2015-03-06 | Add fsscandir01 variants as needed to more BSPs testsuite configuration | Joel Sherrill | 21 | -0/+25 | |
2015-03-06 | Temporarily ignore dl* tests on some PowerPC BSPs | Joel Sherrill | 9 | -0/+45 | |
Some BSPs have issues linking the dl* tests. These issues have not been investigated. This is a temporary workaround until we have an explanation and permanent solution. updates 2258. | |||||
2015-03-06 | Always disable networking for h8300 | Joel Sherrill | 9 | -1/+10 | |
2015-03-06 | Temporarily disable libdl tests on some MIPS BSPSs | Joel Sherrill | 3 | -0/+15 | |
These BSPs are little endian while most are big endian. The dl tool does not support the -EL option yet. updates 2279. | |||||
2015-03-06 | raspberrypi: Do not include default IRQ handler and BSP specific one | Joel Sherrill | 1 | -1/+0 | |
This was tripping a linker error in the dl0[12] tests. closes 2247. | |||||
2015-03-06 | lpc1768_mbed_ahb_ram-testsuite.tcfg: Add ftp01 | Joel Sherrill | 1 | -0/+1 | |
2015-03-06 | lpc1768_mbed_ahb_ram.tcfg: Remove as it is a junk file | Joel Sherrill | 1 | -7/+0 | |
This file does not have "-testsuite" in the name and is ignored by the build system. | |||||
2015-03-06 | Fix a number of minor Doxygen formatting issues | Joel Sherrill | 1 | -1/+1 | |
2015-03-05 | bsps: Use interrupt lock for interrupt server | Sebastian Huber | 1 | -10/+23 | |
2015-03-05 | bsp/qoriq: Fix warning | Sebastian Huber | 1 | -2/+1 | |
2015-03-05 | libmd: Disable SHA modules for m32c | Sebastian Huber | 1 | -0/+3 | |
Close #2219. | |||||
2015-03-05 | libchip/serial: Fix warning | Sebastian Huber | 1 | -2/+1 | |
2015-03-05 | bsps: Fix warning | Sebastian Huber | 1 | -2/+1 | |
2015-03-03 | mips BSPs: Remove .global for unprovided symbol | Joel Sherrill | 4 | -4/+0 | |
closes 2253 | |||||
2015-02-27 | ARM: Add BSP_START_NEEDS_REGISTER_INITIALIZATION | Martin Galvan | 4 | -0/+139 | |
This patch adds the macro BSP_START_NEEDS_REGISTER_INITIALIZATION and three hooks for BSP-specific register init code to arm/shared/start.S. Said hooks are bsp_start_init_registers_core (intended for initializing the ARM core registers), bsp_start_init_registers_banked_fiq (for the FIQ mode banked registers) and bsp_start_init_registers_vfp (for the FPU registers). BSP_START_NEEDS_REGISTER_INITIALIZATION would be defined in a BSP's configure.ac (so that it appears in its bspopts.h). This patch also adds the register init code required by the TMS570. We've tested it with the tms570ls3137_hdk.cfg config and it works fine. | |||||
2015-02-23 | sparc64: fix copyright notices. | Gedare Bloom | 8 | -34/+14 | |
The sparc64 port had some incorrect copyright notices affixed to source code files. | |||||
2015-02-20 | ARM: Support VFP-D16 | Martin Galvan | 1 | -3/+5 | |
This patch allows the existing FPU code to support both VFP-D16 and VFP-D32. According to ARM, writes to D32DIS are ignored for D16 so there's no need to enclose the bic instruction with an #ifdef. We tested it on a TMS570LS3137 using TI initialization code and it works fine. Signed-off by: Martin Galvan <martin.galvan@tallertechnologies.com> | |||||
2015-02-17 | score: Add _CPU_SMP_Prepare_start_multitasking() | Sebastian Huber | 4 | -8/+19 | |
Update #2268. | |||||
2015-02-13 | lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add ftp01 | Joel Sherrill | 1 | -0/+1 | |
2015-02-13 | lpc1768_mbed-testsuite.tcfg: Add ftp01 | Joel Sherrill | 1 | -0/+1 | |
2015-02-12 | IMFS: Add fine grained configuration | Sebastian Huber | 1 | -1/+0 | |
Remove miniIMFS. Statically initialize the root IMFS. Add configuration options to disable individual features of the root IMFS, e.g. o CONFIGURE_IMFS_DISABLE_CHOWN, o CONFIGURE_IMFS_DISABLE_FCHMOD, o CONFIGURE_IMFS_DISABLE_LINK, o CONFIGURE_IMFS_DISABLE_MKNOD, o CONFIGURE_IMFS_DISABLE_MOUNT, o CONFIGURE_IMFS_DISABLE_READLINK, o CONFIGURE_IMFS_DISABLE_RENAME, o CONFIGURE_IMFS_DISABLE_RMNOD, o CONFIGURE_IMFS_DISABLE_SYMLINK, o CONFIGURE_IMFS_DISABLE_UNMOUNT, and o CONFIGURE_IMFS_DISABLE_UTIME. | |||||
2015-02-11 | grspw: Fix typos | Daniel Cederman | 1 | -3/+3 | |
2015-02-11 | bsp/sparc: Move BSP_ISR_handler to a separate file and rename it | Daniel Cederman | 9 | -23/+59 | |
This allows it to be wrapped by another function at link-time and can be used to trace interrupts. If not placed in a separate file, the function pointer address used in BSP_shared_interrupt_init will be resolved at compile-time, and the function will not be wrappable. | |||||
2015-02-09 | Filesystem: Delete unused fsmountme_h handler | Sebastian Huber | 1 | -1/+0 | |
2015-02-04 | arm/tms570: sci context has to be writable because it holds state variable. | Pavel Pisa | 2 | -4/+4 | |
The structure tms570_sci_context holds state variable tx_chars_in_hw which holds if and how many characters (in the optional FIFO support for some Ti SCIs) are submitted into hardware. When field is not writable then code breaks when RTEMS is build for Flash area. The problem found and analyzed by Martin Galvan from tallertechnologies. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> | |||||
2015-01-30 | bsps/powerpc: Fix a clock driver | Nick Withers | 1 | -9/+57 | |
PowerPC Book E: Account for an extra tick period if a tick increment's pending. Close #2230. | |||||
2015-01-23 | mcf5206elite/include/i2c.h: Fix spelling error | Joel Sherrill | 1 | -1/+1 | |
2015-01-23 | stm32f4/.../stm32f105rc-testsuite.tcfg: Add more tests | Joel Sherrill | 1 | -0/+1 | |
2015-01-23 | lpc24xx/.../lpc23xx_tli800-testsuite.tcfg: Add more tests | Joel Sherrill | 1 | -0/+7 | |
2015-01-23 | lpc24xx/.../lpc2362-testsuite.tcfg: Add more tests | Joel Sherrill | 1 | -0/+2 | |
2015-01-23 | lm3s69xx/.../lm3s6965-testsuite.tcfg: Add more tests | Joel Sherrill | 1 | -0/+1 | |
2015-01-23 | lm3s69xx/.../lm3s3749-testsuite.tcfg: Add more tests | Joel Sherrill | 1 | -0/+2 | |
2015-01-23 | bsp/altera-cyclone-v: Use proper free function | Sebastian Huber | 1 | -1/+1 | |
2015-01-23 | bsps/sparc: Use calloc() | Sebastian Huber | 1 | -3/+1 | |
Close #2242. | |||||
2015-01-23 | bsps/powerpc: Fix switch statement in CPU ident | Sebastian Huber | 1 | -0/+2 | |
Close #2237. | |||||
2015-01-23 | libchip: Fix high capacity detection for MMC | Sebastian Huber | 1 | -1/+1 | |
Close #2239. | |||||
2015-01-22 | grspw: descriptor tables no longer statically allocated | javamonn | 1 | -7/+7 | |
2015-01-22 | Filesystem: Delete node type operation | Sebastian Huber | 1 | -7/+8 | |
Use the fstat handler instead. | |||||
2015-01-20 | powerpc: Fix AltiVec VSCR save/restore | Sebastian Huber | 1 | -4/+6 | |
2015-01-14 | bsps/powerpc: Fix conditional compilation | Sebastian Huber | 1 | -3/+1 | |
2015-01-14 | bsp/mcf5206elite: Remove <i2c.h> inlude in <bsp.h> | Sebastian Huber | 2 | -3/+1 | |
This prevents a compile-time error in libtests/i2c01. | |||||
2015-01-13 | libcpu/powerpc/mpc6xx/mmu/bat.c: Now compiles with gcc 5.x | Joel Sherrill | 1 | -12/+12 | |
2015-01-13 | bsp/qoriq: Add T2080RDB and T4240RDB variants | Sebastian Huber | 24 | -318/+714 | |
2015-01-13 | powerpc: AltiVec and FPU context support | Sebastian Huber | 7 | -12/+821 | |
Add AltiVec and FPU support to the Context_Control in case we use the e6500 multilib. Add PPC_MULTILIB_ALTIVEC and PPC_MULTILIB_FPU multilib defines. Add non-volatile AltiVec and FPU context to Context_Control. Add save/restore of non-volatile AltiVec and FPU to _CPU_Context_switch(). Add save/restore of volatile AltiVec and FPU context to the exception code. Adjust data cache optimizations for the new context and cache line size. | |||||
2015-01-13 | bsps/powerpc: Use e500 exc categories for e6500 | Sebastian Huber | 1 | -0/+1 | |
This is not correct, but works for now. | |||||
2015-01-10 | moxiesim: Add conditional logic to handle old and new gas syntax | Anthony Green | 2 | -2/+21 | |
2015-01-09 | powerpc: Use PPC_HAS_FPU | Sebastian Huber | 1 | -6/+6 | |
Provide floating point context support only if PPC_HAS_FPU == 1. | |||||
2015-01-09 | powerpc: Set PPC_DEFAULT_CACHE_LINE_SIZE for e6500 | Sebastian Huber | 1 | -15/+11 | |
2015-01-09 | powerpc: Use PPC_DEFAULT_CACHE_LINE_SIZE | Sebastian Huber | 1 | -8/+2 | |
Use it for the default PPC_CACHE_ALIGNMENT. Use it for PPC_STRUCTURE_ALIGNMENT. | |||||
2015-01-09 | powerpc: Use alternate time base for CPU counter | Sebastian Huber | 1 | -1/+1 | |
