objects_Information_table since this
will take into account that more than one internal thread may exist,
e.g. MPCI thread or idle threads of secondary processors.
Delete bsp_smp_wait_for(). Other parts of the system work without
timeout, e.g. the spinlocks. Using a timeout here does not make the
system more robust.
Delete bsp_smp_cpu_state and replace it with Per_CPU_State. The
Per_CPU_State follows the Score naming conventions. Add
_Per_CPU_Change_state() and _Per_CPU_Wait_for_state() functions to
change and observe states.
Use Per_CPU_State in Per_CPU_Control instead of the anonymous integer.
Add _CPU_Processor_event_broadcast() and _CPU_Processor_event_receive()
functions provided by the CPU port. Use these functions in
_Per_CPU_Change_state() and _Per_CPU_Wait_for_state().
Add prototype for _SMP_Send_message().
Delete RTEMS_BSP_SMP_FIRST_TASK message. The first context switch is
now performed in rtems_smp_secondary_cpu_initialize(). Issuing the
first context switch in the context of the inter-processor interrupt is
not possible on systems with a modern interrupt controller. Such an
interrupt controler usually requires a handshake protocol with interrupt
acknowledge and end of interrupt signals. A direct context switch in an
interrupt handler circumvents the interrupt processing epilogue and may
leave the system in an inconsistent state.
Release lock in rtems_smp_process_interrupt() even if no message was
delivered. This prevents deadlock of the system.
Simplify and format _SMP_Send_message(),
_SMP_Request_other_cores_to_perform_first_context_switch(),
_SMP_Request_other_cores_to_dispatch() and
_SMP_Request_other_cores_to_shutdown().
Do not call bsp_smp_secondary_cpu_initialize() in
rtems_smp_secondary_cpu_initialize(). This allows more flexibilty in
the BSP low-level code. Specify context requirements for a call to
Call _SMP_Handler_initialize() later and move bsp_smp_initialize() into
_SMP_Handler_initialize(). Change bsp_smp_initialize() prototype to
match integer types of calling context.
Move the .fast_text section after the .vector section. The .fast_test
section is normally not empty in case some functions should execute from
an internal SRAM. This would be also the area for the .vector section.
The vector table must be the first content of such an area.
In case the VMA and LMA regions differ, the LMA start address is now no
longer aligned with the alignment of the input sections:
http://sourceware.org/bugzilla/show_bug.cgi?id=15222
Delete rtems_configuration_get_smp_maximum_processors(). Delete
rtems_configuration_smp_maximum_processors variable. Add
maximum_processors field to rtems_configuration_table if RTEMS_SMP is
defined. Add rtems_configuration_get_maximum_processors().
This makes continuous UART polling unnecessary.
Add mask for receive error bits and getter macro for
the data field.
The .vector section contains read-write data (several mode stacks).
Move it to the read-write data area.
i386 soft-float is no longer supported by gcc. Dropping
all references to soft-float in the pc386 BSP.
Add support for LM3S3749.
Rename open_dev_console() to rtems_libio_post_driver(). Rename
rtems_libio_supp_helper to rtems_libio_post_driver_helper.
Add and use rtems_libio_helper function type. Add and use
rtems_libio_helper_null() instead of NULL pointer.
Change SDRAM initialization according to application note AN3221.
