In another attempt to get C++ exceptions working on the gen68360 target
I tried building for the m68k-elf target. All the tools built and
installed properly as did all of RTEMS. No applications would run,
though -- not even hello.exe!
It turns out the problem was in the linker script. The alignment was in
the wrong place.
Here's a patch. Exceptions still don't work, but at least I can get
some things working with the ELF format now.
errors.
to added the bin2boot_SOURCES warning.
and reported by Ralf Corsepius <corsepiu@faw.uni-ulm.de> on the mpc505.
<valette@crf.canon.fr> and Jay Kulpinski <jskulpin@eng01.gdds.com>.
+ Added checks for valid attribute maxmsg and msgsize
+ Added check for ENAMETOOLONG
old_exception_processing tree.
which fixes a couple of bugs in RTEMS's old style Makefile.ins, which
apparently were introduced by moving the start directories and not
having adapted the Makefile.ins.
patch -p1 < rtems-rc-19991203-10.diff
which ontains all what was left over from the other patches (Primarily
minor configuration cleanups).
patch -p1 < rtems-rc-19991203-9.diff
./bootstrap
which does minor cleanup for Makefile.ams below mptests, which only
removes some bogus comments from the Makefile.ams.
patch -p1 < rtems-rc-19991203-8.diff
./bootstrap
esp. some powerpc cpu-models
them to $(PROJECT_INCLUDE)/
./bootstrap
./bootstrap
which fixes a nasty dependency bug in optman/Makefile.am. Those
directories have been build twice before, i.e. re-running make after
having built rtems before, was rebuilding the files in optman/
directories.
patch -p1 < rtems-rc-19991203-6.diff
./bootstrap
John Mills <jmills@tga.com>.
too small when OPERATION_COUNT is less than 10.
I got tired of having strange clock rates (e.g. #define
CONFIGURE_MICROSECONDS_PER_TICK 52489) and drifting times-of-day with
the gen68360 BSP so I changed the way the programmable-interval clock
interrupt works. The new version will have some jitter in the intervals
between individual calls to the rtems_clock_tick routine, but the
long-term average will match the CONFIGURE_MICROSECONDS_PER_TICK
fixes some problems:
I found the problem which prevented opening 'dev/sci1' (the default
console) with the 'gensh2' (sh7045) BSP. Both SCI ports were being
initialized against the same minor device number: '0'. When I tried to
open minor-device '1', it naturally crashed. Fixing that one value in the
'sci_device[]' array solved the problem and allowed 'hello.exe' to run.
TPC values. Reviewed by Ralf Corsepius <corsepiu@faw.uni-ulm.de>
who originally submitted the file.
more flexible about the error status returned from a timeout.
which adds automake support to libbsp/bare.
use correct ifdef conditional (__GNUC__ not __GCC__).
report by Nick.SIMON@syntegra.bt.co.uk:
TFTP uses UDP and UDP packets are prime targets for getting dropped when
the network gets busy. I want the number of retries quite large in my
application. I see that PACKET_REPLY_MILLISECONDS is, in fact, not
being used.
functionality. This puts RTEMS in near compliance with the network
functionality defined in the first draft of the EL/IX API. Comments
follow:
With the attached changes to the libnetworking/libc/Makefile.in, RTEMS
provides all the functions listed in section 4.14 of the EL/IX document
except:
socketpair
if_nametoindex
if_indextoname
if_nameindex
if_freenameindex
Some of the routines which get information from files may be of limited
use unless an application sets up the files somehow (TFTP/untar from
host, etc.), but at least RTEMS is pretty much fully buzzword compliant
with the networking section of the EL/IX API.
