PR 853/filesystem
* libchip/ide/ata.c, libchip/ide/ide_controller.c: The ata driver
should be modified to support the new exception scheme and to use the
handle parameter.
* at91rm9200/clock/clock.c: The clock tick is not very precise on
at91rm9200. The attached patch improves the situation by:
(1) Not reloading the "period interval timer" register in the
interrupt handler since this is done automatically.
(2) Use integer rounding in the calculation of the "period interval
timer" register value to get as close as posible to the
CONFIGURE_MICROSECONDS_PER_TICK value.
* shared/startup/panic.c, shared/startup/probeMemEnd.c:
added code for BSPs to use: panic using printk() to display
reason. probeMemEnd() to determine memory size by probing.
* src/rtemsStatusCode.cc: Fix warnings.
* clock/clockdrv.c: Correct path to clockdrv_shell.c
* startup/linkcmds: Add sections required by newer gcc versions.
* startup/linkcmds, startup/linkcmds-le, startup/linkcmds-le.coff: Add
* startup/linkcmds, startup/linkcmds.rom, startup/linkcmds.rom2ram: Add
* startup/linkcmds, startup/linkcmds.ram, startup/linkcmds.rom: Add
* shared/startup/linkcmds: Add sections required by newer gcc versions.
* startup/linkcmds, startup/linkcmds.dl: Add sections required by newer
gcc versions.
* startup/linkcmds, startup/linkcmds.pm520: Add sections required by
newer gcc versions.
* startup/linkcmds.dl: Add sections required by newer gcc versions.
* startup/linkcmds, startup/linkcmds_ROM: Add sections required by
newer gcc versions.
* startup/linkcmds, startup/linkcmdsflash, startup/linkcmdsram: Add
* startup/linkcmds, startup/linkcmds.flash: Add sections required by
newer gcc versions.
* startup/linkcmds, startup/linkcmds.bootp, startup/linkcmds.prom: Add
* startup/linkcmds: Add sections to fix C++ linking errors.
* configure.ac, console/console.c: Add USE_COM1_AS_CONSOLE BSP option.
This makes it easy to build the pc386 BSP in a configuration that
corresponds to qemu with COM1 redirected to stdio.
* gnatinstallhandler.c: Rename since old name is now used
by GNAT source.
by GNAT source.
* vmeUniverse/vmeTsi148.c, vmeUniverse/vmeUniverse.c,
vmeUniverse/vmeUniverse.h, vmeUniverse/vme_amd_defs.h:
Added 2F address modifier for VME64 CSR access.
* runtest: Add pvr setting.
* mpc6xx/mmu/pte121.c: consistency check now warns instead
of reporting an error when coming across a non 1:1 VSID;
fix: triv121IsRangeMapped() needs to convert segment offset
into a page index if the vsid argument is non-special.
* psim: Enhance to add limit on how long a single test is allowed to
execute. This can be used to significantly enhance the reliability of
long batch test runs.
* wrapup/Makefile.am: Add preinstall.am.
* libchip/Makefile.am: Build libchip/network/smc91111.
* libchip/network/smc91111.c, libchip/network/smc91111config.h:
Eliminate cyg_int* crap.
