path: root/c (follow)
* 2002-08-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-212-1/+12
| | | | * Makefile.am: Add preinstall-stamp.
* 2002-08-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-214-40/+25
| | | | | | | * include/Makefile.am: Remove. * Makefile.am: Merge in former include/Makefile.am. * configure.ac: Reflect changes above. Take out unnecessary autoconf macros.
* 2002-08-14 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2002-08-144-4/+26
| | | | | | | * mips-stub.c: Re-debugged a breakpoint problem, zbreak target address was a char * which caused the target instruction to not be fully copied, so the zbreak logic corrupted the original instruction and didn't insert a valid break instruction.
* 2002-08-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-142-0/+12
| | | | | | * start/start16.S: Per PR259, added code to test for video present before touching the adapter. Eric Norum <eric.norum@usask.ca> tested this patch.
* 2002-08-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-145-3/+11
| | | | | | | * rtems_servers/ftpd.c: Remove unused variable buf. * pppd/md5.c: #include <string.h> to make gcc31 happy. * rtems_telnetd/telnetd.c: #include <string.h> to make gcc31 happy. * rtems_webserver/webmain.c: Remove unused variable dir, cp.
* 2002-08-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-124-6/+24
| | | | | | | | Posix-BSP-Hacks: * configure.ac: Add AM_CONDITIONAL(LIBCHIP). Pass RTEMS_HOST to make/bsp.mak * Makefile.am: Pass RTEMS_HOST to make/bsp.mak. * wrapup/Makefile.am: Apply AM_CONDITIONAL(LIBCHIP).
* 2002-08-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-122-1/+5
| | | | * pppd/utils.c: Include i960 in varargs conditional to avoid error.
* 2002-08-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-122-0/+5
| | | | * console/ps2_mouse.c: Include <string.h> (for abort/exit).
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-112-6/+12
| | | | * bootloader/Makefile.am: Fix that crappy Makefile.am once again.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-112-1/+7
| | | | | * configure.ac: Remove RTEMS_BSP_ALIAS. Add RTEMS_CHECK_BSP_CACHE.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-112-2/+6
| | | | * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-113-7/+12
| | | | | * mpc6xx/wrapup/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-112-1/+5
| | | | * shmdr/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-117-11/+20
| | | | | | | | | * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * shmsupp/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * timer/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-1112-26/+46
| | | | | * start/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-116-9/+21
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-116-4/+20
| | | | * Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-1110-12/+24
| | | | | | | | | | | | * PCI_bus/Makefile.am: Use .$(OBJEXT) instead of .o. * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * timer/Makefile.am: Use .$(OBJEXT) instead of .o. * tod/Makefile.am: Use .$(OBJEXT) instead of .o. * vectors/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-119-14/+25
| | | | | | | | | | | * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * shmsupp/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * timer/Makefile.am: Use .$(OBJEXT) instead of .o. * vectors/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-1113-18/+33
| | | | | | | | | | | | | | | * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * network/Makefile.am: Use .$(OBJEXT) instead of .o. * nvram/Makefile.am: Use .$(OBJEXT) instead of .o. * pci/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * timer/Makefile.am: Use .$(OBJEXT) instead of .o. * tod/Makefile.am: Use .$(OBJEXT) instead of .o. * universe/Makefile.am: Use .$(OBJEXT) instead of .o. * vectors/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-119-18/+29
| | | | | | | | | | | * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * irq/Makefile.am: Use .$(OBJEXT) instead of .o. * network/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * vectors/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* Fix broken ChangeLogRalf Corsepius2002-08-111-15/+0
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-1113-26/+41
| | | | | | | | | | | | | | | * bootloader/Makefile.am: Use .$(OBJEXT) instead of .o. * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * irq/Makefile.am: Use .$(OBJEXT) instead of .o. * motorola/Makefile.am: Use .$(OBJEXT) instead of .o. * openpic/Makefile.am: Use .$(OBJEXT) instead of .o. * pci/Makefile.am: Use .$(OBJEXT) instead of .o. * residual/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * vectors/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-111-0/+15
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-118-12/+22
| | | | | | | | | | * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * irq/Makefile.am: Use .$(OBJEXT) instead of .o. * network/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * vectors/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-115-4/+11
| | | | | | | * dlentry/Makefile.am: Use .$(OBJEXT) instead of .o. * flashentry/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-114-3/+9
| | | | | | * dlentry/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-1110-18/+30
| | | | | | | | | | | | * canbus/Makefile.am: Use .$(OBJEXT) instead of .o. * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * irq/Makefile.am: Use .$(OBJEXT) instead of .o. * network/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * vectors/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-1110-13/+25
| | | | | | | | | | | | * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * scv64/Makefile.am: Use .$(OBJEXT) instead of .o. * sonic/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * timer/Makefile.am: Use .$(OBJEXT) instead of .o. * tod/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-117-6/+15
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-1112-28/+44
| | | | | | | | * console/Makefile.am: Use .$(OBJEXT) instead of .o. * liblnk/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-1128-57/+93
| | | | | | | | | * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * timer/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-119-15/+26
| | | | | | | | | | | * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * fatal/Makefile.am: Use .$(OBJEXT) instead of .o. * network/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * timer/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-1111-18/+31
| | | | | | | | | | | | | * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * consolex/Makefile.am: Use .$(OBJEXT) instead of .o. * network/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * timer/Makefile.am: Use .$(OBJEXT) instead of .o. * tod/Makefile.am: Use .$(OBJEXT) instead of .o. * tools/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-1116-28/+48
| | | | | | | | | | * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * shmsupp/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * timer/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-1121-39/+66
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-118-17/+27
| | | | | | | | | | * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * spurious/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * timer/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-118-13/+23
| | | | | | | | | | * console/Makefile.am: Use .$(OBJEXT) instead of .o. * i2c/Makefile.am: Use .$(OBJEXT) instead of .o. * nvram/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * tod/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-1116-27/+47
| | | | | | | | | | * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * network/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * timer/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-1116-33/+53
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-118-14/+24
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-1128-49/+85
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-116-8/+16
| | | | | | | | * shmsupp/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * tty/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-116-10/+18
| | | | | | | | * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-115-9/+16
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-1116-24/+44
| | | | | | | | | | | | * 3c509/Makefile.am: Use .$(OBJEXT) instead of .o. * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * ne2000/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * timer/Makefile.am: Use .$(OBJEXT) instead of .o. * wd8003/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
| | | | | | | | | | * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * irq/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * timer/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-117-13/+22
