path: root/c (unfollow)
2004-09-292004-09-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-2/+6
* include/tm27.h: i960 obsoleted and all references removed.
2004-09-292004-09-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill23-1314/+19
* README: i960 obsoleted. * i960/.cvsignore, i960/ChangeLog, i960/Makefile.am, i960/configure.ac, i960/i960ca/.cvsignore, i960/i960ca/Makefile.am, i960/i960ca/cpu_install_intr_stack.c, i960/i960ca/cpu_install_raw_isr.c, i960/i960ka/.cvsignore, i960/i960ka/Makefile.am, i960/i960ka/cpu_install_intr_stack.c, i960/i960ka/cpu_install_raw_isr.c, i960/i960rp/.cvsignore, i960/i960rp/Makefile.am, i960/i960rp/cpu_install_intr_stack.c, i960/i960rp/cpu_install_raw_isr.c, i960/include/i960CA.h, i960/include/i960HA.h, i960/include/i960JX_RP_common.h, i960/include/i960KA.h, i960/include/i960RP.h: Removed.
2004-09-292004-09-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill103-8919/+0
* .cvsignore, ChangeLog, Makefile.am, acinclude.m4, configure.ac, cvme961/.cvsignore, cvme961/ChangeLog, cvme961/Makefile.am, cvme961/bsp_specs, cvme961/configure.ac, cvme961/times, cvme961/clock/ckinit.c, cvme961/console/console.c, cvme961/include/.cvsignore, cvme961/include/bsp.h, cvme961/include/tm27.h, cvme961/shmsupp/addrconv.c, cvme961/shmsupp/getcfg.c, cvme961/shmsupp/lock.c, cvme961/shmsupp/mpisr.c, cvme961/start/start.S, cvme961/startup/bspclean.c, cvme961/startup/bspstart.c, cvme961/startup/exit.c, cvme961/startup/linkcmds, cvme961/startup/setvec.c, cvme961/timer/timer.c, cvme961/timer/timerisr.S, i960sim/.cvsignore, i960sim/ChangeLog, i960sim/Makefile.am, i960sim/bsp_specs, i960sim/configure.ac, i960sim/clock/clockdrv.c, i960sim/console/console-io.c, i960sim/console/mon-syscalls.S, i960sim/include/.cvsignore, i960sim/include/bsp.h, i960sim/include/tm27.h, i960sim/start/start.c, i960sim/startup/bspstart.c, i960sim/startup/linkcmds, rxgen960/.cvsignore, rxgen960/ChangeLog, rxgen960/Makefile.am, rxgen960/README, rxgen960/bsp_specs, rxgen960/configure.ac, rxgen960/clock/ckinit.c, rxgen960/console/concntl.h, rxgen960/console/console.c, rxgen960/console/serial.c, rxgen960/console/serial.h, rxgen960/include/.cvsignore, rxgen960/include/bsp.h, rxgen960/include/rxgen960_config.h, rxgen960/include/tm27.h, rxgen960/start/rxgen_romld.S, rxgen960/startup/asmfault.S, rxgen960/startup/asmfault.h, rxgen960/startup/asmstub.S, rxgen960/startup/asmstub.h, rxgen960/startup/bspstart.c, rxgen960/startup/cntrltbl.c, rxgen960/startup/cntrltbl.h, rxgen960/startup/dram.ld, rxgen960/startup/exit.c, rxgen960/startup/fault.c, rxgen960/startup/fault.h, rxgen960/startup/faultret.h, rxgen960/startup/flttbl.c, rxgen960/startup/flttbl.h, rxgen960/startup/frmstr.c, rxgen960/startup/frmstr.h, rxgen960/startup/i960.h, rxgen960/startup/ihandler.S, rxgen960/startup/ihandler.h, rxgen960/startup/intrtbl.c, rxgen960/startup/intrtbl.h, rxgen960/startup/kkprintf.c, rxgen960/startup/linkcmds, rxgen960/startup/linkcmds.real, rxgen960/startup/main.h, rxgen960/startup/memchnl.h, rxgen960/startup/nmi.c, rxgen960/startup/nulsystbl.c, rxgen960/startup/pmc901_memmap.h, rxgen960/startup/prcb.c, rxgen960/startup/prcb.h, rxgen960/startup/rom.ld, rxgen960/startup/rom_cntrltbl.c, rxgen960/startup/rom_ibr.c, rxgen960/startup/rom_ibr.h, rxgen960/startup/rom_prcb.c, rxgen960/startup/rommon.h, rxgen960/startup/sctns.c, rxgen960/startup/sctns.h, rxgen960/startup/setvec.c, rxgen960/startup/systbl.c, rxgen960/startup/systbl.h, rxgen960/startup/time.h, rxgen960/timer/timer.c, rxgen960/timer/timerisr.S: Removed.
2004-09-272004-09-27 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2-32/+120
PR 608/bsps * pci/pcibios.c: BusCountPCI().
2004-09-272004-09-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-0/+7
PR 680/bsps * network/if_hdlcsubr.c: Add missing #include <rtems/rtems_bsdnet.h>.
2004-09-272003-11-01 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill3-25/+101
PR 606/bsps * bootloader/pci.c: Fixed IO remapping so buses >= 1 are remapped. Reduced PCI space to match bat2. Fixed incorrect region size calculation in pci_read_bases. Set PCI latency timers to known sane values. Changed bridge PCI settings to minimum sane instead of whatever sounded neat in the PCI spec. Force pf regions to memory mapped to preserve byte access.
2004-09-272004-04-09 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2-8/+9
PR 607/networking * libchip/network/dec21140.c: Made PCI configuration minimum sane instead of fully specifying unused PCI features.
2004-09-272004-04-09 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2-0/+6
PR 608/bsps * pci/pcibios.c: Added BusCountPCI()
2004-09-24Fix typo in previous change.Ralf Corsepius84-84/+84
2004-09-242004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius188-93/+473
2004-09-242004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2-0/+5
* aclocal/rtems-cpu-subdirs.m4: Add avr.
2004-09-212004-09-21 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius3-0/+26
* aclocal/gcc-weak.m4: New (Extracted from cpukit/configure.ac). * configure.ac: Add RTEMS_CHECK_GCC_WEAK.
2004-09-152004-09-15 Joel Sherrill <joel@OARcorp.com>Joel Sherrill9-7/+13
* README, times, network/network.c, start/start.S, startup/bspclean.c, startup/bspstart.c, startup/init5272.c, startup/linkcmds: Use CVS Id.
2004-08-182004-08-17 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius3-2/+7
* aclocal/ppc.m4 (RTEMS_PPC_EXCEPTIONS): Quote ac_popdir uses. * aclocal/target.m4 (_RTEMS_POP_BUILDDIR): Ditto.
2004-08-182004-08-17 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2-1/+5
* acinclude.m4 (_RTEMS_CONFIG_SUBDIR): Quote ac_popdir uses.
2004-08-032004-08-03 Jay Monkman <jtm@lopingdog.com>Jay Monkman23-0/+2749
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac, times, console/.cvsignore, console/console-io.c, include/.cvsignore, include/bsp.h, include/coverhd.h, include/tm27.h, network/network.c, start/.cvsignore, start/start.S, startup/.cvsignore, startup/bspclean.c, startup/bspstart.c, startup/init5272.c, startup/linkcmds: New files.
2004-08-032004-08-02 Jay Monkman <jtm@lopingdog.com>Jay Monkman13-1/+1275
* Makefile.am, configure.ac: Added CSB360 BSP * mcf5272/.cvsignore, mcf5272/ChangeLog, mcf5272/Makefile.am, mcf5272/clock/.cvsignore, mcf5272/clock/ckinit.c, mcf5272/include/.cvsignore, mcf5272/include/mcf5272.h, mcf5272/timer/.cvsignore, mcf5272/timer/timer.c, mcf5272/timer/timerisr.S: New files.
2004-07-302004-07-30 Jay Monkman <jtm@lopingdog.com>Jay Monkman2-16/+21
* network/network.c: Changes to network driver to get it to compile again.
2004-07-282004-07-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+4
* aclocal/version.m4: Updated to rtems-4.6.99.1.
2004-07-28Back off version again.Joel Sherrill1-4/+0
2004-07-28Back off version.Joel Sherrill1-4/+0
2004-07-282004-07-28Joel Sherrill2-1/+5
2004-07-282004-07-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-0/+6
* startup/linkcmds: Add gnu.linkonce.d and gcc_except_table sections.
2004-07-252004-07-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-1/+6
* libchip/network/if_fxp.c: Add include of <sys/errno.h>.
2004-07-252004-07-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-0/+5
* startup/linkcmds: Add gnu.linkonce.r sections.
* Makefile.am: Add -D__INSIDE_RTEMS_BSD_TCPIP_STACK__ for network.
2004-07-252004-07-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill8-0/+20
* network/network.c: Add include of <sys/errno.h>.
2004-07-252004-07-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-2/+7
* Makefile.am: Add -D__INSIDE_RTEMS_BSD_TCPIP_STACK__ for network. * network/ne2000.c: Add include of <sys/errno.h>.
2004-07-252004-07-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-0/+10
* 3c509/3c509.c: Add <sys/errno.h>. * startup/linkcmds: Add .jcr section.
2004-07-242004-07-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill4-0/+11
* at91rm9200/.cvsignore, mc9328mxl/.cvsignore, shared/.cvsignore: New files.
2004-07-242004-07-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-0/+18
* .cvsignore: New file.
2004-07-152004-07-15 Jay MonkmanJay Monkman4-0/+68
* .cvsignore, ChangeLog, Makefile.am, configure.ac: New files.
2004-07-152004-07-15 Jay MonkmanJay Monkman4-0/+330
* ChangeLog, Makefile.am, arm920/mmu.c, include/mmu.h: New files.
2004-07-152004-07-15 Jay MonkmanJay Monkman12-0/+1226
* ChangeLog, Makefile.am, clock/.cvsignore, clock/clockdrv.c, include/mc9328mxl.h, irq/.cvsignore, irq/bsp_irq_asm.S, irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, timer/.cvsignore, timer/timer.c: New files.
2004-07-152004-07-15 Jay MonkmanJay Monkman21-0/+2466
* ChangeLog, Makefile.am, clock/.cvsignore, clock/clock.c, dbgu/.cvsignore, dbgu/dbgu.c, include/at91rm9200.h, include/at91rm9200_dbgu.h, include/at91rm9200_emac.h, include/at91rm9200_gpio.h, include/at91rm9200_mem.h, include/at91rm9200_pmc.h, include/bits.h, irq/.cvsignore, irq/bsp_irq_asm.S, irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, pmc/pmc.c, timer/.cvsignore, timer/timer.c: New files.
2004-07-152004-07-15 Jay MonkmanJay Monkman2-0/+8
* acinclude.m4: Added csb336 and csb337 BSPs
2004-07-152004-07-15 Jay MonkmanJay Monkman20-0/+1946
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac, times, console/uarts.c, include/.cvsignore, include/bsp.h, include/tm27.h, network/.cvsignore, network/network.c, start/.cvsignore, start/start.S, startup/.cvsignore, startup/bspstart.c, startup/exit.c, startup/linkcmds, startup/memmap.c: New files.
2004-07-152004-07-15 Jay MonkmanJay Monkman6-0/+68
* console/.cvsignore, include/.cvsignore, network/.cvsignore, start/.cvsignore, startup/.cvsignore: New files.
2004-07-152004-07-15 Jay MonkmanJay Monkman17-0/+2652
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac, times, console/uart.c, include/bsp.h, include/tm27.h, network/lan91c11x.c, network/lan91c11x.h, network/network.c, start/start.S, startup/bspstart.c, startup/exit.c, startup/linkcmds, startup/memmap.c: New files.
2004-05-232004-05-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-3/+7
PR 615/bsps * include/tm27.h: Removing USE_ENHANCE_INTR_API conditional check since that is the only kind this BSP supports and tm27 does not care which interrupt model is used as long as the macros are properly defined.
2004-05-222004-05-22 Till Strauman <strauman@slac.stanford.edu>Joel Sherrill2-12/+33
PR 619/bsps * mpc6xx/clock/c_clock.c: The PPC decrementer must be reloaded on each clock tick. Currently, this is done by just reloading a fixed value. The attached patch takes into account the time that elapsed since the decrementer crossed zero in order to adjust the value to be re-loaded. Without the patch, the effective system clock cycle is increased by the exception handler latency.
2004-05-212004-05-21 Till Strauman <strauman@slac.stanford.edu>Joel Sherrill3-28/+40
* PR 624/bsps startup/bspstart.c: When probing the memory, make sure not to corrupt the application. Only probe addresses beyond rtemsFreeMemStart. * Let IBMPC_outch() convert LF -> CRLF to avoid printk scrambling the screen.
2004-05-21Fix formatting so script sees PR.Joel Sherrill1-1/+1
2004-05-212004-05-21 Till Strauman <strauman@slac.stanford.edu>Joel Sherrill4-36/+51
* PR/625/networking * libchip/network/dec21140.c, ... : Prevent name clashes by making 'ld_le32()' etc. static inlines. Let dec21140 attach routine return an error rather than panic if no chip is detected (thus allowing for probing). * libchip/network/elnk.c: Let elnk bail out if autoneg never completes instead of looping forever. Avoid divide by zero (crashed my PC). * libchip/network/if_fxp.c: Enable more fxp chip variants but warn that they are UNTESTED.
2004-05-212004-05-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-0/+6
* network/network.c: Include errno.h as a consequence of recent updates to BSD header files.
2004-05-212004-05-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-0/+7
* ne2000/ne2000.c, wd8003/wd8003.c: Include errno.h as a consequence of recent updates to BSD header files.
2004-05-102004-05-10 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2-5/+4
* aclocal/check-cxx.m4: Remove CPLUS_LD_LIBS.
2004-04-232004-04-23 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius150-195/+698
PR 610/bsps * Makefile.am: Add include/tm27.h, Cosmetics. * include/tm27.h: Final cosmetics.
2004-04-232004-04-22 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius15-150/+265
* include/bsp.h: Split out tmtest27 support. * include/tm27.h: New.
