* bsp_specs: Remove stray % from '*startfile:' having crept in
previous patch.
PR 1354/bsps
* network/network.c: In some cases it can occur that an empty mbuf is
put on the descriptor chain. (We found it especially then when
transmitting fragmented IP Packets.) Since the actual buffer
descriptor pointer will be incremented after every inserted mbuf
(txBd = sc->txBdBase + sc->txBdHead;) even if m->m_len of the current
mbuf was zero. This leads to the bug.
* libchip/i2c/spi-sd-card.c: Fixed RTEMS_BLKDEV_CAPABILITIES ioctl
which caused invalid multiple block writes.
PR 1358/bsps
* clock/clock.c: Fix time-access bug in uc5282 BSP.
PR 1350/bsps
* network/lan91c11x.c: Do not write 65th element into 64 element array.
PR 1349/bsps
* startup/bspstart.c: Add missing volatile on UART access pointer.
* bsp_specs: Backport from CVS-HEAD.
* psim-shared, runtest-bottom: Tidy up more bugs.
* psim-bottom, psim-gdb-bottom, psim-gdb-top.in, psim-shared,
psim-top.in: Clean up and works better. Uses argv[0] to override
configured target name.
PR 1344/bsps
* clock/ckinit.c: Committed code was not final. Corrections.
* psim-bottom, psim-gdb-bottom, psim-shared, psim-top.in: Add ability
to force psim configuration to include System V IPC devices even when
the test does not appear to be multiprocessing. This is used by some
RTEMS application developers for system simulation and could be used
to simulate a framebuffer if a UNIX process mirrored the buffer.
Michael South <msouth@msouth.org>
PR 1344/bsps
* cpuModel.h: Add use of TSC for nanoseconds granularity. i8254 is very
slow on some systems. TSC use is auto-detected by default.
PR 1344/bsps
* configure.ac, clock/ckinit.c, timer/timer.c: Add use of TSC for
nanoseconds granularity. i8254 is very slow on some systems. TSC use
PR 1345/Ada
* rtems.ads: RTEMS boolean type is now C99 bool which is not an
unsigned32.
PR 1339/Ada
* rtems.adb, rtems.ads: Re-add IO Manager to Ada binding.
correct some init values for HSC_CM01 boards
change strategy to determine MAC address
function within a critical section for printk() compatibility.
PR 1332: call BSP_uart_termios_set()/BSP_uart_intr_ctrl()
only from 'firstOpen' and only if this is a serial console.
* shared/startup/linkcmds: increased size of CODE memory
area.
* shared/startup/pretaskinghook.c, shared/startup/sbrk.c:
Fixed PR#1335. Pass initial starting address to heap
initialization to avoid 1st 'sbrk'. User may now define
'BSP_sbrk_policy' variable (see sbrk.c) to tune behavior.
* Makefile.am: Remove unused file.
* pci/no_host_bridge.c: Removed.
* preinstall.am: Regenerated.
* Makefile.am: bsp_cleanup() was wrong. Use stub. openpic.h not needed.
* startup/bspclean.c: Removed.
* console/init68360.c: Delete unused code.
PR 1329/bsps
* network_5200/network.c: Eliminate use of boolean so this compiles.
add U-Boot support
remove dead code
adjust console clock routing
fix CPIC interrupts
* Makefile.am, preinstall.am, PCI_bus/universe.c, console/console.c,
include/bsp.h, irq/FPGA.c, irq/irq.c, startup/Hwr_init.c,
startup/bspstart.c, startup/vmeintr.c: Modifications required to run
on hardware. Some cleanup.
* include/irq-config.h: New file.
* startup/spurious.c: Removed.
* timer/timer.c: Eliminate uses of old benchmark timer names.
* include/tm27.h: Do not use set_vector.
* start/startfor340only.S: Remove (unused).
* console/defaultfont.c: Remove (Renamed into console/defaultfont.h).
* console/defaultfont.h: New (Renamed from console/defaultfont.c).
* Makefile.am, console/conio.c: Reflect renamer.
* support/timer_driver.adb, support/timer_driver.ads,
tmtests/tm01/tmtest.adb, tmtests/tm02/tmtest.adb,
tmtests/tm03/tmtest.adb, tmtests/tm04/tmtest.adb,
tmtests/tm05/tmtest.adb, tmtests/tm06/tmtest.adb,
tmtests/tm07/tmtest.adb, tmtests/tm08/tmtest.adb,
tmtests/tm09/tmtest.adb, tmtests/tm10/tmtest.adb,
tmtests/tm11/tmtest.adb, tmtests/tm12/tmtest.adb,
tmtests/tm13/tmtest.adb, tmtests/tm14/tmtest.adb,
tmtests/tm15/tmtest.adb, tmtests/tm16/tmtest.adb,
tmtests/tm17/tmtest.adb, tmtests/tm18/tmtest.adb,
tmtests/tm19/tmtest.adb, tmtests/tm20/config.h,
tmtests/tm20/tmtest.adb, tmtests/tm21/tmtest.adb,
tmtests/tm22/tmtest.adb, tmtests/tm23/tmtest.adb,
tmtests/tm24/tmtest.adb, tmtests/tm25/tmtest.adb,
tmtests/tm28/tmtest.adb, tmtests/tm29/tmtest.adb,
tmtests/tmck/tmtest.adb, tmtests/tmoverhd/tmtest.adb: Clean up.
Verified to run on psim with gcc 4.3.2.
* liblnk/regs.S: Remove (Renamed into liblnk/regs.h).
* liblnk/regs.h: New (Renamed from liblnk/regs.S).
* Makefile.am, liblnk/pmon.S: Reflect renamer.
* liblnk/regs.S: Remove (Rename into liblnk/regs.h).
* start/regs.S: Remove (Renamed into start/regs.h).
* start/regs.h: New (Renamed from start/regs.S).
* Makefile.am, start/start.S: Reflect renamer.
* Makefile.am: Remove noinst_PROGRAMS (Unused).
* Makefile.am: Cleanup.
* Makefile.am: Eliminates libcpudir.
PR 1323/bsps
* Makefile.am: Remove AM_CFLAGS += -msoft-float.
* Makefile.am: Remove empty HAS_NETWORKING conditional.
PR 1322/bsps
* include/bspopts.h.in: Remove.
