* | bsp/raspberrypi: New BSP | Alan Cudmore | 2013-03-24 | 21 | -0/+1532 |
* | bsp/mpc83xx: Add MPC83XX_NET*_INTERFACE_0_PHY_ADDR | Sebastian Huber | 2013-03-21 | 1 | -0/+5 |
* | bsp/psim: Use shared linkcmds.base | Sebastian Huber | 2013-03-19 | 6 | -285/+62 |
| | | | | | Several GCC tests faild due to the outdated previous linker command file. | ||||
* | bsps: Support DWARF extension | Sebastian Huber | 2013-03-18 | 8 | -0/+19 |
* | bsp/edb7312: Improve output char | Sebastian Huber | 2013-03-14 | 1 | -11/+20 |
| | | | | | The output char function used by printk() is now independent of the console driver initialization. | ||||
* | bsp/edb7312: Fix warnings | Sebastian Huber | 2013-03-14 | 1 | -8/+0 |
* | mpc83xx: Add and use mpc83xx_reset() | Sebastian Huber | 2013-03-14 | 2 | -15/+22 |
| | | | | | The inline version makes it possible to use this code in different memory areas. | ||||
* | mpc83xx: Use shared linkcmds.base | Sebastian Huber | 2013-03-14 | 13 | -495/+129 |
* | mpc83xx: Copy nothing if necessary | Sebastian Huber | 2013-03-14 | 1 | -0/+3 |
* | mpc83xx: Fix local access window 1 configuration | Sebastian Huber | 2013-03-14 | 1 | -0/+10 |
* | mpc83xx: Add MPC83XX_HAS_NAND_LP_FLASH_ON_CS0 | Sebastian Huber | 2013-03-14 | 3 | -9/+27 |
* | mvme3100/Makefile.am: Remove reference to ChangeLog | Joel Sherrill | 2013-03-11 | 1 | -1/+1 |
* | beatnik/Makefile.am: Remove reference to ChangeLog | Joel Sherrill | 2013-03-11 | 1 | -1/+1 |
* | RTEMS: Delete ChangeLog files. | Gedare Bloom | 2013-03-08 | 124 | -58241/+0 |
| | | | | | | | | | This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain. | ||||
* | libchip: Fix prototypes | Sebastian Huber | 2013-03-01 | 3 | -24/+24 |
* | libchip/rtc: Fixed 19 compiler warnings | Andreas Heinig | 2013-02-28 | 3 | -3/+7 |
* | libchip/serial: Fixed warnings | Andreas Heinig | 2013-02-28 | 1 | -0/+3 |
* | Common file changes in support of Moxie port | Anthony Green | 2013-02-28 | 1 | -0/+1 |
| | | | | Signed-off-by: Anthony Green <green@moxielogic.com> | ||||
* | Add sample Moxie BSP for GDB sim | Anthony Green | 2013-02-28 | 15 | -0/+646 |
* | libchip/network: Fixed warning | Andreas Heinig | 2013-02-27 | 1 | -1/+2 |
* | sparc: Remove dead code that was leftover from SMP development. | Jennifer Averett | 2013-02-26 | 1 | -4/+0 |
* | bsp/mpc55xx: Add register type definition | Sebastian Huber | 2013-02-25 | 1 | -1/+1 |
* | bsp/gen5200: New ATA driver | Sebastian Huber | 2013-02-20 | 10 | -45/+1566 |
| | | | | This is a replacement for the ATA task. The performance is much better. | ||||
* | bsp/gen5200: Add and use mpc5200_fatal() | Sebastian Huber | 2013-02-20 | 6 | -10/+27 |
* | bsp/mpc55xx: Fix prototype | Sebastian Huber | 2013-02-20 | 2 | -2/+2 |
* | make: Add default flags | Sebastian Huber | 2013-02-13 | 1 | -7/+4 |
* | make: Add CPPFLAGS | Sebastian Huber | 2013-02-13 | 1 | -0/+2 |
* | make: Remove -Wno-unused flag for debug variant | Sebastian Huber | 2013-02-13 | 1 | -1/+1 |
* | make: Remove -g flags | Sebastian Huber | 2013-02-13 | 1 | -3/+3 |
| | | | | The -g flag is set by the BSP. | ||||
* | make: Remove -qrtems_debug flag usage | Sebastian Huber | 2013-02-13 | 1 | -3/+3 |
* | bsps/powerpc: Remove unused files | Sebastian Huber | 2013-02-13 | 2 | -46/+0 |
* | bsp/lpc32xx: Add BSP_USB_OTG_TRANSCEIVER_VBUS | Sebastian Huber | 2013-02-12 | 1 | -0/+3 |
* | sparc64: revert linkcmds to 4 MB ram size | Gedare Bloom | 2013-02-11 | 1 | -2/+2 |
* | bsp/lpc24xx: Move UART probes to separate files | Sebastian Huber | 2013-02-11 | 6 | -53/+130 |
* | libchip/serial: Make NS16550 handler public | Sebastian Huber | 2013-02-11 | 5 | -18/+29 |
| | | | | This allows derived drivers to use these functions. | ||||
* | libchip/serial: Add const qualifier | Sebastian Huber | 2013-02-11 | 38 | -64/+64 |
* | libchip/serial: Fix warnings | Sebastian Huber | 2013-02-11 | 2 | -2/+13 |
* | libchip/serial: Fix warnings | Sebastian Huber | 2013-02-11 | 1 | -2/+1 |
* | libchip/serial: Fix warnings | Sebastian Huber | 2013-02-11 | 2 | -6/+9 |
* | bsp/erc32: Fix warnings | Sebastian Huber | 2013-02-11 | 1 | -2/+2 |
* | bsp/mpc55xx: Add MPC55XX_ENABLE_START_PROLOGUE | Sebastian Huber | 2013-02-06 | 5 | -0/+51 |
* | bsp/mpc55xx: Merge RSM6 variants into one | Sebastian Huber | 2013-02-06 | 16 | -150/+85 |
* | bsp/mpc55xx: Add and use BSP specific fatal codes | Sebastian Huber | 2013-02-06 | 7 | -20/+45 |
* | bsps/powerpc: Add and use ppc_cpu_is_specific_e200 | Sebastian Huber | 2013-02-06 | 2 | -2/+10 |
* | bsps/powerpc: Fix e200 check | Sebastian Huber | 2013-02-06 | 1 | -4/+2 |
* | bsp/mpc55xx: Add mpc55xx_mmu_apply_config() | Sebastian Huber | 2013-02-06 | 1 | -2/+12 |
* | bsp/mpc55xx: Add BSP_DATA_CACHE_USE_WRITE_THROUGH | Sebastian Huber | 2013-01-28 | 3 | -2/+13 |
* | bsps/powerpc: Add option for write-through cache | Sebastian Huber | 2013-01-28 | 1 | -1/+2 |
* | bsp/mpc55xx: Fix MMU configuration for RSM6 | Sebastian Huber | 2013-01-28 | 1 | -4/+4 |
* | Fixed virtex4,5 BSP compile time warnings | Ric Claus | 2013-01-26 | 6 | -7/+11 |
