* src/threadinitialize.c: Per PR181, clear the array of user extension
pointers. This lets user extensions that have hooked the switch handler
know if a task has been processed by the user extension before. If a
user extension is created after a task is started it may not know it.
* include/Makefile.am: Add stdint.h and inttypes.h.
(reported by Mike Siers <mikes@poliac.com>)
* include/stdint.h: New file.
* include/inttypes.h: New file.
* network/rtems_bsdnet.h: To address PR59, added the drv_ctrl driver
control block field to the ifconfig network driver structure. This
field is needed by the i82586 driver which was ported from NetBSD
as it had better hardware abstraction.
* c/src/libnetworking/rtems/rtems_bsdnet.h: To address PR59, added
the drv_ctrl driver control block field to the ifconfig network driver
structure. This field is needed by the i82586 driver which was ported
from NetBSD as it had better hardware abstraction.
* tbr/Makefile.am: Remove.
* tbr/.cvsignore: Remove.
* tbr/tbr.c: Remove.
* tbr/tbr.h: Remove.
* configure.ac: Remove tbr subdir.
* Makefile.am: Remove tbr subdir.
* include/rtems/system.h: Add i386 to multilib-able targets.
* cache.c: Include <rtems/score/registers.h> instead of
<libcpu/registers.h>.
* cpu.h: Ditto. Remove parts moved to score/cpu/i386.
* registers.h: Add BIG-FAT warning.
* rtems/score/idtr.h: New file, extracted from libcpu/cpu.h.
* rtems/score/interrupts.h: New file, extracted from libcpu/cpu.h.
* rtems/score/registers.h: New file, moved from libcpu.
* cpu.c: Don't include cpuModel.h,
#include <rtems.h>,
#include <rtems/score/i386types.h>,
#include <rtems/score/idtr.h>.
* rtems/score/cpu.h: Don't include libcpu/cpu.h.
#include <rtems/score/interrupts.h>,
#include <rtems/score/registers.h>.
* macros/rtems/score/userext.inl: Now works after merging patch for
functionality requested in PR174.
* inline/rtems/score/userext.inl: Added a comment explaining the
order in which routines appear since it is not the obvious order.
* Per PR141 and PR174, make task switch extension its own list and
fix all odd problems introduced by providing macro version.
* inline/rtems/score/userext.inl: Fix.
* libc/stat.c: include <string.h>.
* libc/printk.c: Remove libcpu/cpu.h.
* src/ramdisk.c: include <string.h>.
* src/blkdev.c: include <string.h>.
* src/imfs/imfs_getchild.c: include <string.h>.
* src/imfs/imfs_gtkn.c: Include <string.h>.
* src/imfs/ioman.c: Include <string.h>.
* src/imfs/linearfile.c: Include <string.h>.
* src/imfs/memfile.c: Include <string.h>.
* console-generic/console-generic.c: Remove unused variable "res".
* score/cpu_asm.c: Adapt inline asm to gcc-3.0.4.
* configure.ac: Add BSPOPTS_*(DISPATCH_HANDLER_STAT).
Remove RTEMS_ENABLE_LIBCDIR.
* include/mvme16x_hw.h: Include <bsp.h> instead of targopts.h.
* include/rtems/bspIo.h: Fix cpp-guards, remove references to i386.
* rtems.c: Adaptation to gcc-3.0.x.
* src/psignal.c: Include <stdlib.h>.
* ChangeLog: Fix dates.
* src/tasks.c: Pre-initialized switch extension for list.
* macros/rtems/score/timer.inl: Corrected typo on end of line.
* macros/rtems/score/object.inl: Corrected arguments.
* macros/rtems/score/userext.inl: Updated to reflect modifications
to inline version from PR142.
* inline/rtems/score/userext.inl: Cleanup as side-effect of above.
* Per PR142, make task switch extension its own list.
* include/rtems/score/userext.h: Reflect above by adding
User_extensions_Switch_control and adding it to User_extenions_Control.
* inline/rtems/score/userext.inl: Allocate all memory in one chunk
to minimize overhead. Address processing dedicated switch chain.
* src/tasks.c (_RTEMS_tasks_User_extensions): Reflect above.
* src/pthread.c (_POSIX_Threads_User_extensions): Reflect above.
* startup/linkcmds, startup/linkcmds.dl : Per PR170, PR171, and PR172
add .eh_frame.
* startup/linkcmds: Per PR170, PR171, and PR172 add .eh_frame
* spsize/size.c: Reflect SPARC modifcation to get rid of
NO_TABLE_MOVE and references to _CPU_Trap_Table_area.
* src/dosfs/Makefile.am: Per PR129 do not install as many files
to the $(includedir).
* monitor/mon-monitor.c: Replace done with return (gcc3).
* src/dosfs/fat.h: Include <string.h>.
Remove DBG1 and DBG2 (unused).
* network/i82586.c: Include <string.h>.
* network/sonic.c: Ditto.
* Per PR169.
* src/dosfs/config.h.in, src/dosfs/stamp-h2.in: Removed from CVS.
* Closed PR57. The hack is OK as it allows a BSP to override
or not at its discretion.
* mpc8xx/timer/timer.c: Removed #warning declaring providing a
default definition for the macros
rtems_cpu_configuration_get_timer_least_valid and
rtems_cpu_configuration_get_timer_average_overhead.
* libc/ctermid.c: Include <string.h>.
* libc/ttyname.c: Ditto.
* libc/ttyname_r.c: Ditto.
* shared/include/byteorder.h: Use unsigned instead of __unsigned
(GCC-3.0.x compatibility).
* residual/residual.c: Include <string.h>.
* vectors/vectors_init.c: Include <rtems/bspIo.h> for printk.
* bootloader/mm.c: Ditto.
* bootloader/pci.c: Ditto.
* console/console.c: Ditto.
* openpic/openpic.c: Ditto.
* bootloader/Makefile.am: Use automake-1.6 AS compilation rules.
* src/getegid.c: Remove <errno.h>.
* src/geteuid.c: Ditto.
* src/getgid.c: Ditto.
* src/getuid.c: Ditto.
* src/getlogin.c: Move <errno.h>.
* configure.ac: AC_DEFINE(CPU_U32_FIX) for sparc.
* configure.ac: Remove BSPOPTS_*(NO_TABLE_MOVE).
Remove BSPOPTS_*(FPU_REVB).
* wrapup/Makefile.am: Remove tbr.
* configure.ac: Remove AC_EXEEXT (obsolete).
* cpu.c: Remove call to sparc_init_tbr/NO_TABLE_MOVE.
* rtems/score/cpu.h: Remove NO_TABLE_MOVE conditional code.
