* | bsps/stackalloc: Add initialization hook | Sebastian Huber | 2012-04-26 | 2 | -16/+23 |
* | bsp/mpc55xxevb: Enable stack allocator | Sebastian Huber | 2012-04-24 | 6 | -4/+10 |
* | bsps/stackalloc: Use stack section symbols | Sebastian Huber | 2012-04-24 | 5 | -55/+26 |
* | bsps/powerpc: Add no cache section | Sebastian Huber | 2012-04-24 | 14 | -89/+78 |
* | bsp/mpc55xxevb: Change early MMU settings | Sebastian Huber | 2012-04-24 | 3 | -17/+28 |
| | | | | | | Add internal SRAM sections with cache enabled to early MMU settings. The internal SRAM initialization will use the early MMU settings. This allows applications to use cache inhibited areas in the internal SRAM. | ||||
* | bsp/lpc24xx: Fix define name | Sebastian Huber | 2012-04-23 | 1 | -1/+1 |
* | bsps/arm: Make the Clock_isr() static again | Sebastian Huber | 2012-04-20 | 1 | -1/+1 |
* | bsps: Avoid rtems_irq_hdl_param type usage | Sebastian Huber | 2012-04-20 | 1 | -2/+1 |
| | | | | | Not every clock interrupt service routine is installed with this API. Remove also the prototype to allow drivers to make this routine static. | ||||
* | bsp/genmcf548x: Enable FPU in BSP startup code | Sebastian Huber | 2012-04-20 | 1 | -13/+5 |
* | bsp/genmcf548x: Fix BSP options | Sebastian Huber | 2012-04-20 | 1 | -3/+4 |
* | bsps/arm: Remove superfluous include | Sebastian Huber | 2012-04-20 | 1 | -1/+0 |
* | s3c24xx shared: Clock driver clean up and ISR Handler Prototype Correction. | Joel Sherrill | 2012-04-19 | 1 | -23/+11 |
* | pxa255 shared: Clock driver clean up and ISR Handler Prototype Correction. | Joel Sherrill | 2012-04-19 | 1 | -16/+8 |
* | mc9328mxl shared: Clock driver clean up and ISR Handler Prototype Correction. | Joel Sherrill | 2012-04-19 | 1 | -31/+18 |
* | lpc22xx shared: Clock driver clean up and ISR Handler Prototype Correction. | Joel Sherrill | 2012-04-19 | 1 | -58/+53 |
* | at91rm9200 shared: Clock driver clean up and ISR Handler Prototype Correction. | Joel Sherrill | 2012-04-19 | 1 | -23/+19 |
* | lpc shared: Clock driver clean up and ISR Handler Prototype Correction. | Joel Sherrill | 2012-04-19 | 1 | -1/+1 |
* | armv7m shared: Clock driver clean up and ISR Handler Prototype Correction. | Joel Sherrill | 2012-04-19 | 1 | -1/+2 |
* | nds: Clock driver clean up and ISR Handler Prototype Correction. | Joel Sherrill | 2012-04-19 | 1 | -15/+8 |
* | gba: Clock driver clean up and ISR Handler Prototype Correction. | Joel Sherrill | 2012-04-19 | 1 | -32/+25 |
* | edb7312: Clock driver clean up and ISR Handler Prototype Correction. | Joel Sherrill | 2012-04-19 | 1 | -19/+14 |
* | Clock Driver Shell - Correct PIC IRQ Prototype. | Joel Sherrill | 2012-04-19 | 1 | -2/+2 |
* | LEON3: rename console/debugputs.c to printk_support.c | Daniel Hellstrom | 2012-04-19 | 2 | -1/+1 |
* | LEON3: added TX-wait-complete and CR on NL support for UART | Daniel Hellstrom | 2012-04-19 | 2 | -6/+23 |
| | | | | Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> | ||||
* | LEON3: debugputs removed pointless isinit code, invoked only once | Daniel Hellstrom | 2012-04-19 | 1 | -34/+26 |
* | LEON3: debugputs added printk mem buffer when no UART present | Daniel Hellstrom | 2012-04-19 | 1 | -1/+13 |
* | LEON3: add console interrupt mode support | Daniel Hellstrom | 2012-04-19 | 2 | -23/+153 |
| | | | | | | | | | The comment in configure.ac is probably inherited from the LEON2 BSP. The LEON3 console driver implements a "flush" mechanism on console_close() in order to solve the problem described with sis/LEON2. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> | ||||
* | LEON3: add console attributes such as parity and baudrate | Daniel Hellstrom | 2012-04-19 | 1 | -3/+68 |
* | LEON3: console, lower bus utilization waiting for UART TX ready | Daniel Hellstrom | 2012-04-19 | 1 | -3/+7 |
* | LEON: updated drivers to use new AMBAPP Layer | Daniel Hellstrom | 2012-04-17 | 31 | -259/+266 |
| | | | | | | | The drivers are updated to use the new AMBA layer, however the backwards-compatibility interface (ambapp_old) is used. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> | ||||
* | LEON3: Network initialization code updated to new AMBAPP layer | Daniel Hellstrom | 2012-04-17 | 3 | -41/+50 |
| | | | | | | | Updated SMC91111, GRETH and open_eth driver registration code to use new AMBAPP Layer. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> | ||||
* | LEON3: updated console driver for new AMBAPP layer | Daniel Hellstrom | 2012-04-17 | 7 | -43/+75 |
* | LEON2: clock driver use new AMBAPP layer | Daniel Hellstrom | 2012-04-17 | 1 | -8/+8 |
* | LEON: updated AMBA PnP API | Daniel Hellstrom | 2012-04-17 | 19 | -634/+1839 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | The old layer had some limitations/problems for multiple AHB buses since the data structure containing all AMBA devices were allocated before scanning. The new layer create devices as they are found and memory is allocated using malloc() or bsp_early_malloc() during booting. The old 8 functions for finding a specific AHB-Slave or APB-Slave device has been replaced with one function, ambapp_for_each(), which iterates over all devices matching the specified search options and calls a user provided function. The new way lowers the footprint and makes searching more flexible. The frequency information is now supported, if the frequency of one device is reported by the user. More AHB-to-AHB bridges are supported. The API has been split into several parts in order to lower the footprint. The API also introduces the AMBAPP CORE concept, where one ambapp_core can be created from one AHB Master, AHB Slave and one APB Slave, at least one device is required for creating a core. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> | ||||
* | no_cpu: replace no_cpu_isr with rtems_isr | Gedare Bloom | 2012-04-16 | 2 | -3/+3 |
* | lm32: use shared setvec.c | Gedare Bloom | 2012-04-16 | 2 | -44/+1 |
* | m68k: use shared setvec.c | Gedare Bloom | 2012-04-16 | 23 | -60/+23 |
* | lm32: replace lm32_isr with rtems_isr | Gedare Bloom | 2012-04-16 | 3 | -7/+3 |
* | m68k: replace m68k_isr with rtems_isr | Gedare Bloom | 2012-04-16 | 35 | -63/+57 |
* | bsp/stm32f4: API changes | Sebastian Huber | 2012-04-15 | 9 | -83/+174 |
* | bsp/stm32f4: Add IO and RCC | Sebastian Huber | 2012-04-12 | 9 | -55/+487 |
* | PR2052: LEON3: fix open_eth interrupt initialization bug | Daniel Hellstrom | 2012-04-10 | 1 | -4/+4 |
| | | | | | | | Fixed a bug where the vector number is used to clean and unmask the IRQ at the IRQ controller, the irq number must be used. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> | ||||
* | bsp/stm32f4: New BSP | Sebastian Huber | 2012-04-07 | 17 | -0/+1085 |
* | bsps/arm: Add BSP_ARMV7M_SYSTICK_PRIORITY | Sebastian Huber | 2012-04-07 | 3 | -5/+6 |
* | bsps/arm: Add BSP_ARMV7M_IRQ_PRIORITY_DEFAULT | Sebastian Huber | 2012-04-07 | 3 | -2/+6 |
* | bsps: Update due to API changes | Sebastian Huber | 2012-04-07 | 2 | -7/+7 |
* | GRETH: use shared-irq service instead of BSP specific set_vec() | Daniel Hellstrom | 2012-04-06 | 3 | -28/+17 |
| | | | | | | | | | | The ISR code is updated to use argument instead of global greth structure, now that the greth private is available in the ISR. The shared-irq routines will unmask the IRQ, so the forced LEON3 BSP unmask/clear IRQ is removed. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> | ||||
* | SMC91111: updated to use shared IRQ service | Daniel Hellstrom | 2012-04-06 | 4 | -20/+15 |
* | LEON3 - Fix spacing | Joel Sherrill | 2012-04-06 | 2 | -2/+2 |
* | LEON3: added IRQAMP support | Daniel Hellstrom | 2012-04-06 | 2 | -3/+18 |
