* TOOL_TARGETS: Add Lattice Mico32 support.
* aclocal/rtems-cpu-subdirs.m4: Add Lattice Mico32 support.
* ChangeLog, Makefile.am, configure.ac, preinstall.am,
shared/cache/cache.c, shared/cache/cache_.h, shared/misc/memcpy.c: New files.
* ChangeLog, Makefile.am, README, acinclude.m4, configure.ac,
shared/clock/ckinit.c, shared/clock/clock.h,
shared/console/console.c, shared/console/uart.c,
shared/console/uart.h, shared/start/start.S,
shared/startup/bspstart.c, shared/startup/setvec.c,
shared/timer/timer.c, shared/tsmac/dp83848phy.h,
shared/tsmac/tsmac.c, shared/tsmac/tsmac.h: New files.
* ChangeLog, Makefile.am, bsp_specs, configure.ac, preinstall.am,
include/.cvsignore, include/bsp.h, include/coverhd.h,
include/irq-config.h, include/system_conf.h, include/tm27.h,
startup/linkcmds: New files.
* shared/irq/openpic_i8259_irq.c: Line wrap.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* bsp_specs, start/start.S: Move -e start from *link to *startfile to
avoid warning for undefined entry symbol when linking relocatables
with binutils 2.19. Also rename entry from _init to _start to avoid
conflict with C++ constructor method name on other architectures.
* bsp_specs, tools/runtest.in: Move -e start from *link to *startfile
to avoid warning for undefined entry symbol when linking relocatables
with binutils 2.19.
* psim-bottom, psim-gdb-bottom, psim-gdb-top.in, psim-shared,
psim-top.in: Clean up and works better. Uses argv[0] to override
configured target name.
PR 1344/bsps
* clock/ckinit.c: Committed code was not final. Corrections.
* bsp_specs: Remove references to start_g.o.
* psim-bottom, psim-gdb-bottom, psim-shared, psim-top.in: Add ability
to force psim configuration to include System V IPC devices even when
the test does not appear to be multiprocessing. This is used by some
RTEMS application developers for system simulation and could be used
to simulate a framebuffer if a UNIX process mirrored the buffer.
* bsp_specs: Remove -e start from %link.
Remove start_g.o.
* bsp_specs: Remove -e start from %link. Remove references to
start_g.
* bsp_specs: Remove -u start -e start from %link.
* console/console.c: Use bool.
Michael South <msouth@msouth.org>
PR 1344/bsps
* cpuModel.h: Add use of TSC for nanoseconds granularity. i8254 is very
slow on some systems. TSC use is auto-detected by default.
PR 1344/bsps
* configure.ac, clock/ckinit.c, timer/timer.c: Add use of TSC for
nanoseconds granularity. i8254 is very slow on some systems. TSC use
PR 1345/Ada
* rtems.ads: RTEMS boolean type is now C99 bool which is not an
unsigned32.
* startup/bspgetworkarea.c: Remove debug prints.
* bsp_specs, startup/bspgetworkarea.c: Links hello again.
* startup/linkcmds: Most .eh_frame section to make gcc 4.4 SVN happy.
* .cvsignore: New file.
* README: Fix typo.
* ChangeLog, Makefile.am, acinclude.m4, configure.ac: New files.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
preinstall.am, console/console-io.c, include/.cvsignore,
include/bsp.h, start/start.S, startup/linkcmds, tools/.cvsignore,
tools/Makefile.am, tools/configure.ac, tools/runtest.in: New files.
PR 1339/Ada
* rtems.adb, rtems.ads: Re-add IO Manager to Ada binding.
correct some init values for HSC_CM01 boards
change strategy to determine MAC address
function within a critical section for printk() compatibility.
* startup/bspstart.c: Add bsp_clicks_per_usec variable which is used by
shared code.
PR 1332: call BSP_uart_termios_set()/BSP_uart_intr_ctrl()
only from 'firstOpen' and only if this is a serial console.
* shared/startup/linkcmds: increased size of CODE memory
area.
* shared/startup/pretaskinghook.c, shared/startup/sbrk.c:
Fixed PR#1335. Pass initial starting address to heap
initialization to avoid 1st 'sbrk'. User may now define
'BSP_sbrk_policy' variable (see sbrk.c) to tune behavior.
PR 1303/bsps
* fatal/bspfatal.c: strcat() is safe to use even in worst case, so do
not have BSP specific mystrcat().
* startup/linkcmds: Do not specify architecture since the linker gets
it right even with multiple variants.
* clock_driver_simidle.c: Ensure ISR nest level and Thread Dispatch
disable level are in the same state they would be in a true ISR. This
ensures that all of the clock tick handling is as similar as possible
in this limited environment.
shared/include/powerpc-utility.h: Use constraint "b" for address
base registers in inline assembler statements.
Update for status-checks.h changes.
* Makefile.am: Remove unused file.
* pci/no_host_bridge.c: Removed.
* startup/bspgetworkarea.c: Fix botched edit.
