* Makefile.am: Remove non-existing file "times" from EXTRA_DIST.
* startup/Makefile.am: Remove non-existing files setvec.c,
bspclean.c, exit.c from EXTRA_DIST.
* timer/Makefile.am: Remove non-existing file timer.c from EXTRA_DIST.
* wrapup/Makefile.am: Reflect changes to libcpu.
* Makefile.am: Remove non-existing times from EXTRA_DIST.
* start/Makefile.am: Remove non-existing cpuboot.c from EXTRA_DIST.
* configure.ac: Add AM_CONDITIONAL(HAS_FPSP).
* README: Fix minor typo.
* Makefile.am: Convert to automake compilation rules.
* configure.ac: Remove.
* .cvsignore: Reflect changes above.
* m68040/Makefile.am: Merge-in m68040/fpsp/Makefile.am.
Use automake-compilation rules.
* m68040/fpsp/Makefile.am: Remove.
* shared/Makefile.am: Use automake compilation rules.
* Makefile.am: Reflect changes above. Remove CPU_SUBDIR.
* configure.ac: Require automake >= 1.8.2.
Add subdir-objects to AUTOMAKE_OPTIONS.
Remove CHECK_CUSTOM_BSP.
* clock/Makefile.am: Convert to using automake compilation rules.
* mongoosev/Makefile.am: Ditto.
* r46xx/Makefile.am: Ditto.
* shared/Makefile.am: Ditto.
* timer/Makefile.am: Ditto.
* tx39/Makefile.am: Ditto.
* Makefile.am: Remove conditional subdirs.
* configure.ac: Add subdir-object to AUTOMAKE_OPTIONS.
Require automake-1.8.2. Add AM_PROG_CC_C_O.
* syscall/Makefile.am: Remove.
* reg_win/Makefile.am: Remove.
* cache/Makefile.am: Remove.
* Makefile.am: Merge-in Makefile.ams above. Use automake compilation
rules.
* Makefile.am: Remove times from EXTRA_DIST (Non-existant).
* startup/Makefile.am: Remove exit.c, setvec.c from EXTRA_DIST.
* console/Makefile.am: Remove console.c from EXTRA_DIST.
* startup/Makefile.am: Remove bspclean.c, exit.c, setvec.c from
EXTRA_DIST.
* Makefile.am: Remove gdbstub/rtems-stub-glue.c (Non-existent)
* startup/Makefile.am: Remove bogus EXTRA_DIST.
* timer/Makefile.am: Remove bogus EXTRA_DIST.
* clock/Makefile.am: Remove bogus EXTRA_DIST.
* gdbsci/Makefile.am: Remove bogus EXTRA_DIST.
* configure.ac: Require automake 1.8.2.
Add AM_PROG_CC_C_0.
* Makefile.am: Use automake compilation rules.
* aclocal/rtems-top.m4: Remove check for version.m4.
* automake/compile.am: Remove LINK_OBJS, LINK_FILES (Unused).
* Makefile.am: Fix typo in previous patch.
* automake/compile.am: Add RTEMS_RELLDFLAGS.
Remove XLDFLAGS.
* wrapup/Makefile.am: Reflect changes to libchip/*.
* support/Makefile.am: Use automake compilation rules.
* wrapup/Makefile.am: Reflect changes to support/*.
* configure.ac: Remove libnetworking/wrapup/Makefile.
* wrapup/Makefile.am: Reflect change to libnetworking/*.
Use libnetworking/*/lib*.a instead of libnetapps.a
* Makefile.am: Remove wrapup.
* pppd/Makefile.am: Build libpppd.
* rtems_servers/Makefile.am: Build libftpd.
* rtems_telnetd/Makefile.am: Build libtelnetd.
* rtems_webserver/Makefile.am: Build libhttpd.
* wrapup/Makefile.am: Remove (Unused).
* configure.ac: Add subdir-objects to AUTOMAKE_OPTIONS.
Add RTEMS_PROG_CCAS.
Add AM_PROG_CC_C_O.
* Makefile.am: Use automake-compilation rules.
* start/.cvsignore: Remove.
* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* wrapup/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* automake/lib.am: Remove TMPINSTALL_FILES.
* pppd/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* rtems_servers/Makefile.am: Ditto.
* rtems_telnetd/Makefile.am: Ditto.
* rtems_webserver/Makefile.am: Ditto.
* startup/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* startup/Makefile.am: Ditto.
* console/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* irq/Makefile.am: Ditto.
* motorola/Makefile.am: Ditto.
* openpic/Makefile.am: Ditto.
* pci/Makefile.am: Ditto.
* residual/Makefile.am: Ditto.
* vectors/Makefile.am: Ditto.
* start/Makefile.am: Ditto.
* bootloader/Makefile.am: Ditto.
* vme/Makefile.am: Ditto.
* start/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* consolex/Makefile.am: Ditto.
* configure.ac: Ditto.
* console/Makefile.am: Ditto.
