1996-05-29 | added entry point for posix initialization threads to the posix initialization | Joel Sherrill | 2 | -4/+16 | |
threads table structure | |||||
1996-05-29 | Addressed RTEMS API initialization tasks table in a system without | Joel Sherrill | 2 | -6/+14 | |
RTEMS initialization tasks. | |||||
1996-05-29 | Gutted test of rtems api calls and added comments to indicate what the test | Joel Sherrill | 3 | -77/+31 | |
should do in their place. It now compiles and links. | |||||
1996-05-29 | Added default POSIX API configuration table. | Joel Sherrill | 1 | -1/+13 | |
1996-05-29 | It is now not an error to have 0 RTEMS initialization tasks since you could | Joel Sherrill | 1 | -0/+6 | |
create POSIX initialization threads. | |||||
1996-05-29 | renamed signal.c to psignal.c to avoid naming problems. | Joel Sherrill | 5 | -7/+119 | |
added mp stubs to cond.c and mutex.c to eliminate link errors. added pthread_exit to pthread.c | |||||
1996-05-28 | split the inclusion of "EXTERN" data based on whether it was sapi, | Joel Sherrill | 93 | -226/+372 | |
score, rtems api, or posix api related. | |||||
1996-05-28 | added maximum keys | Joel Sherrill | 2 | -2/+2 | |
1996-05-28 | added enumerated constant for the POSIX API as an error source | Joel Sherrill | 2 | -2/+4 | |
1996-05-28 | added initial set of api extension callouts | Joel Sherrill | 5 | -6/+166 | |
1996-05-28 | new file | Joel Sherrill | 1 | -0/+72 | |
1996-05-28 | commented out interrupt support | Joel Sherrill | 2 | -0/+4 | |
1996-05-28 | added ifndef's for the POSIX maximum field in the POSIX api configuration table | Joel Sherrill | 2 | -2/+12 | |
1996-05-28 | added posix api initialization call to init.c | Joel Sherrill | 2 | -1/+5 | |
deleted a blank line in rtemsapi.c | |||||
1996-05-28 | comment cleanup | Joel Sherrill | 2 | -4/+2 | |
1996-05-28 | added maximum keys | Joel Sherrill | 2 | -0/+2 | |
1996-05-28 | made posix configuration information conditional so configurations wanting | Joel Sherrill | 4 | -2/+98 | |
only the rtems api don't have to include it. | |||||
1996-05-28 | fixed typo | Joel Sherrill | 1 | -1/+1 | |
1996-05-28 | changed call to _ISR_Enable() to _ISR_Set_level() in _Thread_Handler. | Joel Sherrill | 1 | -1/+1 | |
_ISR_Enable() takes the magic cookie expected by the cpu's status register instead of a simple isr level. | |||||
1996-05-28 | added initial posix configuration support | Joel Sherrill | 34 | -107/+326 | |
1996-05-24 | new file | Joel Sherrill | 14 | -0/+337 | |
1996-05-24 | changed version to 3.5.17 | Joel Sherrill | 2 | -2/+2 | |
1996-05-24 | added Motorola MVME147 BSP submitted by Dominique le Campion | Joel Sherrill | 11 | -0/+1427 | |
(Dominique.LECAMPION@enst-bretagne.fr), for Telecom Bretagne and T.N.I. (Brest, France) | |||||
1996-05-24 | changed joel's email address | Joel Sherrill | 1 | -4/+4 | |
1996-05-24 | added acknowledgement for Motorola MVME147 from Dominique le Campion | Joel Sherrill | 1 | -0/+4 | |
1996-05-24 | new file | Joel Sherrill | 1 | -0/+50 | |
1996-05-24 | updates from Tony Bennett to correct calling sequences. | Joel Sherrill | 2 | -0/+2 | |
1996-05-24 | new files | Joel Sherrill | 3 | -4/+111 | |
1996-05-24 | updates to fix typos | Joel Sherrill | 3 | -35/+35 | |
1996-05-24 | new file | Mark Johannes | 1 | -0/+22 | |
1996-05-24 | added use of sporadic server scheduling parameters | Joel Sherrill | 7 | -0/+58 | |
1996-05-24 | new files | Joel Sherrill | 3 | -0/+96 | |
1996-05-23 | clean up on DELAYTIMER_MAX | Joel Sherrill | 3 | -12/+0 | |
1996-05-23 | new files | Joel Sherrill | 6 | -0/+204 | |
1996-05-23 | unused variable | Joel Sherrill | 1 | -1/+0 | |
1996-05-23 | new files | Joel Sherrill | 8 | -0/+208 | |
1996-05-23 | new files | Joel Sherrill | 7 | -0/+184 | |
1996-05-23 | new files | Joel Sherrill | 3 | -0/+75 | |
1996-05-23 | new files | Joel Sherrill | 5 | -0/+144 | |
1996-05-23 | new files | Joel Sherrill | 4 | -0/+110 | |
1996-05-23 | cleanup | Joel Sherrill | 8 | -12/+12 | |
1996-05-23 | new files | Joel Sherrill | 8 | -0/+254 | |
1996-05-23 | cleanup status vs. result | Joel Sherrill | 29 | -48/+48 | |
1996-05-23 | new files | Joel Sherrill | 5 | -0/+152 | |
1996-05-23 | new files | Joel Sherrill | 4 | -0/+134 | |
1996-05-23 | new files | Joel Sherrill | 2 | -0/+60 | |
1996-05-23 | new files | Joel Sherrill | 6 | -0/+200 | |
1996-05-23 | new files | Joel Sherrill | 9 | -0/+288 | |
1996-05-23 | updated to reflect more constants and feature macros | Joel Sherrill | 34 | -5/+160 | |
1996-05-23 | updates from Tony Bennett | Joel Sherrill | 12 | -102/+139 | |
