* sptests/sp21/sptest.adb: Fixed IO_Initialize invocations to
match corrected prototype.
* sptests/sp19/sptest.adp: Added from old Ada implementation.
* tmtests/tm27/.cvsignore: Removed. Missed in previous attempts.
* sptests/sp09/sptest.adb: Add Result to SCREEN_13.
Remove Status from TASK_1.
* sptests/sp21/sptest.adb: Add Result to TASK_1.
* tmtests/tm20/tmtest.adb: Remove various RETURN_VALUEs.
* ada.am: Remove ADACOMPILE, ADAC. Add AM_LDFLAGS, LDFLAGS.
* configure.ac: Check for m4. Abort if HAS_GNAT = no.
* tm27 and tm27 are irrelevant as Ada binding tests.
* tmtests/tm26/config.h, tmtests/tm26/config.h: Removed.
* tmtests/tm26/Makefile.am, tmtests/tm26/README, tmtests/tm26/tm26.adb,
tmtests/tm26/tmtest.adb, tmtests/tm26/tmtest.adp,
tmtests/tm26/tmtest.ads, tmtests/tm27/Makefile.am, tmtests/tm27/README,
tmtests/tm27/tm27.adb, tmtests/tm27/tmtest.adb,
tmtests/tm27/tmtest.ads: Removed.
* configure.ac, tmtests/Makefile.am: Modified to reflect above.
* sptests/sp19/sptest.adb: Modified to follow pattern of SP01
even though this test is not supported.
* sptests/sp19/sp19.adb: New file.
* mptests/mp01/mptest.ads, mptests/mp02/mptest.ads,
mptests/mp03/mptest.ads, mptests/mp04/mptest.ads,
mptests/mp05/mptest.ads, mptests/mp06/mptest.ads,
mptests/mp07/mptest.ads, mptests/mp08/mptest.ads,
mptests/mp09/mptest.ads, mptests/mp10/mptest.ads,
mptests/mp11/mptest.ads, mptests/mp12/mptest.ads,
mptests/mp13/mptest.ads, mptests/mp14/mptest.adb,
mptests/mp14/mptest.ads: Per PR274, identify the need for the
BSP_MPCI package. It was a trivial dependency and eliminated.
* sptests/sp19/sp19.adb: Removed/Renamed to sptest.adb.
* sptests/sp19/sptest.adb: Added/Renamed from sptest.adb.
* sptests/sp09/sptest.adb, sptests/sp21/sptest.adb: All RTEMS IO
Manager directives take fewer arguments than these tests used.
* startup/linkcmds: Move .init section after text section so
C+ global constructors work.
* sptests/sp04/Makefile.am: Remove init.$(OBJEXT).
* Makefile.am: Activate tmtests.
* configure.ac: Activate tmtests.
* samples/base_mp/Makefile.am: Add nodeX subdirs.
* sptests/sp01/Makefile.am: Add *.scn.
* sptests/sp02/Makefile.am: Add *.scn.
* sptests/sp03/Makefile.am: Add *.scn.
* sptests/sp04/Makefile.am: Add *.scn.
* sptests/sp05/Makefile.am: Add *.scn.
* sptests/sp06/Makefile.am: Add *.scn.
* sptests/sp07/Makefile.am: Add *.scn.
* sptests/sp08/Makefile.am: Add *.scn.
* sptests/sp09/Makefile.am: Add *.scn.
* sptests/sp11/Makefile.am: Add *.scn.
* sptests/sp12/Makefile.am: Add *.scn.
* sptests/sp13/Makefile.am: Add *.scn.
* sptests/sp14/Makefile.am: Add *.scn.
* sptests/sp15/Makefile.am: Add *.scn.
* sptests/sp16/Makefile.am: Add *.scn.
* sptests/sp17/Makefile.am: Add *.scn.
* sptests/sp19/Makefile.am: Add *.scn.
* sptests/sp20/Makefile.am: Add *.scn.
* sptests/sp21/Makefile.am: Add *.scn.
* sptests/sp22/Makefile.am: Add *.scn.
* sptests/sp23/Makefile.am: Add *.scn.
* sptests/sp24/Makefile.am: Add *.scn.
* sptests/sp25/Makefile.am: Add *.scn.
* tmtests/Makefile.am: New.
* tmtests/tm01/Makefile.am: New.
* tmtests/tm02/Makefile.am: New.
* tmtests/tm03/Makefile.am: New.
* tmtests/tm04/Makefile.am: New.
* tmtests/tm05/Makefile.am: New.
* tmtests/tm06/Makefile.am: New.
* tmtests/tm07/Makefile.am: New.
* tmtests/tm08/Makefile.am: New.
* tmtests/tm09/Makefile.am: New.
* tmtests/tm10/Makefile.am: New.
* tmtests/tm11/Makefile.am: New.
* tmtests/tm12/Makefile.am: New.
* tmtests/tm13/Makefile.am: New.
* tmtests/tm14/Makefile.am: New.
* tmtests/tm15/Makefile.am: New.
* tmtests/tm16/Makefile.am: New.
* tmtests/tm17/Makefile.am: New.
* tmtests/tm18/Makefile.am: New.
* tmtests/tm19/Makefile.am: New.
* tmtests/tm20/Makefile.am: New.
* tmtests/tm21/Makefile.am: New.
* tmtests/tm22/Makefile.am: New.
* tmtests/tm23/Makefile.am: New.
* tmtests/tm24/Makefile.am: New.
* tmtests/tm25/Makefile.am: New.
* tmtests/tm26/Makefile.am: New.
* tmtests/tm26/tmtest.adb
* tmtests/tm27/Makefile.am: New.
* tmtests/tm28/Makefile.am: New.
* tmtests/tm29/Makefile.am: New.
* tmtests/tmck/Makefile.am: New.
* tmtests/tmoverhd/Makefile.am: New.
* Makefile.am: New.
* configure.ac: New.
* ada.am: New.
* support/Makefile.am: New.
* samples/Makefile.am: New.
* samples/base_mp/Makefile.am: New.
* samples/base_sp/Makefile.am: New.
* samples/hello/Makefile.am: New.
* samples/ticker/Makefile.am: New.
* sptests/Makefile.am: New.
* sptests/sp01/Makefile.am: New.
* sptests/sp02/Makefile.am: New.
* sptests/sp03/Makefile.am: New.
* sptests/sp04/Makefile.am: New.
* sptests/sp05/Makefile.am: New.
* sptests/sp06/Makefile.am: New.
* sptests/sp07/Makefile.am: New.
* sptests/sp08/Makefile.am: New.
* sptests/sp09/Makefile.am: New.
* sptests/sp11/Makefile.am: New.
* sptests/sp12/Makefile.am: New.
* sptests/sp13/Makefile.am: New.
* sptests/sp14/Makefile.am: New.
* sptests/sp15/Makefile.am: New.
* sptests/sp16/Makefile.am: New.
* sptests/sp17/Makefile.am: New.
* sptests/sp19/Makefile.am: New.
* sptests/sp20/Makefile.am: New.
* sptests/sp21/Makefile.am: New.
* sptests/sp22/Makefile.am: New.
* sptests/sp23/Makefile.am: New.
* sptests/sp24/Makefile.am: New.
* sptests/sp25/Makefile.am: New.
* sptests/spsize/Makefile.am: New.
* ChangeLog: New.
* .cvsignore: New.
* mptests/.cvsignore: New.
* mptests/mp01/.cvsignore: New.
* mptests/mp02/.cvsignore: New.
* mptests/mp03/.cvsignore: New.
* mptests/mp04/.cvsignore: New.
* mptests/mp05/.cvsignore: New.
* mptests/mp06/.cvsignore: New.
* mptests/mp07/.cvsignore: New.
* mptests/mp08/.cvsignore: New.
* mptests/mp09/.cvsignore: New.
* mptests/mp10/.cvsignore: New.
* mptests/mp11/.cvsignore: New.
* mptests/mp12/.cvsignore: New.
* mptests/mp13/.cvsignore: New.
* mptests/mp14/.cvsignore: New.
* samples/.cvsignore: New.
* samples/base_sp/.cvsignore: New.
* samples/hello/.cvsignore: New.
* samples/ticker/.cvsignore: New.
* sptests/.cvsignore: New.
* sptests/sp01/.cvsignore: New.
* sptests/sp02/.cvsignore: New.
* sptests/sp03/.cvsignore: New.
* sptests/sp04/.cvsignore: New.
* sptests/sp05/.cvsignore: New.
* sptests/sp06/.cvsignore: New.
* sptests/sp07/.cvsignore: New.
* sptests/sp08/.cvsignore: New.
* sptests/sp09/.cvsignore: New.
* sptests/sp11/.cvsignore: New.
* sptests/sp12/.cvsignore: New.
* sptests/sp13/.cvsignore: New.
* sptests/sp14/.cvsignore: New.
* sptests/sp15/.cvsignore: New.
* sptests/sp16/.cvsignore: New.
* sptests/sp17/.cvsignore: New.
* sptests/sp19/.cvsignore: New.
* sptests/sp20/.cvsignore: New.
* sptests/sp21/.cvsignore: New.
* sptests/sp22/.cvsignore: New.
* sptests/sp23/.cvsignore: New.
* sptests/sp24/.cvsignore: New.
* sptests/sp25/.cvsignore: New.
* sptests/spsize/.cvsignore: New.
* support/.cvsignore: New.
* tmtests/.cvsignore: New.
* tmtests/tm01/.cvsignore: New.
* tmtests/tm02/.cvsignore: New.
* tmtests/tm03/.cvsignore: New.
* tmtests/tm04/.cvsignore: New.
* tmtests/tm05/.cvsignore: New.
* tmtests/tm06/.cvsignore: New.
* tmtests/tm07/.cvsignore: New.
* tmtests/tm08/.cvsignore: New.
* tmtests/tm09/.cvsignore: New.
* tmtests/tm10/.cvsignore: New.
* tmtests/tm11/.cvsignore: New.
* tmtests/tm12/.cvsignore: New.
* tmtests/tm13/.cvsignore: New.
* tmtests/tm14/.cvsignore: New.
* tmtests/tm15/.cvsignore: New.
* tmtests/tm16/.cvsignore: New.
* tmtests/tm17/.cvsignore: New.
* tmtests/tm18/.cvsignore: New.
* tmtests/tm19/.cvsignore: New.
* tmtests/tm20/.cvsignore: New.
* tmtests/tm21/.cvsignore: New.
* tmtests/tm22/.cvsignore: New.
* tmtests/tm23/.cvsignore: New.
* tmtests/tm24/.cvsignore: New.
* tmtests/tm25/.cvsignore: New.
* tmtests/tm26/.cvsignore: New.
* tmtests/tm27/.cvsignore: New.
* tmtests/tm28/.cvsignore: New.
* tmtests/tm29/.cvsignore: New.
* tmtests/tmck/.cvsignore: New.
* tmtests/tmoverhd/.cvsignore: New.
* Makefile.am: New.
* .cvsignore: New.
* configure.ac, shared/misc/Makefile.am: PR217 required that the
idle task be moved to libcpu so it could be more acutely aware of
the CPU model. This file was modified to pick up the idle task
from there.
* shared/misc/m68kidle.c: New file.
* wrapup/Makefile.am: PR217 required that the idle task be moved to
libcpu so it could be more acutely aware of the CPU model. This
file was modified to pick up the idle task from there.
* Makefile.am: Add preinstall-stamp.
* Makefile.am: Merge in former include/Makefile.am.
Take out unnecessary autoconf macros.
* mips-stub.c: Re-debugged a breakpoint problem, zbreak target
address was a char * which caused the target instruction to not
be fully copied, so the zbreak logic corrupted the original
instruction and didn't insert a valid break instruction.
* start/start16.S: Per PR259, added code to test for video present
before touching the adapter. Eric Norum <eric.norum@usask.ca>
tested this patch.
* rtems_servers/ftpd.c: Remove unused variable buf.
* pppd/md5.c: #include <string.h> to make gcc31 happy.
* rtems_telnetd/telnetd.c: #include <string.h> to make gcc31 happy.
* rtems_webserver/webmain.c: Remove unused variable dir, cp.
Posix-BSP-Hacks:
* configure.ac: Add AM_CONDITIONAL(LIBCHIP).
Pass RTEMS_HOST to make/bsp.mak
* Makefile.am: Pass RTEMS_HOST to make/bsp.mak.
* wrapup/Makefile.am: Apply AM_CONDITIONAL(LIBCHIP).
* pppd/utils.c: Include i960 in varargs conditional to avoid error.
* console/ps2_mouse.c: Include <string.h> (for abort/exit).
* bootloader/Makefile.am: Fix that crappy Makefile.am once again.
* configure.ac: Remove RTEMS_BSP_ALIAS.
Add RTEMS_CHECK_BSP_CACHE.
* mpc6xx/wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* shmdr/Makefile.am: Use .$(OBJEXT) instead of .o.
* shmsupp/Makefile.am: Use .$(OBJEXT) instead of .o.
* Makefile.am: Use .$(OBJEXT) instead of .o.
* PCI_bus/Makefile.am: Use .$(OBJEXT) instead of .o.
* tod/Makefile.am: Use .$(OBJEXT) instead of .o.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* nvram/Makefile.am: Use .$(OBJEXT) instead of .o.
* pci/Makefile.am: Use .$(OBJEXT) instead of .o.
* universe/Makefile.am: Use .$(OBJEXT) instead of .o.
* irq/Makefile.am: Use .$(OBJEXT) instead of .o.
* bootloader/Makefile.am: Use .$(OBJEXT) instead of .o.
* motorola/Makefile.am: Use .$(OBJEXT) instead of .o.
* openpic/Makefile.am: Use .$(OBJEXT) instead of .o.
* residual/Makefile.am: Use .$(OBJEXT) instead of .o.
* dlentry/Makefile.am: Use .$(OBJEXT) instead of .o.
* flashentry/Makefile.am: Use .$(OBJEXT) instead of .o.
* canbus/Makefile.am: Use .$(OBJEXT) instead of .o.
