path: root/c (unfollow)
2020-10-01leon,gr1553b: improve init checkDaniel Hellstrom1-3/+8
Check in init3 not needed since same data is already checked in init2 stage. Adds an extra check that the APB register space is available before accessing it. Closes #2331
2017-05-11bsps/arm: Fix bit field offset in GIC supportSebastian Huber1-1/+1
Close #3002.
2017-01-26Change version to 4.11.1.99Sebastian Huber1-1/+1
Update #2886.
2017-01-12GRETH: Interrupt Handler Uses Wrong EventsChristian Spindeldreier1-1/+1
closes #2796.
2016-11-03virtex4, virtex5 bsp.h: Use BSP_INTERRUPT_STACK_SIZE not user space ↵4.11.14.11.0Tim Cussins2-2/+2
CONFIGURE_INTERRUPT_STACK_SIZE closes #2801.
2016-10-02arm/tms570: document BSP setup with included hardware initialization.Pavel Pisa1-22/+100
2016-10-02arm/tms570: update bootstrap generated preinstall.amPavel Pisa1-0/+13
2016-10-02arm/tms570: include TMS570_USE_HWINIT_STARTUP option to select bare metal ↵Pavel Pisa2-0/+26
startup and selftest.
2016-10-02arm/tms570: include hardware initialization and selftest based on Ti ↵Pavel Pisa16-0/+3519
HalCoGen generated files. The configuration is specific for TMS570LS3137 based HDK. Pins configuration can be easily changed in rtems/c/src/lib/libbsp/arm/tms570/hwinit/init_pinmux.c file. The list tms570_selftest_par_list in the file rtems/c/src/lib/libbsp/arm/tms570/hwinit/bspstarthooks-hwinit.c specifies peripherals which health status is examined by parity self-test at BSP start-up. It can be easily modified for other TMS570 family members variants same as the selection of other tests in bspstarthooks-hwinit.c.
2016-10-02arm/tms570: define base addresses of all TMS570LS3137 SPI interfaces.Pavel Pisa1-1/+5
Generated header file ti_herc/reg_spi.h contains complete registers and fields set for Ti MibSPI peripheral. Care has to be taken that only TMS570_SPI1, TMS570_SPI3 and TMS570_SPI5 are of this complete multibuffer type. TMS570_SPI2 and TMS570_SPI4 have substantial part of registers removed but else they are compatible.
2016-10-02bsp/tms570: ensure that change of SCI baudrate is not applied in the middle ↵Pavel Pisa1-2/+23
of character Tx. The rtems_monitor_task() setups/updates termios attributes of the opened TTY and if there is ongoing some other output it leads to the stuck. It would be better to use some termios API function which would call drainOutput() in rtems/cpukit/libcsupport/src/termios.c. But functionality is not accessible outside of core termios implementation. The loop waiting for last character to be sent has to be there anyway because hardware does not provide Tx machine/shift register empty interrupt. Closes #2794
2016-10-02bsp/tms570: regenerate preinstall makefile by bootstrap -p.Pavel Pisa1-0/+8
2016-10-02bsp/tms570: include complete peripheral initialization to SCI driver.Pavel Pisa1-2/+36
Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz>
2016-10-02bsp/tms570: update pinmux to provide support for initialization lists and ↵Pavel Pisa4-69/+196
clear of alt outputs.
2016-10-02bsp/tms570: include package balls and PINMMR registers mapping for ↵Pavel Pisa2-0/+700
TMS570LS3135ZWT chip.
2016-10-02bsps/arm: Export bsp_start_hook_0_done symbol from ARM start.S.Pavel Pisa1-0/+1
The symbol can be used by bsp_start_hook_0 when complete RAM memory is initialization and overwritten during BSP self-test. The test overwrites even memory used to store return address / link register and regular resturn from bsp_start_hook_0 is not possible then.
2016-10-02arm/raspberrypi: minimized mainline patch move MMU in front of application ↵Pavel Pisa2-3/+4
image and correct RPi2 boot on 4.11 branch. This is minimized version of mainline patch arm/raspberrypi: move MMU in front of application image to respect variable memory size. plus correction which has been part of other mainline patches. This is end of series which allows 4.11 to boot on Raspberry Pi. Closes #2782 Closes #2783
2016-10-02arm/raspberrypi: change interrupt dispatch and enable to generic vector id ↵Pavel Pisa2-43/+94
based approach. Using conditional branches to find bits is extremely inefficient and for asynchronous delivery of different interrupt sources lead to total confusion of branch prediction unit. Updates #2783
2016-10-02arm/raspberrypi: remove duplicate setup of IRQ handler in the main ARM ↵Pavel Pisa2-21/+0
exception table. Exception table setup is processed by common CPU architecture support. For ARM architecture, it can be found in the file rtems/c/src/lib/libbsp/arm/shared/start/start.S and ends by bsp_vector_table_copy_done label. The actual tabel content can be found at bsp_start_vector_table_begin For ARMv7-A and even other variant with hypervisor mode support, it is even not necessary to copy table to address 0 at all because CP15 register can be used to specify alternative table start address arm_cp15_set_vector_base_address(&)bsp_start_vector_table_begin; ARMv7-M have register to set exception table base as well. Updates #2783
2016-10-02arm/raspberrypi: ensure that correct RPI_PERIPHERAL_BASE is provided by ↵Pavel Pisa2-0/+2
raspberrypi.h If the raspberrypi.h has been included without preceding inclussion of bsp.h then BSP_IS_RPI2 has not been set for Raspberry Pi 2 BSP variant and bad things happen later. The patch includes bspopts.h by raspberrypi.h and even includes bsp.h in critical peripherals support. Updates #2783
2016-10-02arm/raspberrypi: reorder and update MMU config table to nor force RW section ↵Pavel Pisa1-9/+22
later to RO. Enable even the first megabyte of SDRAM to be cache-able after problems with stale cache content has been resolved by previous commit. Because major part of application usually fits to the first megabyte this speedups test dhrystone application by factor 40. Updates #2783
2016-10-02arm/raspberrypi: Enable HYP to SVC switch for this BSP.Pavel Pisa2-0/+7
This support is required when newer firmware is used on Raspberry Pi 2 boards. Updates #2783
2016-10-02bsps/arm: Support recent bootloaders starting kernel in HYP modePavel Pisa5-7/+175
When HYP mode is detected at startup then setup HYP mode vectors table (for future extensions) clean exceptions switching to HYP mode and switch CPU to ARM SVC mode. BSPs which want to use this support need to include next option in their configure.ac RTEMS_BSPOPTS_SET([BSP_START_IN_HYP_SUPPORT],[*],[1]) RTEMS_BSPOPTS_HELP([BSP_START_IN_HYP_SUPPORT], [Support start of BSP in ARM HYP mode]) AM_CONDITIONAL(BSP_START_IN_HYP_SUPPORT,test "$BSP_START_IN_HYP_SUPPORT" = "1") and need to include next lines in corresponding Makefile.am if BSP_START_IN_HYP_SUPPORT libbsp_a_SOURCES += ../shared/startup/bsp-start-in-hyp-support.S endif Updates #2783
2016-10-02libbsp/arm: Fix ARM BSPs missing the bsp_translation_table_end symbol.Chris Johns2-0/+2
Closes #2775.
2016-10-02libbsp/arm: Add the TTB table to the default MMU set up as read/write.Chris Johns1-0/+4
This lets the table be changed at runtime for dynamic loading and debugger support. Closes #2775.
2016-10-02bsps/arm: Fix basic cache support for SMPSebastian Huber1-8/+8
Updates #2782 Updates #2783
2016-10-02bsps/arm: reorganize CP15 code to allow clean and invalidate ARMv7 cache by ↵Pavel Pisa1-48/+60
level. New function arm_cp15_cache_invalidate_level and arm_cp15_cache_clean_level can be used to maintain single cache level (instruction or data). Updates #2782 Updates #2783
2016-10-02bsps/arm: remove lock in arm_cp15_set_translation_table_entries().Pavel Pisa1-9/+1
Protection by rtems_interrupt_disable() is incompatible with SMP build. Actual page table entries manipulation function does not need locking and disabling cache and can be run concurrently even on multiple CPUs as long as changes do not modify same region. If the function is called from more threads/CPUs to modify same region with different mapping options concurrently then there is problem at another level of virtual address space management and has to be solved by mutex or other locking at that level. Updates #2782 Updates #2783
2016-10-02bsps/arm: use defines for cache type register format field.Pavel Pisa1-9/+30
The change documents meaning of codes and opens well defined way to use cache type format for cache examination/debugging outside of arm-cp15.h file. Updates #2782 Updates #2783
2016-10-02arm/xilinx_zynq: ensure that cache is cleaned and MMU disabled when ↵Pavel Pisa1-0/+35
initialization starts. The u-boot loader enables the MMU plus the data and instruction caches in some versions which results in RTEMS boot failure. Closes #2774.
2016-10-02arm/raspberrypi: use cache manager operations to flush/invalidate all cache ↵Pavel Pisa1-7/+7
levels. This fix strange behavior where some stale content has been stored in level 2 cache before RTEMS has been start from U-boot which has reappeared after MMU enable and shadow vector table at start of SDRAM. Updates #2782 Updates #2783
2016-10-02arm/bsps: CP15 and basic cache support entire cache clean for more ↵Pavel Pisa3-6/+66
architecture variants now. Next cache operations should work on most of cores now rtems_cache_flush_entire_data() rtems_cache_invalidate_entire_data() rtems_cache_invalidate_entire_instruction() Instruction cache invalidate works on the first level for now only. Data cacache operations are extended to ensure flush/invalidate on all cache levels. The CP15 arm_cp15_data_cache_clean_all_levels() function extended to continue through unified levels too (ctype = 4). Updates #2782 Updates #2783
2016-10-02bsps/arm: do not disable MMU during translation table management operations.Pavel Pisa2-8/+58
Disabling MMU requires complex cache flushing and invalidation operations. There is almost no way how to do that right on SMP system without stopping all other CPUs. On the other hand, there is documented sequence of operations which should be used according to ARM manual and it guarantees even distribution of maintenance operations to other cores for last generation of Cortex-A cores with multiprocessor extension. This change could require addition of appropriate entry to arm_cp15_start_mmu_config_table for some BSPs to ensure that MMU table stays accessible after MMU is enabled { .begin = (uint32_t) bsp_translation_table_base, .end = (uint32_t) bsp_translation_table_base + 0x4000, .flags = ARMV7_MMU_DATA_READ_WRITE_CACHED } Updates #2782 Updates #2783
2016-10-02bsps/arm: basic on core cache support changed to use l1 functions.Pavel Pisa3-48/+97
The basic data and instruction rage functions should be compatible for all ARMv4,5,6,7 functions. On the other hand, some functions are not portable, for example arm_cp15_data_cache_test_and_clean() and arm_cp15_data_cache_invalidate() for all versions and there has to be specialized version for newer cores. arm_cache_l1_properties_for_level uses CCSIDR which is not present on older chips. Actual version is only experimental, needs more changes and problem has been found on RPi1 with dlopen so there seems to be real problem. Updates #2783 Updates #2782
2016-10-02bsps/arm: Change code to explicit selection of cache implementation for ARM ↵Pavel Pisa10-124/+190
BSPs. The original ARM architecture wide cache_.h is changed to dummy version for targets not implementing/enablig cache at all. The ARM targets equipped by cache should include appropriate implementation. Next options are available for now c/src/lib/libbsp/arm/shared/armv467ar-basic-cache/cache_.h basic ARM cache integrated on the CPU core directly which requires only CP15 oparations c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h support for case where ARM L2C-310 cache controller is used. It is accessible as mmaped peripheral. c/src/lib/libbsp/arm/shared/armv7m/include/cache_.h Cortex-M specific cache support Updates #2782 Updates #2783
2016-10-02bsp/arm: Report correct maximal cache line length for ARM Cortex-A + L2C-310.Pavel Pisa1-0/+4
2016-10-02rtems+bsps/cache: Define cache manager operations for code synchronization ↵Pavel Pisa1-0/+42
and maximal alignment. There is need for unambiguous named and defined cache function which should be called when code is updated, loaded or is self-modifying. There should be function to obtain maximal cache line length as well. This function can and should be used for allocations which can be used for data and or code and ensures that there are no partial cache lines overlaps on start and end of allocated region. Updates #2782
2016-10-02arm/score and shared: define ARM hypervisor mode and alternate vector table ↵Pavel Pisa1-0/+30
base access. The main reason for inclusion of minimum hypervisor related defines is that current ARM boards firmware and loaders (U-boot for example) start loaded operating system kernel in HYP mode to allow it take control of virtualization (Linux/KVM for example). Updates #2783
2016-10-02arm/raspberrypi: ensure that RTEMS application image can be started by U-boot.Pavel Pisa2-1/+39
The current versions of U-boot start kernel/RTEMS application image with instruction and data caches enabled and it sets exception base register to new address after its self-relocation. ldr r0, [r9, #GD_RELOCADDR] /* r0 = gd->relocaddr */ mcr p15, 0, r0, c12, c0, 0 /* Set VBAR */ Included changes in bsp_start_hook_0 restore default state to allow RTEMS image to run after startup from newer U-boot version on Raspberry Pi. Clear interrupt enable registers in interrupt controller to ensure that RTEMS starts from well defined state. Updates #2783
2016-10-02bsps/arm: CP15 support for flush prefetch buffer and table base control.Pavel Pisa1-0/+48
2016-07-19bsps/powerpc: Fix shared console driverSebastian Huber1-13/+9
The Termios modes are now an emum. Do not use them in #if expressions. Update #2762.
2016-07-19bsps/powerpc: Fix AtliVec context switchSebastian Huber2-62/+68
Properly pass the stack aligned context to _CPU_Context_switch_altivec() since _CPU_altivec_ctxt_off defined via ppc_context. Update #2761.
2016-07-19bsps/powerpc: Fix AltiVec enableSebastian Huber3-0/+3
There must be an isync after the mtmsr to ensure that the AltiVec is enabled for subsequent instructions. Close #2760.
2016-03-24sparc: Fix window underflow trap handlerDaniel Hellstrom2-7/+7
The window underflow trap handler used %i5 which destroyed the %o5 of the calling context. Bug introduced by 0d3b5d47429effb350448d9e9123a67db722109f. Go back to the pre 0d3b5d47429effb350448d9e9123a67db722109f behaviour and use the two unused instructions in the trap vector to optimize a bit. Close #2651.
2016-01-27score: Fix simple timecounter supportSebastian Huber12-122/+188
Close #2502.
2016-01-18bsps/arm: Fix broken switch statementSebastian Huber1-4/+5
Close #2530.
2016-01-11Clearly mark SMP support as experimental in 4.11Sebastian Huber1-3/+7
2015-12-01bsp/tms570: ensure that linker symbol comparison to NULL is not optimized out.Pavel Pisa1-2/+12
2015-11-18bsp/tms570: unite code duplication in pinmux and clean SCI close per review ↵Premysl Houdek3-18/+21
remarks. Signed-off-by: Premysl Houdek <kom541000@gmail.com>
2015-11-18bsp/tms570: use common tms570ls3137.inc file for all board ling variants.Pavel Pisa5-64/+24
