* acinclude.m4: Add the av5282 BSP.
* .cvsignore, Makefile.am, README, bsp_specs, configure.ac,
clock/clock.c, console/console.c, include/bsp.h,
include/bspopts.h.in, include/coverhd.h, include/tm27.h,
network/network.c, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/init5282.c, startup/linkcmds,
startup/linkcmdsflash, startup/linkcmdsram, timer/timer.c: New files.
PR 727/bsps
* at91rm9200/clock/clock.c: Correct the equation so 10 milliseconds
tick is not 9.365 miliseconds long.
* optman/Makefile.am: Add preinstall.am.
* Makefile.am: Add preinstall.am.
* configure.ac: Add AMPOLISH3.
* preinstall.am: New.
PR 816/bsps
* mpc8xx/include/mpc8xx.h: The struct which describes SCC Ethernet mode
parameters (m8xxSCCENparms_t) does not match the hardware: members
taddr_h and taddr_l are transposed. When loading new multicast group
addresses into the hash table, the wrong hash bit is set.
* Makefile.am: Unconditionally initialize include_libcpu_HEADERS.
running.
* Makefile.am: Fix broken patch to mcf5235.
* Makefile.am: added smc.rel.
* smc/smc.c, smc/smc.h: New files.
* libchip/network/if_fxp.c: Change status of PCI Id 0x1229 from
UNTESTED to tested.
PR 813/networking
* ne2000/ne2000.c: The ne2000 driver on pc386 has been broken since a
parameter was added to irq handlers (2005-04-18). Before these
changes the argument to the interrupt handler was the interrupt
number, now the argument is handle, but the ne2000 driver needs the
interrupt number. The fix is to set the handle to the interrupt
number.
* Makefile.am: Eliminate duplicate entry for include_mcf5235... .
* mpc5xx/vectors/vectors.h: Add hack to avoid warning.
* lcd/lcd.c: removed.
* Makefile.am: Remove lcd.rel, added console/uart.c,
removed conio stuffs.
* console/conio.c, console/console.c, console/defaultfont.c,
include/conio.h : files removed.
* console/uart.c: New file.
* include/bsp.h: lcd.c prototypes removed.
* startup/bspstart.c: bsp_reset() cause gp32 to reset to bios,
added a bsp_idle_task which put s3c2400 in a "wait for IRQ" state.
* Makefile.am: Remove s3c2400/lcd/lcd.c
* s3c2400/lcd/lcd.c: Remove.
* s3c2400/clock/support.c: file "rewrote" to avoid GPL.
* acinclude.m4: Added GBA BSP.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
clock/clockdrv.c, console/conio.c, console/console.c,
console/defaultfont.c, include/arm_mode_bits.h, include/asm_macros.h,
include/bsp.h, include/bspopts.h.in, include/conio.h, include/gba.h,
include/gba_registers.h, include/tm27.h, irq/bsp_irq_asm.S,
irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, irq/irq_asm.S,
irq/irq_init.c, start/logo.S, start/start.S, startup/bspstart.c,
startup/cpu.c, startup/cpu_asm.S, startup/exit.c, startup/linkcmds,
* console/keyboard.c: Apply CHAR_BIT to compute BITS_PER_LONG.
* console/console-io.c: Remove unused variable i.
of that for us.
Many thanks to Mr. Kolja Waschk for identifying the problem.
* librdbg/src/powerpc/excep_f.c: Conditionalize use of ISI vector since
it is not supported by the MPC5xx.
* include/.cvsignore: New file.
* libchip/network/if_dc.c: Begin to convert to new PCI and IRQ
interface. Also correct attempting to build on other than PowerPC and
x86.
* acinclude.m4: Added mcf5235.
* ChangeLog, Makefile.am, configure.ac, preinstall.am: Addition of
mcf5235 support.
* mcf5235/include/mcf5235.h: New file.
clock/clock.c, console/console.c, include/bsp.h, include/coverhd.h,
include/tm27.h, network/network.c, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/init5235.c, startup/linkcmds,
* libchip/Makefile.am: Add driver for Tulip clones.
* libchip/network/README.tulipclone, libchip/network/if_dc.c,
libchip/network/if_dcreg.h: New files.
* Makefile.am: Include lcd.rel.
* Makefile.am: Add s3c2400/lcd/lcd.c, s3c2400/clock/support.c
* s3c2400/clock/clockdrv.c: Update to use get_PCLK()
* s3c2400/timer/timer.c: Update to use get_PCLK()
* bsp_specs: Add rules for cpp support
* include/bsp.h: Add gp32 support fct prototypes
* console/conio.c: Moved video buffer to 0x0c7ed000
* startup/bspstart.c: Add some init code, some cleaning...
PR 799/bsps
* include/bsp.h: Add include of bsp/vectors.h so rdbg.h can be
compiled.
