to convert the sample tests to automake.
by the same application.
+ Cleaned up code.
+ Corrected enable/disable of dispatch.
+ Added tests for sem_open, sem_close, and sem_unlink.
+ Yellow lined sem_open, sem_close, sem_unlink,
_POSIX_Semaphore_Delete, _POSIX_Semaphore_Name_to_id,
and _POSIX_Semaphore_Create_support. Except for MP, pshared
OBJECT_REMOTE, and out of memory paths.
can be included from the same file.
Synthesizer Control Register to remove use of single letter names.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
<corsepiu@faw.uni-ulm.de> to correct the constraints on the
inline assembly language macro for sh_disable_interrupt.
1. SH-Port:
* Many files renamed.
applying VPATH.
2. SH1-Port
3. SH2-Port
* Merged
you don't mind).
family of macros to produce better checks and diagnostic messages.
its name in the name_table. This was required by the POSIX semaphore
and message queue managers which support a concept of open, close, and
unlink. The object becomes "invisible" to further opens following an
unlink but all open sessions remain active until they are closed. This
requires that the removal of an object ID be separate from the removal
of its name.
but all paths have not been checked, yet.
<corsepiu@faw.uni-ulm.de> which corrects some configuration
problems and cleans up a few Makefile.in's.
<corsepiu@faw.uni-ulm.de> which turns OPERATION_COUNT into a configure
time option.
to be able to boot the archives located in powerpc-rtems/c/mcp750/bin.
This information was provided by Eric Valette <valette@crf.canon.fr>
to UnixWare (UW).
