* configure.ac: Reflect changes to librdbg.
* src/powerpc/new_exception_processing/Makefile.am: Remove.
* src/powerpc/Makefile.am: Merge-in former
new_exception_processing/Makefile.am.
* src/m68k/any/Makefile.am: Remove.
* src/m68k/Makefile.am: Merge-in former any/Makefile.am.
* src/i386/any/Makefile.am: Remove.
* src/i386/Makefile.am: Merge-in former any/Makefile.am.
* src/Makefile.am: Cosmetics.
* include/Makefile.am: Cosmetics.
* Makefile.am: Cosmetics.
* automake/lib.am: Add project_libdir.
Add preinstallation dirstamp support.
* mptests/mp01/Makefile.am: Cosmetics.
* samples/Makefile.am: Cosmetics.
* samples/base_mp/Makefile.am: Cosmetics.
* samples/base_sp/Makefile.am: Cosmetics.
* samples/hello/Makefile.am: Cosmetics.
* samples/ticker/Makefile.am: Cosmetics.
* support/Makefile.am: Cosmetics.
* tmtests/tmoverhd/Makefile.am: Cosmetics.
* console/Makefile.am: Remove all: $(ARCH).
* irq/Makefile.am: Remove all: $(ARCH).
* startup/Makefile.am: Remove all: $(ARCH).
* wrapup/Makefile.am: Remove all: $(ARCH).
* console/Makefile.am: Remove all: $(ARCH)..
* i2c/Makefile.am: Remove all: $(ARCH)..
* nvram/Makefile.am: Remove all: $(ARCH)..
* startup/Makefile.am: Remove all: $(ARCH)..
* tod/Makefile.am: Remove all: $(ARCH)..
Remove bogus wildcard from CPU_PIECES..
* automake/compile.am: Remove $(ARCH):-rule.
* configure.ac: Cosmetics.
* clock/Makefile.am: Remove.
* console/Makefile.am: Remove.
* mbus/Makefile.am: Remove.
* timer/Makefile.am: Remove.
* Makefile.am: Merge-in former clock/Makefile.am, console/Makefile.am,
include/Makefile.am, mbus/Makefile.am, timer/Makefile.am.
* configure.ac: Remove shared/gdbstub/Makefile.
* Makefile.am: merge-in gdbstub/Makefile.am.
Add stray files bspspuriousinit.c, m68000spurious.c.
* gdbstub/Makefile.am: Remove.
* startup/Makefile.am: Remove S_FILES. Cosmetics.
* ide/Makefile.am: PGM = ide.rel.
* debug_ada/Makefile.am: Cosmetics.
* debug_c/Makefile.am: Cosmetics.
* dos_sup/Makefile.am: Cosmetics.
* network_ada/Makefile.am: Cosmetics.
* network_ada/adasockets/Makefile.am: Cosmetics.
* network_ada/listener/Makefile.am: Cosmetics.
* network_ada/tcprelay/Makefile.am: Cosmetics.
* ts_1325_ada/Makefile.am: Cosmetics.
* mbus/Makefile.am: Cosmetics.
* startup/Makefile.am: Remove S_FILES (Unused).
* vectors/Makefile.am: Cosmetics.
* bootloader/Makefile.am: Cosmetics.
* i2c/Makefile.am: Cosmetics.
* nvram/Makefile.am: Cosmetics.
* start/Makefile.am: Cosmetics.
* tod/Makefile.am: Cosmetics.
* gdbsci/Makefile.am: Cosmetics.
* scitab/Makefile.am: Cosmetics.
* trap34/Makefile.am: Cosmetics.
* hw_init/Makefile.am: Cosmetics.
* configure.ac: Remove lib/libbsp/shared/Makefile,
lib/libbsp/shmdr/Makefile.
* Makefile.am: Merge-in shared/Makefile.am, shmdr/Makefile.am.
* shared/Makefile.am: Remove.
* shmdir/Makefile.am: Remove.
* bsp.am: Add preinstallation dirstamp support.
Don't preinstall bsp_specs.dl.
* dlentry/Makefile.am: Cosmetics.
* flashentry/Makefile.am: Cosmetics.
* PCI_bus/Makefile.am: Cosmetics.
* shmsupp/Makefile.am: Cosmetics.
* network/Makefile.am: Cosmetics.
* pci/Makefile.am: Cosmetics.
* universe/Makefile.am: Cosmetics.
* irq/Makefile.am: Add preinstallation dirstamp support.
* vectors/Makefile.am: Add preinstallation dirstamp support.
* motorola/Makefile.am: Cosmetics.
* openpic/Makefile.am: Cosmetics.
* residual/Makefile.am: Cosmetics.
* vme/Makefile.am: Add preinstallation dirstamp support.
* ide/Makefile.am: Cosmetics.
* canbus/Makefile.am: Cosmetics.
* scv64/Makefile.am: Cosmetics.
* sonic/Makefile.am: Cosmetics.
* liblnk/Makefile.am: Cosmetics.
Add mvme/mvme16x_hw.h.
* fatal/Makefile.am: Cosmetics.
* consolex/Makefile.am: Add preinstallation dirstamp support.
* tools/Makefile.am: Cosmetics.
* spurious/Makefile.am: Cosmetics.
