* | LEON: move driver headers to bsp/ directory | Daniel Hellstrom | 2015-04-17 | 58 | -432/+432 |
* | MCTRL: fix build warnings in MCTRL driver | Daniel Hellstrom | 2015-04-17 | 6 | -0/+38 |
* | AMBAPP GRLIB: fix build warnings | Daniel Hellstrom | 2015-04-17 | 1 | -0/+3 |
* | LEON2: fix build warnings | Daniel Hellstrom | 2015-04-17 | 1 | -22/+11 |
* | AMBAPP_BUS: fix build warnings | Daniel Hellstrom | 2015-04-17 | 1 | -23/+18 |
* | LEON CONS: fix build warnings | Daniel Hellstrom | 2015-04-17 | 1 | -1/+1 |
* | GR-TMTC-1553: fix build warnings | Daniel Hellstrom | 2015-04-17 | 2 | -12/+16 |
* | GR-RASTA-TMTC: fix build warnings | Daniel Hellstrom | 2015-04-17 | 2 | -17/+20 |
* | GR-RASTA-SPW-ROUTER: fix build warnings | Daniel Hellstrom | 2015-04-17 | 2 | -11/+11 |
* | GR-RASTA-IO: fix build warnings | Daniel Hellstrom | 2015-04-17 | 2 | -17/+16 |
* | GR-RASTA-ADCDAC: fix build warnings | Daniel Hellstrom | 2015-04-17 | 2 | -15/+16 |
* | GR-LEON4-N2X: fix build warnings | Daniel Hellstrom | 2015-04-17 | 2 | -12/+14 |
* | GR_701: fix build warnings | Daniel Hellstrom | 2015-04-17 | 2 | -13/+14 |
* | GRGPIO: fix buld warnings | Daniel Hellstrom | 2015-04-17 | 1 | -9/+9 |
* | GPIOLIB: fix build warnings | Daniel Hellstrom | 2015-04-17 | 1 | -10/+5 |
* | GRADCDAC: fix build warnings | Daniel Hellstrom | 2015-04-17 | 1 | -2/+2 |
* | GENIRQ: fix build warnings | Daniel Hellstrom | 2015-04-17 | 1 | -1/+6 |
* | GRPWM: fix build warnings | Daniel Hellstrom | 2015-04-17 | 1 | -6/+12 |
* | SPWCUC: fix build warnings | Daniel Hellstrom | 2015-04-17 | 1 | -2/+2 |
* | SPICTRL: fix build warnings | Daniel Hellstrom | 2015-04-17 | 1 | -10/+19 |
* | GRSPW router: fix build warnings | Daniel Hellstrom | 2015-04-17 | 2 | -13/+28 |
* | GRSPW_PKT: fix build warnings | Daniel Hellstrom | 2015-04-17 | 2 | -1/+4 |
* | TLIB: fix build warnings | Daniel Hellstrom | 2015-04-17 | 1 | -0/+13 |
* | TLIB Clock: fix build warnings | Daniel Hellstrom | 2015-04-17 | 1 | -1/+2 |
* | GRASCS: fix build warnings | Daniel Hellstrom | 2015-04-17 | 1 | -1/+1 |
* | GRCTM: fix build warnings | Daniel Hellstrom | 2015-04-17 | 2 | -1/+4 |
* | GRTM: fix build warnings | Daniel Hellstrom | 2015-04-17 | 2 | -4/+9 |
* | GRTC: fix build warnings | Daniel Hellstrom | 2015-04-17 | 2 | -16/+16 |
* | LEON: GRPCI2 driver warning fixes | Daniel Hellstrom | 2015-04-17 | 1 | -10/+11 |
* | LEON: I2CMST driver warnings fixes | Daniel Hellstrom | 2015-04-17 | 2 | -1/+4 |
* | LEON: OCCAN driver warnings fixes | Daniel Hellstrom | 2015-04-17 | 1 | -2/+5 |
* | LEON: B1553BRM driver warnings fixes | Daniel Hellstrom | 2015-04-17 | 2 | -3/+8 |
* | LEON: B1553RT driver warnings fixes | Daniel Hellstrom | 2015-04-17 | 2 | -4/+6 |
* | LEON: added get_resarray_count() helper routine | Daniel Hellstrom | 2015-04-17 | 7 | -0/+63 |
* | GR1553B: fixed build warnings | Daniel Hellstrom | 2015-04-17 | 5 | -56/+64 |
* | AT697PCI: fix build warnings | Daniel Hellstrom | 2015-04-17 | 4 | -12/+43 |
* | GPTIMER: move ISR install from init1 | Daniel Hellstrom | 2015-04-17 | 1 | -11/+18 |
| | | | | | To avoid install ISRs during init level 1 the ISR install is moved to the opening/initialization of the timer. | ||||
* | GPTIMER: fix build warnings | Daniel Hellstrom | 2015-04-17 | 7 | -3/+47 |
* | APBUART_CONS: fix build warning | Daniel Hellstrom | 2015-04-17 | 5 | -4/+27 |
* | GR-RASTA-SPW-ROUTER: fix build warnings | Daniel Hellstrom | 2015-04-17 | 7 | -7/+60 |
* | PCIF: fixed build warnings | Daniel Hellstrom | 2015-04-17 | 7 | -13/+39 |
* | GRPCI: fixed build warnings | Daniel Hellstrom | 2015-04-17 | 7 | -12/+63 |
* | GRSPW: fix build warnings | Daniel Hellstrom | 2015-04-17 | 1 | -4/+1 |
* | LEON3: watchdog use common timer defines | Daniel Hellstrom | 2015-04-17 | 1 | -1/+1 |
* | LEON3: export debug uart to console uart driver | Daniel Hellstrom | 2015-04-17 | 1 | -1/+1 |
* | GRETH: fix build warnings with GCC-4.9 | Daniel Hellstrom | 2015-04-17 | 2 | -21/+24 |
* | GPTIMER: avoid build warnings | Daniel Hellstrom | 2015-04-17 | 1 | -10/+10 |
* | AHBSTAT: fix build warnings | Daniel Hellstrom | 2015-04-17 | 2 | -2/+5 |
* | GRTM: fixed descriptor TS bit declaration | Daniel Hellstrom | 2015-04-17 | 1 | -4/+5 |
* | GRSPW_PKT: grspw_status renamed in header | Daniel Hellstrom | 2015-04-17 | 1 | -1/+1 |
