* | Moved to network demos | Joel Sherrill | 1998-08-01 | 1 | -8/+1 | |
* | Patch from David Fiddes <D.J.Fiddes@hw.ac.uk> to make ASFLAGS include the | Joel Sherrill | 1998-08-01 | 1 | -1/+1 | |
| | | | | CPU_ASFLAGS. | |||||
* | Patch from David Fiddes <D.J.Fiddes@hw.ac.uk> to not use this file for | Joel Sherrill | 1998-08-01 | 1 | -0/+3 | |
| | | | | ColdFires. It is just too wrong to fix. | |||||
* | Merged patch from David Fiddes <D.J.Fiddes@hw.ac.uk> to add ColdFire | Joel Sherrill | 1998-08-01 | 2 | -1/+15 | |
| | | | | specific register macros and correct code in rtems.s. | |||||
* | Added Rod Barman (rodb@cs.ubc.ca) in credits for ColdFire. | Joel Sherrill | 1998-08-01 | 1 | -1/+2 | |
* | Changed name of network driver. | Joel Sherrill | 1998-07-30 | 1 | -1/+1 | |
* | Added temporary include of dmv170.h | Joel Sherrill | 1998-07-30 | 1 | -0/+6 | |
* | Added SONIC configuration information. | Joel Sherrill | 1998-07-30 | 1 | -0/+9 | |
* | Added a hint to continue writing this. | Joel Sherrill | 1998-07-30 | 1 | -0/+2 | |
* | Updated. | Joel Sherrill | 1998-07-30 | 2 | -2/+2 | |
* | Added getRealTime() and setRealTime(). | Joel Sherrill | 1998-07-30 | 2 | -18/+99 | |
| | | | | Reimplemented checkRealTime() to use RTEMS internal routine. | |||||
* | Changed clock rate from 32 Khz to 1 Mhz. | Joel Sherrill | 1998-07-30 | 2 | -6/+6 | |
| | | | | Registers are at 8 byte boundaries NOT 4 as initially configured. | |||||
* | Changed comment to be more polite. | Joel Sherrill | 1998-07-30 | 1 | -1/+1 | |
* | Updating to make more readable. | Joel Sherrill | 1998-07-30 | 1 | -28/+8 | |
* | New files. | Joel Sherrill | 1998-07-30 | 8 | -0/+46 | |
* | Spacing corrected. | Joel Sherrill | 1998-07-30 | 1 | -1/+0 | |
* | New file based on email from DY-4 technical support. | Joel Sherrill | 1998-07-30 | 1 | -0/+62 | |
* | Fixed spacing. | Joel Sherrill | 1998-07-30 | 1 | -1/+0 | |
* | Updated to accurately reflect the dmv177. | Joel Sherrill | 1998-07-30 | 1 | -22/+21 | |
* | Patch from Eric Valette <valette@crf.canon.fr>: | Joel Sherrill | 1998-07-30 | 1 | -1/+1 | |
| | | | | | | Now that Joel told me how to compile outside the tree, I have found a few more bugs. Here is a small patch to fix them. | |||||
* | Made chain.h shared | Joel Sherrill | 1998-07-30 | 2 | -355/+1 | |
* | Made tod.h shared | Joel Sherrill | 1998-07-30 | 2 | -1/+2 | |
* | New file. Based on merged of shared libchip style console.c and the | Joel Sherrill | 1998-07-29 | 1 | -0/+187 | |
| | | | | existing TOD interface. | |||||
* | Cleaned up comment. | Joel Sherrill | 1998-07-29 | 1 | -4/+5 | |
| | | | | Modified open so it uses a local variable rather than modifying a parameter. | |||||
* | Added reference to shared TOD driver. | Joel Sherrill | 1998-07-29 | 1 | -1/+1 | |
* | Added prototype for default register access routines to header files. | Joel Sherrill | 1998-07-29 | 8 | -8/+200 | |
| | | | | | Corrected prototypes to reflect unsigned32 values being passed around instead of unsigned8's. | |||||
* | Corrected to reflect the ICM7170 which is really on this board. | Joel Sherrill | 1998-07-29 | 2 | -16/+12 | |
* | Added config.c and deleted tod.c. | Joel Sherrill | 1998-07-29 | 1 | -1/+1 | |
* | Simplified RTC base address. | Joel Sherrill | 1998-07-29 | 1 | -2/+1 | |
* | Changed cast on RTC address and added base address of RTC fields as opposed | Joel Sherrill | 1998-07-29 | 1 | -1/+2 | |
| | | | | to entire RTC with NVRAM included. | |||||
* | Deleted probe routine as device specific. | Joel Sherrill | 1998-07-29 | 2 | -12/+6 | |
| | | | | Renamed port table. | |||||
* | Added function table. | Joel Sherrill | 1998-07-29 | 2 | -0/+12 | |
* | Renamed control register constants. | Joel Sherrill | 1998-07-29 | 2 | -22/+48 | |
| | | | | | | Set time->ticks to 0. Added function table. | |||||
* | New files for Harris Semiconductor ICM7170. | Joel Sherrill | 1998-07-29 | 4 | -0/+456 | |
* | New files. | Joel Sherrill | 1998-07-29 | 22 | -0/+806 | |
* | Added new files. | Joel Sherrill | 1998-07-29 | 2 | -4/+10 | |
* | First cut at configuration table for libchip RTC. At this point, we | Joel Sherrill | 1998-07-28 | 4 | -275/+117 | |
| | | | | are pretending that the DMV177 has an M48T08. | |||||
* | First cut implementation of real-time clock support in libchip. This | Joel Sherrill | 1998-07-28 | 10 | -12/+442 | |
| | | | | | version compiles cleanly but there is not a BSP with a configuration table to utilize it. | |||||
* | Corrected spacing. | Joel Sherrill | 1998-07-28 | 4 | -28/+12 | |
* | Added rtc directory. | Joel Sherrill | 1998-07-28 | 5 | -1/+277 | |
* | Added missing parts of patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1998-07-28 | 1 | -4/+16 | |
* | Closed window thanks to patch from Eric Norum. | Joel Sherrill | 1998-07-28 | 2 | -10/+6 | |
* | New file -- copied from dmv177 but same as ppcn_60x. | Joel Sherrill | 1998-07-25 | 1 | -0/+290 | |
* | Added comments and corrected spacing. | Joel Sherrill | 1998-07-25 | 4 | -42/+56 | |
* | Corrected spacing and added headers. | Joel Sherrill | 1998-07-25 | 2 | -34/+56 | |
* | Added ns16550_set_attributes. | Joel Sherrill | 1998-07-25 | 4 | -8/+210 | |
* | Corrected spacing and added a comment. | Joel Sherrill | 1998-07-25 | 2 | -6/+10 | |
* | Updated to reflect set attributes. | Joel Sherrill | 1998-07-25 | 2 | -4/+18 | |
* | Rewrote NS16550 TX interrupt processing to use termios for the buffer | Joel Sherrill | 1998-07-25 | 6 | -250/+168 | |
| | | | | | and manage the interrupt sources like the other drivers. This let use remove the ns16550_flush() routine. | |||||
* | Removed TX ring buffer. | Joel Sherrill | 1998-07-25 | 2 | -4/+0 | |
