architecture variants now.
Next cache operations should work on most of cores now
rtems_cache_flush_entire_data()
rtems_cache_invalidate_entire_data()
rtems_cache_invalidate_entire_instruction()
Instruction cache invalidate works on the first level for now only.
Data cacache operations are extended to ensure flush/invalidate
on all cache levels.
The CP15 arm_cp15_data_cache_clean_all_levels() function extended
to continue through unified levels too (ctype = 4).
Updates #2782
Updates #2783
Disabling MMU requires complex cache flushing and invalidation
operations. There is almost no way how to do that right
on SMP system without stopping all other CPUs. On the other hand,
there is documented sequence of operations which should be used
according to ARM manual and it guarantees even distribution
of maintenance operations to other cores for last generation
of Cortex-A cores with multiprocessor extension.
This change could require addition of appropriate entry
to arm_cp15_start_mmu_config_table for some BSPs to ensure
that MMU table stays accessible after MMU is enabled
.begin = (uint32_t) bsp_translation_table_base,
.end = (uint32_t) bsp_translation_table_base + 0x4000,
.flags = ARMV7_MMU_DATA_READ_WRITE_CACHED
Updates #2782
Updates #2783
The basic data and instruction rage functions should be compatible
for all ARMv4,5,6,7 functions. On the other hand, some functions
are not portable, for example arm_cp15_data_cache_test_and_clean()
and arm_cp15_data_cache_invalidate() for all versions and there
has to be specialized version for newer cores.
arm_cache_l1_properties_for_level uses CCSIDR which is not present
on older chips.
Actual version is only experimental, needs more changes
and problem has been found on RPi1 with dlopen so there seems
to be real problem.
Updates #2783
Updates #2782
BSPs.
The original ARM architecture wide cache_.h is changed to dummy version
for targets not implementing/enablig cache at all.
The ARM targets equipped by cache should include
appropriate implementation.
Next options are available for now
c/src/lib/libbsp/arm/shared/armv467ar-basic-cache/cache_.h
basic ARM cache integrated on the CPU core directly
which requires only CP15 oparations
c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h
support for case where ARM L2C-310 cache controller
is used. It is accessible as mmaped peripheral.
c/src/lib/libbsp/arm/shared/armv7m/include/cache_.h
Cortex-M specific cache support
Updates #2782
Updates #2783
Updates #2782
Updates #2783
and maximal alignment.
There is need for unambiguous named and defined cache function
which should be called when code is updated, loaded
or is self-modifying.
There should be function to obtain maximal cache line length
as well. This function can and should be used for allocations
which can be used for data and or code and ensures that
there are no partial cache lines overlaps on start and
end of allocated region.
Updates #2782
base access.
The main reason for inclusion of minimum hypervisor related defines
is that current ARM boards firmware and loaders (U-boot for example)
start loaded operating system kernel in HYP mode to allow it take
control of virtualization (Linux/KVM for example).
Updates #2783
The current versions of U-boot start kernel/RTEMS application image
with instruction and data caches enabled and it sets exception
base register to new address after its self-relocation.
ldr r0, [r9, #GD_RELOCADDR] /* r0 = gd->relocaddr */
mcr p15, 0, r0, c12, c0, 0 /* Set VBAR */
Included changes in bsp_start_hook_0 restore default state to
allow RTEMS image to run after startup from newer U-boot version
on Raspberry Pi.
Clear interrupt enable registers in interrupt controller
to ensure that RTEMS starts from well defined state.
Updates #2783
Updates #2782
Updates #2783
The Termios modes are now an emum. Do not use them in #if expressions.
Update #2762.
Properly pass the stack aligned context to _CPU_Context_switch_altivec()
since _CPU_altivec_ctxt_off defined via ppc_context.
Update #2761.
There must be an isync after the mtmsr to ensure that the AltiVec is
enabled for subsequent instructions.
Close #2760.
The window underflow trap handler used %i5 which destroyed the %o5 of
the calling context. Bug introduced by
0d3b5d47429effb350448d9e9123a67db722109f.
Go back to the pre 0d3b5d47429effb350448d9e9123a67db722109f behaviour
and use the two unused instructions in the trap vector to optimize a
bit.
Close #2651.
Close #2502.
Close #2530.
Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz>
remarks.
Signed-off-by: Premysl Houdek <kom541000@gmail.com>
boot loader.
The default tms570ls3137_hdk variant is for building RTEMS
application image starting directly from start of Flash.
Variant tms570ls3137_hdk_with_loader skips 256kB at start
of Flash to allow use with application loader.
Parameters overlay module is initialized and cleared first.
It is used later to replace exception target vectors
only if that is required.
The application loader code with CPU and SDRAM setup
code has to provide well defined pattern of instructions
at addresses 0x00000000 and 0x0000001f, because only data
read accesses can be processed reliably by POM. The expected
instruction pattern can be seen in the next example
https://github.com/hornmich/tms570ls3137-hdk-sdram/blob/master/SDRAM_SCI_configuration/source/sys_intvecs.asm
Comments with detailed description of code, background
and reasons for selected approach have been included
in TMS570 bsp startup code.
tms570_sci_interrupt_last_close: do not wait for old data transmit.
We must not load registers (e.g. PSR) from the heir context area before
the heir stopped execution.
With this patch the write to PSR is divided into two steps. We first update
the current window pointer and then we restore the status registers and
enable traps. This allows us to move the first write to PSR to be before
the write to WIM, as there is now no risk that we get an interrupt where
the CWP and WIM would be inconsistent. We only need to make sure that we
do not use any of the non-global registers or instructions that affects
CWP for three instructions after the write.
In the earlier code the non-global %o1 register was used right after the
write to PSR, which required the use of three nop:s.
Close #2472.
Close #2470.
closes #2432.
Only the context of the console device was used and this is wrong in
case more than one APBUART device is available.
flush_data_cache uses R0 directly but doesn't list it as a clobbered
register. Compiling with -O3 made this code break, since the function
that calls flush_data_cache already uses r0.
closes #2416.
Updates #2405.
closes #2379.
there is no need to define access macros for field covering
whole registers. In addition, BSP_FLD32 does not work right
for field 32bit length.
Close #2373.
The update fixes breakage of TMS570 support after Alexander Krutwig
switch of RTEMS time read to timecounter mechanism
bsps: Convert clock drivers to use a timecounter
Mechanism to specify odd (non 1 Mhz) time base update frequencies
implemented after objections of Martin Galvan.
Code is adjusted to convert RTEMS configuration parameter
microseconds_per_tick to such odd base if
TMS570_PREFERRED_TC_FREQUENCY is specified appropriately.
The header files are generated by script make_header.py.
Current script's version can be found at:
https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python
Registers offsets and fields have been extracted from reference manual.
These files were left after running the script in the previous patch.
do
echo $b
# echo $g
-i $b
done
The e500v1 has no support for the ATB.
Update #2369.
Update #2369.
counter
timer interrupt was hard coded to 10 ms per tick.
Fix uses the setting of CONFIGURE_MICROSECONDS_PER_TICK to compute the correct start value for the counter
See for more information: http://permalink.gmane.org/gmane.os.rtems.user/22691
