* | Miscellaneous - Clean up file headers so patterns followed | Joel Sherrill | 2012-05-11 | 4 | -31/+28 |
| | | | | XXX | ||||
* | librtems++ - Remove junk line accidentally committed | Joel Sherrill | 2012-05-11 | 1 | -3/+2 |
* | pc386 - Clock driver compiles again plus clean up | Joel Sherrill | 2012-05-10 | 1 | -18/+26 |
| | | | | | | | The clock drivers were very inconsistent about prototyping the ISR handlers. This broke with the recent clean up. Tested on qemu. | ||||
* | clockdrv_shell.h - Fix commment | Joel Sherrill | 2012-05-10 | 1 | -1/+1 |
* | clockdrv_shell.c - Remove unreferenced and obsolete file | Joel Sherrill | 2012-05-10 | 1 | -16/+0 |
* | Clock Driver Shell - ISR handler prototype should follow port interrupt model | Joel Sherrill | 2012-05-10 | 1 | -1/+2 |
| | | | | | | The prototype for the clock driver tick isr varies based upon the interrupt model used by the port. This driver was checking solely upon a flag set by the BSP. | ||||
* | nds - Clock driver compiles again | Joel Sherrill | 2012-05-10 | 1 | -12/+17 |
* | nds/libnds - Fix missing prototype warning and formatting | Joel Sherrill | 2012-05-10 | 1 | -6/+9 |
* | hurricane - Remove unused file setvec.c | Joel Sherrill | 2012-05-10 | 1 | -44/+0 |
* | score603e - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 1 | -46/+0 |
* | virtex4 - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 1 | -6/+0 |
* | virtex - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 1 | -7/+0 |
* | mbx8xx - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 1 | -1/+0 |
* | haleakala - Eliminate commented out code | Joel Sherrill | 2012-05-09 | 1 | -8/+0 |
* | mpc8260ads - Eliminate commented out code | Joel Sherrill | 2012-05-09 | 1 | -6/+0 |
* | mpc8260ads - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 1 | -6/+0 |
* | malta - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 1 | -3/+0 |
* | jmr3904 - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 1 | -5/+0 |
* | hurricane - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 1 | -5/+0 |
* | genmongoosev - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 1 | -5/+0 |
* | rbtx4925 - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 1 | -5/+0 |
* | rbtx4938 - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 1 | -5/+0 |
* | csb350 - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 2 | -7/+14 |
* | libchip/serial - Only use set_vector() on Simple Vectored Architectures | Joel Sherrill | 2012-05-09 | 2 | -2/+11 |
* | librtems++ - Disable Interrupt Class When Not Simple Vectored | Joel Sherrill | 2012-05-09 | 1 | -0/+4 |
| | | | | | | This class only works on Simple Vectored Architectures. Even worse, it is not guaranteed to compile on a Programmable Interrupt Vector architecture. | ||||
* | jmr3904 - Correct tm27.h to use PIC Interrupt Model | Joel Sherrill | 2012-05-07 | 1 | -20/+9 |
* | genmongoosev - Correct tm27.h to use PIC Interrupt Model | Joel Sherrill | 2012-05-07 | 1 | -23/+9 |
* | csb350 - Correct tm27.h to use PIC Interrupt Model | Joel Sherrill | 2012-05-07 | 1 | -10/+8 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 300 | -0/+780 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 3 | -9/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 47 | -127/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 2 | -6/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 109 | -217/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 6 | -16/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 6 | -18/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 10 | -30/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 36 | -111/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 4 | -12/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 13 | -42/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 48 | -144/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 5 | -14/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 8 | -25/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 20 | -68/+0 |
