Geoffroy Montel <g_montel@yahoo.com>.
sent an example bare bsp but we have not decided how to integrate it yet.
<qqi@world.std.com>). Unfortunately after merging these,
the pc386 will not boot using grub for for. It still does not
work using netboot for me. Here is his summary of changes:
rtems/c/src/lib/libbsp/i386/pc386/Makefile.in
Added support for new sub-directory
rtems/c/src/lib/libbsp/i386/pc386/bsp_specs
Made possible to build COFF image
rtems/c/src/lib/libbsp/i386/pc386/console/console.c
Added support for serial consoles, selectable by patching
binary image, added __assert(), use _IBMPC_inch_sleep()
instaed of _IMBPC_inch()
rtems/c/src/lib/libbsp/i386/pc386/console/inch.c
Added _IMBPC_inch_sleep()
rtems/c/src/lib/libbsp/i386/pc386/console/outch.c
Oops - just formatting
rtems/c/src/lib/libbsp/i386/pc386/include/Makefile.in
Added support for new files
rtems/c/src/lib/libbsp/i386/pc386/include/bsp.h
Added support for new features
rtems/c/src/lib/libbsp/i386/pc386/include/pc386uart.h
New file: definitions for serial ports
rtems/c/src/lib/libbsp/i386/pc386/include/pcibios.h
New file: definitions for PCI BIOS
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/Makefile.in
New file: makefile in new directory
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/i386-stub-glue.c
New file: i386-stub interface
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/i386-stub.c
New file: i386-stub itself
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/pc386uart.c
New file: serial ports
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/pcibios.c
New file: PCI BIOS support
rtems/c/src/lib/libbsp/i386/pc386/start/start.s
Commented out DEBUG_EARLY stuff, everything is working fine
rtems/c/src/lib/libbsp/i386/pc386/start/start16.s
Cleaned up
rtems/c/src/lib/libbsp/i386/pc386/startup/bspstart.c
Added call to console_resereve_resources
rtems/c/src/lib/libbsp/i386/pc386/startup/exit.c
rtems/c/src/lib/libbsp/i386/pc386/startup/ldsegs.s
Fixed typo in comments
rtems/c/src/lib/libbsp/i386/pc386/tools/Makefile.in
Changed to reflect cnages in code
rtems/c/src/lib/libbsp/i386/pc386/tools/bin2boot.c
Trivialized, problem - I do not know how to make patch
remove obsolete files - there are a lot of them there
rtems/c/src/lib/libbsp/i386/pc386/tools/binpatch.c
New file: utility to do binary patches
rtems/c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in
Added support for new directory
rtems/make/custom/pc386.cfg
Add COFF image building
all the targets:
breaking CXX support.
handling.
after minor changes.)
insecure about.
external packages.
may be broken).
disturb now.
--enable-* flags).
--enable-gcc28 are given.
mvme162.cfg-bug.
Here are his comments:
I removed all unnecessary stuff from start16.s - setting idt and
setting 16-bit stack using .code32 istructions.
between CPU32 and CPU32+ cores. Commentary follows:
Unfortunately c/src/exec/score/cpu/m68k/m68k.h incorrectly defines
M68K_HAS_MISALIGNED for the plain old CPU32 (it is correct for the CPU32+).
As a consequence, the recently-relocated m68k memcpy() may still attempt
misaligned memory accesses.
I suggest that until such time as egcs/gcc differentiates these cores
that we invent a new preprocessor symbol, RTEMS__mcpu32p__ for this
purpose, on the assumption that egcs may one day grow a -mcpu32+ option
which will define a __mcpu32p__ symbol (whether this option would also
define __mcpu32__ is yet to be resolved).
BSPs that have a CPU32+ (like gen68360) would for the time being define
RTEMS__mcpu32p__ using -D. The symbol is `RTEMS__mcpu32p__' because
symbols of the form __xxx__ should only be defined by the compiler
itself.
Note that the patch tests for RTEMS__mcpu32p__ *before* __mcpu32__, since
__mcpu32__ is still defined for the CPU32+. It does not change the
gen68360 BSP.
An aside:
Note that in egcs-1.0.3a, the option -m68332 is identical to -mcpu32,
except it defines __mc68332__ as well as __mcpu32__. This is only
for the sake of compatibility. The story with -m68302 is similar;
it defines __mc68302__ and __mc68000__. In my opinion these options
are depreciated and ought to be avoided in RTEMS.
clarity.
automatic handling of RTS/CTS. This only protects the on-chip buffers
and FIFOs -- not the termios queues as the RTS/CTS code in here did. It
may be necessary in the future to enable this automatic support.
Interrupt processing code added.
In some places, channel and duart base addresses were swapped.
needed to properly handle the interrupt mask register since it is
shared.
Added numerous constants to mc68681_p.h.
Changed spacing.
At this point the polled support is in but nothing else is right except the
structure.
Cleaned up spacing.
task to be deleted was created via the same API (i.e. were of the object
class created by this API). For example, a POSIX thread calling
the rtems_task_delete(SELF) directive would incorrectly update the RTEMS
object local pointer table.
Jennifer discovered this when moving tests implemented in C using the
Classic RTEMS API into a tree of Ada tests. The Ada tests were implicitly
using POSIX services. This lead to some unexpected behavior.
not a valid object class. This was discovered while looking for
a bug reported by Jennifer.
of seconds since 1988 from RTEMS and not adding in the 1970-1988 correction
factor. Plus removed checks for data/time set since POSIX does not permit
this call to fail. GNAT 3.12 depends on this.
important distinctions between CPU models which are not made by gcc.
These distinctions help give us a more optimized memcpy(). This is important
for message queues and KA9Q.
The array is too long and needs to be shortened.
