* src/aclocal/rtems-cpu-subdirs.m4: Add new M32R port. It is just a
beginning but the BSP is functional enough to initialize and shutdown
RTEMS.
* ChangeLog, Makefile.am, acinclude.m4, configure.ac: New files.
* .cvsignore, ChangeLog, Makefile.am, bsp_specs, configure.ac,
preinstall.am, console/console-io.c, console/syscalls.S,
console/trap0.S, include/.cvsignore, include/bsp.h, include/tm27.h,
start/start.S, startup/linkcmds: New files.
* aclocal/rtems-cpu-subdirs.m4: Add new M32C port.
* include/tm27.h: Use shared tm27.h stub.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* preinstall.am: Regenerated.
* .cvsignore, ChangeLog, Makefile.am, acinclude.m4,
* README: New file.
include/.cvsignore, include/bsp.h, start/start.S, startup/bspstart.c,
startup/crtn.S, startup/linkcmds, timer/timer.c, tools/.cvsignore,
tools/Makefile.am, tools/configure.ac, tools/runtest.in: New files.
* Makefile.am: bsp_cleanup() was wrong. Use stub. openpic.h not needed.
* startup/bspclean.c: Removed.
* console/init68360.c: Delete unused code.
* bootcard.c, bspgetworkarea.c, bsppretaskinghook.c,
include/bootcard.h: Change size_t to ssize_t on bsp_get_work_area().
On 16-bit architectures, size_t can be 16-bits which would limit the
work area to 64K.
* startup/bspgetworkarea.c: Change size_t to ssize_t on
bsp_get_work_area(). On 16-bit architectures, size_t can be 16-bits
which would limit the work area to 64K.
* shared/bspgetworkarea.c: Change size_t to ssize_t on
* shared/startup/bspgetworkarea.c: Change size_t to ssize_t on
* console/config.c, console/console.c, console/console.h,
console/ns16550cfg.c, console/ns16550cfg.h, include/bsp.h,
include/tm27.h, irq/irq_init.c, irq/openpic_xxx_irq.c,
pci/no_host_bridge.c: File head clean up.
* console/debugio.c: Removed.
* Makefile.am, preinstall.am: Use shared stub coverhd.h
* include/coverhd.h: Removed.
* PCI_bus/PCI.c, PCI_bus/PCI.h, PCI_bus/flash.c, console/85c30.h,
console/console.c, console/consolebsp.h, console/tbl85c30.c,
include/gen2.h, irq/FPGA.c, irq/irq.c, irq/irq.h, irq/irq_init.c,
pci/no_host_bridge.c, startup/bspclean.c, startup/bspstart.c,
startup/genpvec.c, startup/vmeintr.c: File head clean up.
* Makefile.am, startup/bspgetworkarea.c: Turn = into +=.
* configure.ac: Move PGH360, GEN68360, GEN68360_040
defines from *.cfg into bspopts.h.
* configure.ac: Move M5484FIREENGINE defines from *.cfg into
bspopts.h.
* configure.ac: Move PM520_ZE30, PM520_CR825, icecube, BRS5L
* configure.ac: Move MPC8313ERDB, MPC8349EAMDS, HSC_CM01, MPC8349
* Makefile.am, PCI_bus/PCI.c, PCI_bus/universe.c, startup/genpvec.c:
Fix warnings.
* Makefile.am, preinstall.am, PCI_bus/PCI.c, PCI_bus/PCI.h,
PCI_bus/universe.c, console/85c30.c, console/85c30.h,
console/consolebsp.h, console/tbl85c30.c, include/gen2.h,
startup/Hwr_init.c, startup/bspstart.c, startup/genpvec.c,
startup/setvec.c, startup/vmeintr.c, timer/timer.c, tod/tod.c,
vme/VMEConfig.h: Some clean up.
* mpc83xx/include/mpc83xx.h: #include <bspopts.h> to make sure
defines from bspopts.h get propagated.
* include/bsp.h: #include <bspopts.h> first.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Remove scitab.c (Not applicable).
* include/irq-config.h: New file.
* startup/spurious.c: Removed.
* Makefile.am, preinstall.am, PCI_bus/universe.c, console/console.c,
include/bsp.h, irq/FPGA.c, irq/irq.c, startup/Hwr_init.c,
startup/bspstart.c, startup/vmeintr.c: Modifications required to run
on hardware. Some cleanup.
* timer/timer.c: Eliminate uses of old benchmark timer names.
* include/tm27.h: Do not use set_vector.
* sh7750/score/ispsh7750.c, shgdb/score/ispshgdb.c: Fine tune
conditional so _CPU_ISR_install_vector is in CPU Kit now.
* Makefile.am, preinstall.am: Add timer driver stub.
* acinclude.m4: simsh4 folded into shsim.
* Makefile.am, preinstall.am, include/bsp.h, include/tm27.h,
trap34/console-io.c: Now builds cleanly for runs for SH1, SH2, and
SH4.
* include/syscall.h: New file.
* include/gdbsci.h: Removed.
* start/startfor340only.S: Remove (Unused).
* include/tm27.h: Now links all tests.
* simsh4/.cvsignore, simsh4/ChangeLog, simsh4/Makefile.am,
simsh4/README, simsh4/bsp_specs, simsh4/configure.ac,
simsh4/preinstall.am, simsh4/clock/ckinit.c,
simsh4/console/console.c, simsh4/include/.cvsignore,
simsh4/include/bsp.h, simsh4/include/coverhd.h,
simsh4/include/ramdisk.h, simsh4/include/syscall.h,
simsh4/include/tm27.h, simsh4/start/start.S,
simsh4/startup/hw_init.c, simsh4/startup/linkcmds,
simsh4/startup/linkcmds-le, simsh4/startup/linkcmds-le.coff,
simsh4/timer/timer.c, simsh4/tools/.cvsignore,
simsh4/tools/ChangeLog, simsh4/tools/Makefile.am,
simsh4/tools/configure.ac, simsh4/tools/runtest.in: Removed.
* Makefile.am: Eliminate bsp.am. Cleanup.
* shgdb/score/ispshgdb.c: Add dummy _CPU_ISR_install_vector.
* Makefile.am, preinstall.am: Now links all tests.
* include/tm27.h: New file.
