* preinstall.am: Add vme_am_defs.h
* network/network.c: Fix LED configuration to match uCDIMM.
* network/if_100MHz/GT64260eth.c: Add else.
* README: Update.
* network/GT64260eth.c, network/GT64260eth.h, network/GT64260ethreg.h: Removed.
* Makefile.am, README, README.booting, README.irq,
preinstall.am, GT64260/MVME5500I2C.c, include/bsp.h, irq/irq.c,
irq/irq.h, irq/irq_init.c, pci/pci.c, pci/pci_interface.c,
pci/pcifinddevice.c, start/preload.S, startup/bspclean.c,
startup/bspstart.c, startup/pgtbl_activate.c, startup/reboot.c:
Merge my improvements in this BSP including a new network
driver for the 1GHz NIC.
* network/if_100MHz/GT64260eth.c, network/if_100MHz/GT64260eth.h,
network/if_100MHz/GT64260ethreg.h, network/if_100MHz/Makefile.am,
network/if_1GHz/Makefile.am, network/if_1GHz/POSSIBLEBUG,
network/if_1GHz/if_wm.c, network/if_1GHz/if_wmreg.h,
network/if_1GHz/pci_map.c, network/if_1GHz/pcireg.h: New files.
PR 1249/build
* configure.ac: Jerry Needell <jerry.needell@unh.edu> reported that the
leon3 was left out of the cache enable logic. Thus the cache
management support code was empty on LEON3 CPUs.
PR 1244/bsps
* console/console.c: Remove definition of __assert.
* posix/tools/runtest.in: Do not run pppd.exe from batch mode script.
* erc32/tools/runtest.in, leon2/tools/runtest.in,
leon3/tools/runtest.in: Do not run pppd.exe from batch mode script.
* simsh4/tools/runtest.in: Do not run pppd.exe from batch mode script.
* psim/tools/runtest: Do not run pppd.exe from batch mode script.
* jmr3904/tools/runtest: Do not run pppd.exe from batch mode script.
* mcf5206elite/tools/runtest: Do not run pppd.exe from batch mode
script.
* configure.ac: Do not configure tools. They only build on a Solaris
VMEBus host anyway.
* bsp_specs: Remove --oformat=...
Use old_link for -qrtems (Prevents *.link from killing endianness).
* bsp_specs: Use nostdlib instead of nostdlibs (bogus).
* bsp_specs: Use old_link for -qrtems (Prevents *.link from killing
endianness).
* bsp_specs: Remove lib (Now expected to exist in GCC).
* rtems.adb, rtems.ads: Update.
* Makefile.am: Add dummy printk support so all tests link.
* dummy_printk_support.c: New file.
PR 1235/bsps
* pci/pci.c: Add conditional declaration of variables used in debug
printk's.
PR 1233/bsps
* Makefile.am, console/console.c, console/debugputs.c: Move printk
support code into debug IO file so you do not get the entire console
driver when you do not want it.
PR 1232/bsps
* bsppost.c: It should not be a fatal error to not have a console.
* aclocal/target.m4: Strip CFLAGS (Hack to prevent bsp-cflags from
being used to compile "tools").
match the "auto clock detection" scheme in the libcpu clock driver
* startup/linkcmds: remove content of dpram section to avoid
download hangs with the EPPCBug board monitor
* libchip/network/cs8900.c, libchip/network/cs8900.h,
libchip/network/greth.c, libchip/network/greth.h: Correct license URL
and/or fix mistake in copyright notice. Both of these mistakes appear
to be from code submitted after these changes were made previously.
* console/uart.c, start/start.S, startup/linkcmds, startup/memmap.c:
Correct license URL and/or fix mistake in copyright notice. Both of
these mistakes appear to be from code submitted after these changes
* console/uarts.c, include/bsp.h, start/start.S, startup/bspstart.c,
startup/exit.c, startup/linkcmds: Correct license URL and/or fix
mistake in copyright notice. Both of these mistakes appear to be from
* include/bsp.h, network/lan91c11x.c, network/lan91c11x.h,
network/network.c, start/start.S, startup/bspstart.c, startup/exit.c,
startup/linkcmds, startup/memmap.c: Correct license URL and/or fix
* clock/clock.c, console/console.c, include/bsp.h, include/coverhd.h,
include/tm27.h, network/network.c, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/init5282.c, startup/linkcmds,
timer/timer.c: Correct license URL and/or fix mistake in copyright
notice. Both of these mistakes appear to be from code submitted after
* include/coverhd.h, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/linkcmds, startup/linkcmdsflash,
startup/linkcmdsram: Correct license URL and/or fix mistake in
copyright notice. Both of these mistakes appear to be from code
* console/console-io.c, include/bsp.h, start/start.S,
startup/bspclean.c, startup/bspstart.c, startup/init5272.c: Correct
license URL and/or fix mistake in copyright notice. Both of these
mistakes appear to be from code submitted after these changes were
made previously.
* console/console-io.c, startup/exception.S: Correct license URL and/or
fix mistake in copyright notice. Both of these mistakes appear to be
* clock/ckinit.c, startup/exception.S: Correct license URL and/or fix
* clock/clockdrv.c, console/console-io.c, include/bsp.h,
startup/bspstart.c, timer/timer.c: Correct license URL and/or fix
* irq/irq_init.c: Correct license URL and/or fix mistake in copyright
* clock/clock.c, console/console.c, ide/pcmcia_ide.c, irq/irq.c,
irq/irq.h, irq/irq_asm.S, irq/irq_init.c, nvram/nvram.c,
nvram/nvram.h, slicetimer/slicetimer.c, startup/bspstart.c,
vectors/vectors.h, vectors/vectors_init.c: Correct license URL and/or
* at91rm9200/clock/clock.c, at91rm9200/dbgu/dbgu.c,
at91rm9200/include/at91rm9200.h,
at91rm9200/include/at91rm9200_dbgu.h,
at91rm9200/include/at91rm9200_emac.h,
at91rm9200/include/at91rm9200_gpio.h,
at91rm9200/include/at91rm9200_mem.h,
at91rm9200/include/at91rm9200_pmc.h, at91rm9200/include/bits.h,
at91rm9200/irq/bsp_irq_asm.S, at91rm9200/irq/bsp_irq_init.c,
at91rm9200/irq/irq.c, at91rm9200/irq/irq.h, at91rm9200/pmc/pmc.c,
at91rm9200/timer/timer.c, mc9328mxl/clock/clockdrv.c,
mc9328mxl/include/mc9328mxl.h, mc9328mxl/irq/bsp_irq_asm.S,
mc9328mxl/irq/bsp_irq_init.c, mc9328mxl/irq/irq.c,
mc9328mxl/irq/irq.h, mc9328mxl/timer/timer.c,
s3c2400/clock/clockdrv.c, s3c2400/timer/timer.c: Correct license URL
* mcf5272/clock/ckinit.c, mcf5272/include/mcf5272.h,
mcf5272/timer/timer.c, mcf5272/timer/timerisr.S: Correct license URL
* au1x00/include/au1x00.h, au1x00/vectorisrs/maxvectors.c,
au1x00/vectorisrs/vectorisrs.c: Correct license URL and/or fix
* mpc6xx/mmu/mmuAsm.S: Correct license URL and/or fix mistake in
PR 1227/bsps
* include/bsp.h: Remove MAX_LONG_TEST_DURATION and
MAX_SHORT_TEST_DURATION. They are obsolete and unused.
