* include/confdefs.h, include/rtems/config.h, include/rtems/io.h,
optman/no-io.c, src/exinit.c, src/io.c: Added a device driver
register/unregister interface to allow device drivers to be
installed and removed at runtime. This means you do not need devices
present in the device table when you build.
* include/rtems++/Makefile.am: Remove.
* include/zilog/Makefile.am: Remove.
* include/motorola/Makefile.am: Remove.
* include/sys/Makefile.am: Remove.
* startup/Makefile.am: Remove AC_CFLAGS, HZ.
* configure.ac: Use AC_CONFIG_SUBDIRS for posix and itron.
Reflect changes to configuration of rtems, score and sapi subdirs.
* include/rtems/rtems/Makefile.am: Remove.
* inline/rtems/rtems/Makefile.am: Remove.
* macros/rtems/rtems/Makefile.am: Remove.
* macros: Handle subdirs, require automake-1.5.
* macros/rtems/score/Makefile.am: Remove.
* macros/Makefile.am: Handle subdirs, require automake-1.5.
* inline/rtems/score/Makefile.am: Remove.
* include/rtems/posix/Makefile.am: Remove.
* include/Makefile.am: Handle subdirs.
* inline/rtems/posix/Makefile.am: Remove.
* inline/Makefile.am: Handle subdirs.
* macros/rtems/posix/Makefile.am: Remove.
* macros/Makefile.am: Handle subdirs.
* include/itronsys/Makefile.am: Remove.
* include/rtems/itron/Makefile.am: Remove.
* inline/rtems/itron/Makefile.am: Remove.
* macros/rtems/itron/Makefile.am: Remove.
* include/Makefile.am: handle subdirs.
* inline/Makefile.am: handle subdirs.
* macros/Makefile.am: handle subdirs.
* console/.cvsignore: New file.
* include/sh4uart.h: move to include/sh/sh4uart.h.
* include/ispsh7750.h: move to include/rtems/score/ispsh7750.h.
* include/iosh7750.h: move include/rtems/score/iosh7750.h.
* include/sh7750_regs.h: move to include/rtems/score/sh7750_regs.h.
* include/rtems/score/ipl.h: move to include/rtems/score/ipl.h.
* include/rtems/score/sh4_regs.h: Reintroduce from Alexandra
Kossovsky's original sources.
* include/Makefile.am: reflect changes above, remove EXTRA_DIST,
require automake 1.5.
* sci/Makefile.am: Disable compilation of console.c.
* sci/sh4uart.c: include <sh/sh4uart.h>, add SH7750_SCSMR_CHK_S,
remove SH4_CPU_HZ_Frequency;
* score/isph7750.c: Remove #if !defined(sh7750), include sh4_regs.h.
* configure.ac: Added support for START_HW_INIT.
* console/Makefile.am: Removed VPATH.
* include/Makefile.am: Added missing ramdisk.h to include_HEADERS.
* startup/linkcmds: Do not force output format to coff-sh.
* startup/linkcmds-le: Comment out force of output format and add
comment questioning need to have special linkcmds for little endian.
* wrapup/Makefile.am: Add ramdisk to list of BSP_PIECES.
* configure.ac: Add sh7750.
* acinclude.m4: Add gensh4 and simsh4.
* configure.ac: Remove AC_SUBST(CPU_CLOCK_RATE_HZ), add
START_HW_INIT-support macros, add console/Makefile.
* Makefile.am: Add console SUBDIR.
* hw_init/Makefile.am: Fix C_FILES, remove AM_CPPFLAGS/HZ.
* include/Makefile.am: Add bspopts.h.
* include/bsp.h: Comment out SH4_CPU_HZ_Frequency.
* startup/bspstart.c: Comment out SH4_CPU_HZ_Frequency.
* startup/linkcmds: Comment out OUTPUT_FORMAT for coff
compatibility.
* wrapup/Makefile.am: Add console to BSP_PIECES.
* console/Makefile.am: New.
* console/console.c: Moved from libcpu/sh/sh7750/sci/console.c.
* cpu.c: Fix #ifdefs, add missing #endif.
* start/start.S: Fixed typo.
* clock/p_clock.c, startup/bspstart.c: Fixed typo.
* include/chain.h: Fixed typo.
* console/inch.c: Fixed typo.
* startup/linkcmds: Fixed typo.
* comm/gdb_glue.c:
* debug_ada/init.c, network_ada/listener/init.c,
network_ada/tcprelay/init.c, ts_1325_ada/init.c: Fixed typo.
* console/console-io.c: Fixed typo.
* clock/ckinit.c, console/console.c, include/bsp.h, startup/bspstart.c,
startup/exit.c, startup/setvec.c, timer/timer.c, timer/timerisr.S:
Fixed typo.
* clock/clock.c, console/debugio.c, include/dmv170.h, startup/setvec.c,
startup/vmeintr.c: Fixed typo.
* clock/p_clock.c: Fixed typo.
* clock/p_clock.c, include/bsp.h, include/coverhd.h,
startup/bspstart.c, startup/bspstart.c.nocache, startup/setvec.c,
startup/start.S: Fixed typo.
* shmsupp/lock.c, shmsupp/mpisr.c: Fixed typo.
* clock/clock.c, console/console.c, console/debugio.c,
console/ns16550cfg.c, console/ns16550cfg.h, console/z85c30cfg.c,
console/z85c30cfg.h, include/bsp.h, startup/bspstart.c,
startup/genpvec.c, startup/rtems-ctor.cc, startup/setvec.c,
timer/timer.c: Fixed typo.
* PCI_bus/PCI.h, clock/clock.c, console/85c30.c, console/console.c,
console/consolebsp.h, console/consolereserveresources.c,
console/tbl85c30.c, include/bsp.h, include/coverhd.h, include/gen1.h,
include/gen2.h, startup/82378zb.c, startup/FPGA.c,
startup/bspstart.c, startup/genpvec.c, startup/setvec.c,
startup/vmeintr.c, timer/timer.c: Fixed typo.
* include/bsp.h, include/coverhd.h, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/linkcmds: Fixed typo.
* include/bsp.h, start/start.S, start/start.ram, start/start.rom,
startup/bspclean.c, startup/bspstart.c, startup/linkcmds,
startup/linkcmds.ram, startup/linkcmds.rom: Fixed typo.
* console.c, setvec.c: Fixed typo.
* console-polled.c, console.c: Fixed typo.
* clock/ckinit.c, console/console.c, include/bsp.h, include/leon.h,
startup/setvec.c, timer/timer.c: Fixed typo.
* mpc6xx/clock/c_clock.c, mpc6xx/clock/c_clock.h, mpc8xx/clock/clock.c,
mpc8xx/timer/timer.c, new_exception_processing/cpu.c,
new_exception_processing/cpu.h, new_exception_processing/cpu_asm.S,
old_exception_processing/cpu.c, old_exception_processing/cpu.h,
old_exception_processing/cpu_asm.S, old_exception_processing/rtems.S:
Fixed typo.
* rootfs/mkrootfs.c, rootfs/mkrootfs.h: Fixed typo.
* unlimited/init.c, unlimited/system.h, unlimited/test1.c,
unlimited/test2.c, unlimited/test3.c, unlimited/unlimited.doc:
Fixed typo.
* serial/z85c30.c: Fixed typo.
* clock/ckinit.c, delay/delay.c, include/iosh7032.h,
include/ispsh7032.h, include/sci.h, include/sh7_pfc.h,
include/sh7_sci.h, sci/sci.c, score/cpu_asm.c, score/ispsh7032.c,
* clock/ckinit.c, include/iosh7045.h, include/ispsh7045.h,
include/sci.h, include/sh7_pfc.h, include/sh7_sci.h, sci/sci.c,
score/cpu_asm.c, score/ispsh7045.c, timer/timer.c: Fixed typo.
* clock/ckinit.c, include/iosh7750.h, include/ipl.h,
include/ispsh7750.h, sci/console.c, sci/sh4uart.c, score/cpu_asm.c,
score/ispsh7750.c, timer/timer.c: Fixed typo.
* console/console.c: Fixed typo.
* shared/ppctypes.h: Fixed typo.
* include/rtems/directives.h: Fixed typo.
