* | Fixed typo. | Joel Sherrill | 1999-10-27 | 1 | -1/+1 |
* | New files from Ralf Corsepius <corsepiu@faw.uni-ulm.de> which | Joel Sherrill | 1999-10-27 | 3 | -0/+129 |
| | | | | | | | | are a dummy for linking programs together when you are primarily concerned with tricking another package into building. This may grow into something which could help link programs on the command line by having a default start sequence. | ||||
* | Added $(EXEEXT) in attempt to help Cygwin install process. | Joel Sherrill | 1999-10-27 | 1 | -2/+2 |
* | Updated. | Joel Sherrill | 1999-10-27 | 1 | -1/+3 |
* | Last cleanup to attempt to link. | Joel Sherrill | 1999-10-27 | 2 | -1/+3 |
* | rxgen960 now compiles -- may not link. | Joel Sherrill | 1999-10-27 | 13 | -52/+42 |
* | Added CVS Ids and a basic header. More header cleanup needed. | Joel Sherrill | 1999-10-27 | 42 | -9/+174 |
* | Removed systbl.S save_systbl.c. They were unnecessary. | Joel Sherrill | 1999-10-27 | 3 | -523/+2 |
* | Removed sctns.S. This file was obviously the output of the compiler. | Joel Sherrill | 1999-10-27 | 2 | -336/+1 |
* | Replaced Makefile.in's with modified copies of cvme961 to get | Joel Sherrill | 1999-10-27 | 9 | -152/+242 |
| | | | | autoconf/automake changes. | ||||
* | Moved timerisr.s to timerisr.S per GNU conventions. | Joel Sherrill | 1999-10-27 | 1 | -0/+0 |
* | Moved systbl.s to systbl.S per GNU conventions. | Joel Sherrill | 1999-10-27 | 1 | -0/+0 |
* | Moved sctns.s to sctns.S per GNU conventions. | Joel Sherrill | 1999-10-27 | 1 | -0/+0 |
* | Moved rxgen_romld.s to rxgen_romld.S per GNU conventions. | Joel Sherrill | 1999-10-27 | 1 | -0/+0 |
* | Moved ihandler.s to ihandler.S per GNU conventions. | Joel Sherrill | 1999-10-27 | 1 | -0/+0 |
* | Moved asmstub.s to asmstub.S per GNU conventions. | Joel Sherrill | 1999-10-27 | 1 | -0/+0 |
* | Moved asmfault.s to asmfault.S per GNU conventions. | Joel Sherrill | 1999-10-27 | 1 | -0/+0 |
* | The rxgen960 BSP and i960 RPM support was submitted by Mark Bronson | Joel Sherrill | 1999-10-27 | 77 | -44/+7151 |
| | | | | <mark@ramix.com> of RAMIX. | ||||
* | First attempt at icluding Eric Valette and Emmanuel Raguet. | Joel Sherrill | 1999-10-27 | 1 | -0/+6 |
* | Warnings removed. Still don't know what to do about the pragma | Joel Sherrill | 1999-10-27 | 3 | -10/+16 |
| | | | | pack warnings in uemf.h. | ||||
* | Patch from Emmanuel Raguet <raguet@crf.canon.fr> and Eric Valette | Joel Sherrill | 1999-10-27 | 36 | -3/+12134 |
| | | | | | | | | | | <valette@crf.canon.fr> to add a port of the GoAhead web server (httpd) to the RTEMS build tree. They have successfully used this BSP on i386/pc386 and PowerPC/mcp750. Mark and Joel spoke with Nick Berliner <nickb@goahead.com> on 26 Oct 1999 about this port and got verbal approval to include it in RTEMS distributions. | ||||
* | New files created by split of old imfs_handlers.c. | Joel Sherrill | 1999-10-26 | 9 | -0/+333 |
* | Added include of libio.h so this would compile when posix is disabled. | Joel Sherrill | 1999-10-26 | 3 | -0/+3 |
* | Split console_reserve_resources to separate file to reduce | Joel Sherrill | 1999-10-26 | 3 | -7/+42 |
| | | | | code size. | ||||
* | Added initial cut at miniIMFS which leaves out memfile and directory | Joel Sherrill | 1999-10-26 | 31 | -837/+679 |
| | | | | | readdir support. The next step is to add a mount table and configure either the miniIMFS or the full IMFS at the application level. | ||||
* | Patch from Gerwin Pfab <pb@schenk.isar.de> to leave dispatching | Joel Sherrill | 1999-10-26 | 1 | -3/+4 |
| | | | | | disabled on exit to ISR Thread dispatching. This allows a context switch to finish under high high interrupt rates. | ||||
* | Patch from Emmanuel Raguet <raguet@crf.canon.fr> to fix a small bug where | Joel Sherrill | 1999-10-26 | 1 | -1/+1 |
| | | | | the receive buffer size was 16 bytes too small. | ||||
* | Increased minimum stack size to ensure that there are no problems | Joel Sherrill | 1999-10-26 | 2 | -2/+2 |
| | | | | running the network stack. | ||||
* | Patch from Emmanuel Raguet <raguet@crf.canon.fr> to add missing file | Joel Sherrill | 1999-10-26 | 2 | -2/+2 |
| | | | | reference to the Makefile. | ||||
* | Removed all references to HOST_ARCH including the file gcc.cfg.in. All | Joel Sherrill | 1999-10-26 | 4 | -231/+0 |
| | | | | | host programs are now compiled with automake generated rules. This was done after discussions with Ralf Corsepius and Eric Norum. | ||||
* | idir=/opt/tmp/opt/rtems | Joel Sherrill | 1999-10-26 | 6 | -21/+12 |
| | | | | | | | | | | | | rdir=/opt/rtems cd $idir find . -type f | while read file do if [ ! -f ${file} ] ; then echo ${file} missing fi done | ||||
* | cat /tmp/j | while read f | Joel Sherrill | 1999-10-26 | 54 | -7836/+0 |
| | | | | | | do rpm -qi $f 2>&1 | grep -v "is not ins" done | ||||
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to move | Joel Sherrill | 1999-10-26 | 6 | -9/+8 |
| | | | | c/src/lib/libmisc to c/src/libmisc. | ||||
* | cat /tmp/j | while read f | Joel Sherrill | 1999-10-26 | 42 | -5982/+0 |
* | Patch rtems-rc-19991011-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-10-26 | 2 | -6/+5 |
| | | | | fixes a minor configuration bug. | ||||
* | New ideas on test incorporated. | Joel Sherrill | 1999-10-26 | 1 | -9/+17 |
* | Modifications from Erik Ivanenko <erik.ivanenko@utoronto.ca> to add | Joel Sherrill | 1999-10-26 | 2 | -5/+17 |
| | | | | | proper Multiboot signature to pc386 BSP. This enables Grub to recognize the image. | ||||
* | Patch from Erik Ivanenko <erik.ivanenko@utoronto.ca> to fix some | Joel Sherrill | 1999-10-26 | 1 | -28/+68 |
| | | | | reported bugs in the start code. | ||||
* | Patch from Eric Norum <eric@cls.usask.ca> to address the following problem | Joel Sherrill | 1999-10-25 | 2 | -2/+2 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | report from Philip A. Prindeville <philipp@zembu.com>: I was working on a device driver for a certain ethernet chipset that occassionally wraps in its buffer, and causes a resulting mbuf chain with only a few dozen bytes in the first mbuf of the chain. I wouldn't have thought this would be a problem, until I ran some stress tests that flooded the ethernet receiver with packets and started to get panics here: 250 251 if (m->m_pkthdr.len < sizeof(struct ip)) 252 goto tooshort; 253 254 #ifdef DIAGNOSTIC 255 if (m->m_len < sizeof(struct ip)) 256 panic("ipintr mbuf too short"); 257 #endif 258 259 if (m->m_len < sizeof (struct ip) && 260 (m = m_pullup(m, sizeof (struct ip))) == 0) { 261 ipstat.ips_toosmall++; 262 return; 263 } 264 ip = mtod(m, struct ip *); and the panic was at line 256. But if I #undef'd DIAGNOSTICS, then the m_pullup() at line 260 does the right thing and the packet ends up being processed just fine. So I started wondering, (a) why was the test checking for something that apparently wasn't a fatal condition but rather one that is subsequently recovered from a couple of lines later and (b) why panic as a diagnostic "aid" from a recoverable condition rather than just (say) log a message to the console? All of this seems overly severe for no reason that is readily apparent to me. | ||||
* | Patch from Charles-Antoine Gauthier <charles.gauthier@iit.nrc.ca> | Joel Sherrill | 1999-10-25 | 1 | -0/+8 |
| | | | | | to initialize the pthread cancellation fields. This is a patch to _POSIX_Threads_Create_extension that fixes the problem. | ||||
* | Added notes for new test. | Joel Sherrill | 1999-10-25 | 1 | -0/+19 |
* | tch from Eric Valette <valette@crf.canon.fr> and Emmanuel Raguet | Joel Sherrill | 1999-10-25 | 2 | -72/+72 |
| | | | | | <raguet@crf.canon.fr> to fix bugs and make the mcp750 boot RTEMS running the GoAhead web server. | ||||
* | Patch from Eric Valette <valette@crf.canon.fr> and Emmanuel Raguet | Joel Sherrill | 1999-10-25 | 3 | -21/+24 |
| | | | | <raguet@crf.canon.fr> to use a local variable. | ||||
* | Added code to correctly free any allocated space during the evaluation | Jennifer Averett | 1999-10-25 | 4 | -144/+148 |
| | | | | process. | ||||
* | Added sp26 which tests the rtems_task_is_suspended directive. | Joel Sherrill | 1999-10-25 | 8 | -1/+332 |
* | Modified to ease comparison of screen to target output. | Joel Sherrill | 1999-10-25 | 4 | -1092/+1092 |
* | Modified to reflect test change where reinitialize mutex test case was | Joel Sherrill | 1999-10-25 | 1 | -1/+1 |
| | | | | removed. | ||||
* | Removed reinitialize mutex test case to reflect earlier code change in | Joel Sherrill | 1999-10-25 | 1 | -1/+8 |
| | | | | the executive. | ||||
* | Changed leading spaces to periods to ease comparing test output. | Joel Sherrill | 1999-10-25 | 3 | -3/+3 |
* | Modified to produce correct output with new version of sis. | Joel Sherrill | 1999-10-25 | 1 | -1/+6 |
