index
4.11
4.8
4.9
5
master
RTEMS Kernel, file-systems, drivers, BSPs, samples, and testsuite.
devel@rtems.org
summary
refs
log
tree
commit
diff
stats
log msg
author
committer
range
path:
root
follow
Commit message (
Collapse
Author
Age
Lines
sh/sh7750/sci/sh4uart.c: ix misleading indentation warning
Joel Sherrill
2017-04-24
1
-1
+1
powerpc/new-exceptions/bspsupport/ppc_exc_print.c: Fix printf() format warnings
Joel Sherrill
2017-04-24
1
-2
+2
powerpc/mpc5xx/console-generic/console-generic.c: Use updated struct termios ↵
Joel Sherrill
2017-04-24
1
-2
+2
format
leon2/console/debugputs.c: Fix misleading indentation warning
Joel Sherrill
2017-04-24
1
-5
+5
virtex5/startup/dummy_console.c: Fix no prototype warning
Joel Sherrill
2017-04-24
1
-0
+1
virtex4/startup/dummy_console.c: Fix no prototype warning
Joel Sherrill
2017-04-24
1
-0
+1
mcf5235/console/console.c: Fix indentation and add braces
Joel Sherrill
2017-04-24
1
-5
+6
sparc64/shared/helenos/boot/sparc64/loader/main.c: Fix printf() format warning
Joel Sherrill
2017-04-24
1
-1
+1
sparc64/shared/clock/ckinit.c: Include <rtems/bspIo.h>
Joel Sherrill
2017-04-24
1
-0
+1
shared/drvmgr/leon2_amba_bus.c: Include <rtems/bspIo.h>
Joel Sherrill
2017-04-24
1
-0
+1
shared/startup/panic.c: Fix printf() format warnings
Joel Sherrill
2017-04-24
1
-2
+5
shared/pci/detect_raven_bridge.c: Fix printf() format warnings
Joel Sherrill
2017-04-24
1
-1
+1
shared/bootloader/mm.c: Fix printf() format warnings
Joel Sherrill
2017-04-24
1
-2
+4
shared/bootloader/misc.c: Fix printf() format warnings
Joel Sherrill
2017-04-24
1
-2
+3
beatnik/pci/gt_pci_init.c: Fix printf() format warnings
Joel Sherrill
2017-04-24
1
-1
+1
beatnik/startup/bspstart.c: Fix printf() format warnings
Joel Sherrill
2017-04-24
1
-1
+1
beatnik/marvell/discovery.c: Fix printf() format warnings
Joel Sherrill
2017-04-24
1
-2
+2
gensh2/console/config.c: Fix to reflect struct termios change
Joel Sherrill
2017-04-24
1
-4
+6
uC5282/startup/bspstart.c: Fix printf() format warnings
Joel Sherrill
2017-04-24
1
-6
+16
uC5282/console/console.c: Add braces and correct indentation to fix warnings
Joel Sherrill
2017-04-24
1
-5
+6
libbsp/shared/pci/pci_bus_count.c: Add include <rtems/bspIo.h>
Joel Sherrill
2017-04-24
1
-0
+1
gen68340/startup/dumpanic.c: Fix printf() format warnings
Joel Sherrill
2017-04-24
1
-10
+10
fb/fb.c: Include <rtems/inttypes.h> and use PRI constant to fix warning
Joel Sherrill
2017-04-23
1
-2
+7
amba/ahbstat.c: Correct printf() format
Joel Sherrill
2017-04-23
1
-1
+1
uart/apbuart.c: Correct printk() format
Joel Sherrill
2017-04-23
1
-1
+1
spw/grspw_router.c: Include <rtems/bspIo.h>
Joel Sherrill
2017-04-23
1
-0
+1
irq/genirq.c: Include <rtems/bspIo.h>
Joel Sherrill
2017-04-23
1
-0
+1
drvmgr/ambapp_bus.c: Include <rtems/bspIo.h>
Joel Sherrill
2017-04-23
1
-0
+1
amba/ahbstat.c: Include <rtems/bspIo.h>
Joel Sherrill
2017-04-23
1
-0
+1
elnk.c: Fix printf() format warnings
Joel Sherrill
2017-04-20
1
-3
+9
elnk.c: rtems_elnk_driver_attach() prototype added
Joel Sherrill
2017-04-20
1
-0
+3
elnk.c: Make elnk_txDaemon() static to fix warning
Joel Sherrill
2017-04-20
1
-1
+1
if_fxp.c: Add prototype of rtems_fxp_attach()
Joel Sherrill
2017-04-20
1
-0
+3
if_fxp.c: Remove unused variable
Joel Sherrill
2017-04-20
1
-1
+1
dec21140.c: Add prototype of dec21140_txDaemon()
Joel Sherrill
2017-04-20
1
-0
+2
dec21140.c: Fix printk() warnings
Joel Sherrill
2017-04-20
1
-3
+3
dec21140.c: Include <libcpu/page.h> to eliminate warnings
Joel Sherrill
2017-04-20
1
-0
+1
dec21140.c: Fix PRIxx formatter
Joel Sherrill
2017-04-20
1
-1
+1
m68k/mrm332/./sci.c: Use inttypes.h constants removes 6 warnings.
Cillian O'Donnell
2017-04-14
1
-6
+7
powerpc/haleakala/./mmu_405.c: Use inttypes.h constants removes 11 warnings.
Cillian O'Donnell
2017-04-14
1
-6
+14
powerpc/mvme550/./pci.c: Use inttypes.h constant to fix 1 warning.
Cillian O'Donnell
2017-04-14
1
-1
+2
virtex4/startup/bspstart.c: Use %p to fix 11 warnings.
Cillian O'Donnell
2017-04-14
1
-13
+14
virtex5/startup/bspstart.c: Use %p to fix 11 warnings.
Cillian O'Donnell
2017-04-14
1
-13
+14
libbsp/.../sparc64/loader/main.c: Use inttypes.h constants to remove 1 warning
Cillian O'Donnell
2017-04-14
1
-1
+2
libchip/network/dec21140.c: Use inttypes.h to fix 1 warning.
Cillian O'Donnell
2017-04-14
1
-1
+3
libbsp/powerpc/./pci/detect_raven_bridge.c: Use inttypes.h to fix 1 warning.
Cillian O'Donnell
2017-04-14
1
-1
+2
bootstrap: regenerate files after sort order fix
Gedare Bloom
2017-04-13
2
-4
+4
Updates #2965.
libcpu/../mpc5xx/.../vectors_init.c: Using inttype macros fixes 39 format ↵
Cillian O'Donnell
2017-04-07
1
-39
+41
warnings
lm32/shared/timer/timer.c: Include <rtems/bspIo.h>
Joel Sherrill
2017-04-05
1
-0
+1
lm32/shared/milkymist_video/video.c: Include <rtems/bspIo.h>
Joel Sherrill
2017-04-05
1
-0
+1
[next]
