* libchip/serial/serial.h: Declare Console_Port_Minor.
* shared/console/conscfg.c: Whitespace and style fixes.
* shared/console/conscfg.c: Give console port a name.
* ChangeLog: Fix ChangeLog with name and email address
* shared/score/interrupt.S: Pass ISR correct pointer to interrupt frame
PR 1945/cpukit
* libchip/i2c/spi-memdrv.c: Replace rtems_off64_t with off_t.
PR 1945/cpukit
* umon/tfsDriver.c: Replace rtems_off64_t with off_t.
* ChangeLog, Makefile.am: Add bsp_reset() stub.
PR 1944/misc
* libchip/serial/mc68681.c: Remove #if 0.
* shared/can/occan.c: Comment out unused var "tmp".
* network/network.c: Remove unused var "dptr".
* libchip/serial/ns16550.c (ns16550_init):
Remove unused var "ucTrash".
* libchip/network/smc91111.c (lan91cxx_recv):
Define var "lp" conditionally (Avoid warning).
* page.c: Remove unused var "dirCount".
* shared/comm/uart.c (uartError): Remove unused var "uartStatus".
* libchip/network/dec21140.c (dec21140_rxDaemon):
Remove unused var "tbase".
* libchip/rtc/mc146818a.c (mc146818a_initialize):
Remove unused var "getReg".
* libchip/rtc/mc146818a.c (mc146818a_set_time):
* console/console.c (ISS_output_char): Add return type.
* timer/timer.c: Remove unused vars "old_ie".
* libchip/display/disp_hcms29xx.c: Remove ARRAY_COUNT (unused).
* console.c: Include <rtems/error.h> for rtems_panic().
PR 1940/misc:
* libchip/serial/ns16550.c: Reflect changes to console-driver.
PR 1926/bsps
* timer/timer.c: New file.
* Makefile.am: Reflect change above.
* libchip/network/smc91111.c: Use PRIxPTR to print pointers.
* console.c: RTEMS_DEBUG is a define, not a variable.
PR 1917/bsps
* libchip/serial/mc68681.c, libchip/serial/ns16550.c,
libchip/serial/serial.h, libchip/serial/z85c30.c: Modifications to
add dynamic tables for libchip serial drivers.
PR 1917/bsps
* mongoosev/duart/mg5uart.c: Modifications to add dynamic tables for
PR 1917/bsps
* sh7045/sci/sci_termios.c: Modifications to add dynamic tables for
PR 1917/bsps
* Makefile.am, console/conscfg.c: Modifications to add dynamic tables
PR 1917/bsps
* Makefile.am, console/consolelite.c: Modifications to add dynamic
PR 1917/bsps
* Makefile.am, preinstall.am, console/config.c, console/mc68360_scc.c,
console/ns16550cfg.c, console/printk_support.c: Modifications to add
PR 1917/bsps
* Makefile.am, console/console-config.c, startup/bspstart.c:
Modifications to add dynamic tables for libchip serial drivers.
PR 1917/bsps
* Makefile.am, console/console-config.c, console/uart-bridge-master.c,
console/uart-bridge-slave.c, startup/bspstart.c: Modifications to add
PR 1917/bsps
* console/config.c: Modifications to add dynamic tables for libchip
serial drivers.
PR 1917/bsps
* Makefile.am, console/erc32_console.c: Modifications to add dynamic
PR 1917/bsps
* shared/console/conscfg.c: Modifications to add dynamic tables for
PR 1917/bsps
* Makefile.am: Modifications to add dynamic tables for libchip serial
drivers.
PR 1917/bsps
* Makefile.am, console/uarts.c: Modifications to add dynamic tables for
PR 1917/bsps
* Makefile.am, console/uart.c: Modifications to add dynamic tables for
PR 1917/bsps
* Makefile.am, console/console-config.c: Modifications to add dynamic
PR 1917/bsps
* Makefile.am, console/console-config.c, console/hsu.c: Modifications
PR 1917/bsps
* console.c: Modifications to add dynamic tables for libchip serial
drivers.
* console_control.c, console_private.h, console_read.c,
console_select.c, console_write.c: New files.
* ne2000/ne2000.c: Remove unused var "stat".
* libchip/rtc/icm7170.c (icm7170_get_time): Remove unused var setReg.
* libchip/rtc/icm7170.c (icm7170_set_time): Remove unused var getReg.
* include/start-config.h, make/custom/lpc24xx_plx800_rom_int.cfg,
startup/linkcmds.lpc24xx_plx800_rom_int,
startup/start-config-emc-dynamic.c, startup/start-config-emc-static.c,
startup/start-config-pinsel.c: New files.
* Makefile.am, configure.ac, preinstall.am: Reflect changes above.
* startup/bspstarthooks.c: Use configuration tables for EMC
initialization.
* shared/comm/uart.c: Remove unused var "tmp".
* libchip/network/smc91111.c: Eliminate unused var "success".
* libchip/serial/mc68681.c: Eliminate unused var "success".
* libchip/serial/z85c30.c: Eliminate unused var "dummy".
