.s files to .S in conformance with GNU conventaons. This is a
Corsepius <corsepiu@faw.uni-ulm.de>.
all conflicts.
Date: Sat, 5 Dec 98 13:20:51 -0600
What do you think of this patch? It implements your `tap'
suggestion in a way that adds support for all ethernet devices with
no driver modifications. I also added a return value from the tap
function. If the return value is zero, the packet will be passed up
the chain as usual. If the return value is non-zero the mbuf holding
the packet will be freed and the packet will be dropped.
If you like it, please submit it to Joel.
I guess there needs to be an addition to the network documentation
describing the additional ioctl's -- and a big warning that the tap
function is called from a context that holds the network semaphore.
Here is Eric's patch. I've tested it a bit, and made a couple of
trivial changes. This is certainly better than mine: it should work
for all Ethernet drivers.
The only concern I have about this patch is that the tap function may
want to fiddle with the mbuf, calling functions like m_pullup and the
like. If those force the networking code to rearrange the mbuf
structure, then the caller's call to m_freem may crash. I don't know
if this is a realistic concern--I don't know enough about the mbuf
layer.
This patch avoids a warning from the development version of gas.
RTEMS permits using the SO_SNDTIMEO and SO_RCVTIMEO socket options to
set a timeout for most socket I/O operations. However, in RTEMS
4.0.0, those options do not affect connect or accept. I don't know of
any way to put a timeout on those calls in RTEMS 4.0.0; can anybody
point to one.
Since it is frequently useful to have a timeout on accept, and
sometimes useful to have a timeout on connect shorter than the BSD
system default of 75 seconds, the following patch causes SO_RCVTIMEO
to affect connect and accept.
Hello,
host :
- one for RTEMS it self,
- one for GDB-4.17.
1/ RTEMS patch
This patch adds 2 libraries :
- the Remote Debugger library
--enable-rdbg
rtems_rdbg_initialize ();
2/ GDB-4.17 patch
To connect to a target, use :
And... Debug ;)
blocking protocol is used.
Updated scn files to match present expected test output.
Renamed all directories to start with psx.
Modifications for RTEMS_UNIX.
test suite designator. In English, we now support psxfile in addition
to psx11.
Include files now installed as <rtems/*.h>.
PROBLEMS
can/will be fixed.
it work.
<erik.ivanenko@utoronto.ca> and Eric Valette <valette@crf.canon.fr>.
Here is a cosmetic patch which corrects a few spelling problems in parts
written by me.
Apparently, I must have written these under the influence of ether (:-)
