* | added mvme147s from Dominique le Campion | Joel Sherrill | 1996-09-18 | 1 | -1/+2 |
* | new file submitted by Dominique le Campion. | Joel Sherrill | 1996-09-18 | 10 | -0/+1243 |
* | extended Task_id and Task_name arrays to avoid indexing past end of array. | Joel Sherrill | 1996-09-17 | 1 | -2/+2 |
* | Reversed logic in conditional to correctly distinguish between | Joel Sherrill | 1996-09-17 | 1 | -2/+2 |
| | | | | FIFO and priority disciplines. | ||||
* | added routine _POSIX_Timespec_subtract | Joel Sherrill | 1996-09-17 | 1 | -0/+31 |
* | Added code to insure that the post switch extension was executed and | Joel Sherrill | 1996-09-17 | 1 | -0/+5 |
| | | | | | | to made signals sent to a particular thread from an ISR operated correctly. This behavior was required by the exception detection/reporting code in the gnat runtime. | ||||
* | Corrected implementation of timed wait on condition variables. First | Joel Sherrill | 1996-09-17 | 1 | -29/+52 |
| | | | | | | | | the timeout is given as a wall-time not an interval as was previously implemented. Second, the interpretation of ETIMEDOUT behavior was incorrect as all possible error cases needed to be checked before this error was returned. This caused problems when the wall-time specified was in the past. | ||||
* | added prototype for _POSIX_Timespec_subtract | Joel Sherrill | 1996-09-17 | 2 | -0/+22 |
* | Fixed test to match change to pthread_cond_timedwait which now takes a wall | Mark Johannes | 1996-09-12 | 1 | -26/+32 |
| | | | | | | | time. Commented out calls to pthread_cond_wait and pthread_cond_timedwait without the mutex locked before calling. | ||||
* | added $Id$ to file headers | Joel Sherrill | 1996-09-11 | 19 | -14/+21 |
| | | | | cpu.h: added prototype for _CPU_ISR_Get_level() | ||||
* | added $ string to file header | Joel Sherrill | 1996-09-11 | 13 | -4/+13 |
* | added $Id$ string to file header | Joel Sherrill | 1996-09-11 | 18 | -16/+50 |
* | new files | Joel Sherrill | 1996-09-11 | 4 | -0/+812 |
* | added definition of EXT_INT5 | Joel Sherrill | 1996-09-08 | 2 | -2/+2 |
* | added mips64orion entries for SHM_LOCK_VALUE and SHM_UNLOCK_VALUE | Joel Sherrill | 1996-09-08 | 3 | -0/+15 |
* | idtmem.S: changed reference to include files to correct location | Joel Sherrill | 1996-09-08 | 4 | -12/+8 |
| | | | | | | iface.c: commented out routines now provided by rtems setvec.c: remov | ||||
* | changed reference to include files to correct location | Joel Sherrill | 1996-09-08 | 2 | -4/+4 |
* | moved PTHREAD_MINIMUM_STACK_SIZE from pthread.c to pthread.h so it would be | Joel Sherrill | 1996-09-08 | 1 | -1/+0 |
| | | | | visible to other files. | ||||
* | Ada task stack size minimize is twice that for regular pthreads. | Joel Sherrill | 1996-09-08 | 1 | -2/+2 |
* | moved PTHREAD_MINIMUM_STACK_SIZE from pthread.c to here so it would be | Joel Sherrill | 1996-09-08 | 2 | -0/+4 |
* | changed to reflect status of R4600 work. | Joel Sherrill | 1996-09-06 | 1 | -1/+1 |
* | removed need for exceptbdr.h file | Joel Sherrill | 1996-09-06 | 2 | -2/+2 |
* | new file for MIPS port by Craig Lebakken (lebakken@minn.net) and | Joel Sherrill | 1996-09-06 | 56 | -0/+11603 |
| | | | | Derrick Ostertag (ostertag@transition.com). | ||||
* | added MIPS port by Craig Lebakken (lebakken@minn.net) and Derrick Ostertag | Joel Sherrill | 1996-09-06 | 1 | -0/+5 |
* | modified test to take into account change in default value of | Joel Sherrill | 1996-09-06 | 1 | -0/+5 |
| | | | | | inheritsched pthread attribute from implicit to explicit scheduling parameters. | ||||
* | changed _TOD_Is_set from a function to a boolean variable | Joel Sherrill | 1996-09-06 | 13 | -57/+31 |
* | default thread attributes: default value for inheritsched changed from | Joel Sherrill | 1996-09-05 | 1 | -5/+25 |
| | | | | | | | | | | | | explicit to inherit scheduler to be consistent with FSU pthreads for gnat. _POSIX_Threads_Create_extension: now inherit signal blocked mask from creator if the new thread is a posix thread. _POSIX_Threads_Initialize_user_threads: make sure posix initialization threads start with a useful priority. If they inherit the priority of the creating thread, they will end up at the same priority as the idle thread. Since the idle thread does not yield, they will not run. | ||||
* | pthread_mutex_setprioceiling: fixed bug where returned priority was | Joel Sherrill | 1996-09-05 | 1 | -1/+3 |
| | | | | not converted from core priority to posix priority. | ||||
* | added printf of status when not successful | Joel Sherrill | 1996-09-05 | 1 | -1/+3 |
* | nanosleep: negative value for tv_sec is no longer an error. It now | Joel Sherrill | 1996-09-05 | 1 | -4/+10 |
| | | | | is changed into being a 0 delay. | ||||
* | nanosleep no longer consider a negative value of tv_sec to be an error. | Joel Sherrill | 1996-09-05 | 1 | -6/+7 |
| | | | | Instead it is an indication of a request for a small delay. | ||||
* | new file to support GNU Ada. | Joel Sherrill | 1996-08-29 | 1 | -0/+28 |
| | | | | | currently the only routine in this file simply returns the minimum stack size for each thread. | ||||
* | fixed typo .. changed == to != | Joel Sherrill | 1996-08-27 | 1 | -1/+1 |
* | check that we were passed a valid mutex and ignore errors from the | Joel Sherrill | 1996-08-27 | 1 | -0/+8 |
| | | | | | later pthread_mutex_lock. This makes our behavior more compatible with that of FSU pthreads. | ||||
* | Changed all EFAULTS to EINVALs | Mark Johannes | 1996-08-23 | 1 | -14/+20 |
* | filled in screen | Mark Johannes | 1996-08-23 | 1 | -0/+11 |
* | Filled in screen | Mark Johannes | 1996-08-23 | 2 | -0/+78 |
* | Filled in the screen | Mark Johannes | 1996-08-23 | 9 | -0/+479 |
* | Added build_time statement to provide a tm for the test | Mark Johannes | 1996-08-23 | 1 | -2/+4 |
* | Changed test 5 to test 10 at bottom | Mark Johannes | 1996-08-23 | 1 | -1/+1 |
* | pthread_create: changed EINVAL for no more threads back to EAGAIN | Mark Johannes | 1996-08-23 | 1 | -20/+21 |
* | Commented out the EINVAL for mutex not acquired befor cond_wait call | Mark Johannes | 1996-08-22 | 1 | -4/+9 |
* | updated to support ENOTSUP | Mark Johannes | 1996-08-21 | 1 | -10/+10 |
* | Added Einval case for mutex not initialized | Mark Johannes | 1996-08-20 | 1 | -0/+10 |
* | Changed all EFAULTs to EINVALs | Mark Johannes | 1996-08-19 | 1 | -7/+14 |
* | pthread_mutex_init: added error messages for NULL mutex and EBUSY | Mark Johannes | 1996-08-19 | 1 | -6/+22 |
* | updates from Tony Bennett (tbennett@divnc.com) | Joel Sherrill | 1996-08-15 | 2 | -2/+26 |
* | _Thread_Start_multitasking: added code to initialize the floating point | Joel Sherrill | 1996-08-15 | 1 | -1/+25 |
| | | | | context of the first thread to execute. | ||||
* | changed ENOMEM error message | Mark Johannes | 1996-08-15 | 1 | -1/+4 |
* | init: added tests for pthread_kill and kill errors. | Mark Johannes | 1996-08-15 | 1 | -32/+186 |
