* console/console.c (ISS_output_char): Add return type.
* timer/timer.c: Remove unused vars "old_ie".
* libchip/display/disp_hcms29xx.c: Remove ARRAY_COUNT (unused).
* console.c: Include <rtems/error.h> for rtems_panic().
PR 1940/misc:
* libchip/serial/ns16550.c: Reflect changes to console-driver.
PR 1926/bsps
* timer/timer.c: New file.
* Makefile.am: Reflect change above.
* libchip/network/smc91111.c: Use PRIxPTR to print pointers.
* console.c: RTEMS_DEBUG is a define, not a variable.
PR 1917/bsps
* libchip/serial/mc68681.c, libchip/serial/ns16550.c,
libchip/serial/serial.h, libchip/serial/z85c30.c: Modifications to
add dynamic tables for libchip serial drivers.
PR 1917/bsps
* mongoosev/duart/mg5uart.c: Modifications to add dynamic tables for
PR 1917/bsps
* sh7045/sci/sci_termios.c: Modifications to add dynamic tables for
PR 1917/bsps
* Makefile.am, console/conscfg.c: Modifications to add dynamic tables
PR 1917/bsps
* Makefile.am, console/consolelite.c: Modifications to add dynamic
PR 1917/bsps
* Makefile.am, preinstall.am, console/config.c, console/mc68360_scc.c,
console/ns16550cfg.c, console/printk_support.c: Modifications to add
PR 1917/bsps
* Makefile.am, console/console-config.c, startup/bspstart.c:
Modifications to add dynamic tables for libchip serial drivers.
PR 1917/bsps
* Makefile.am, console/console-config.c, console/uart-bridge-master.c,
console/uart-bridge-slave.c, startup/bspstart.c: Modifications to add
PR 1917/bsps
* console/config.c: Modifications to add dynamic tables for libchip
serial drivers.
PR 1917/bsps
* Makefile.am, console/erc32_console.c: Modifications to add dynamic
PR 1917/bsps
* shared/console/conscfg.c: Modifications to add dynamic tables for
PR 1917/bsps
* Makefile.am: Modifications to add dynamic tables for libchip serial
drivers.
PR 1917/bsps
* Makefile.am, console/uarts.c: Modifications to add dynamic tables for
PR 1917/bsps
* Makefile.am, console/uart.c: Modifications to add dynamic tables for
PR 1917/bsps
* Makefile.am, console/console-config.c: Modifications to add dynamic
PR 1917/bsps
* Makefile.am, console/console-config.c, console/hsu.c: Modifications
PR 1917/bsps
* console.c: Modifications to add dynamic tables for libchip serial
drivers.
* console_control.c, console_private.h, console_read.c,
console_select.c, console_write.c: New files.
* ne2000/ne2000.c: Remove unused var "stat".
* libchip/rtc/icm7170.c (icm7170_get_time): Remove unused var setReg.
* libchip/rtc/icm7170.c (icm7170_set_time): Remove unused var getReg.
* include/start-config.h, make/custom/lpc24xx_plx800_rom_int.cfg,
startup/linkcmds.lpc24xx_plx800_rom_int,
startup/start-config-emc-dynamic.c, startup/start-config-emc-static.c,
startup/start-config-pinsel.c: New files.
* Makefile.am, configure.ac, preinstall.am: Reflect changes above.
* startup/bspstarthooks.c: Use configuration tables for EMC
initialization.
* shared/comm/uart.c: Remove unused var "tmp".
* libchip/network/smc91111.c: Eliminate unused var "success".
* libchip/serial/mc68681.c: Eliminate unused var "success".
* libchip/serial/z85c30.c: Eliminate unused var "dummy".
* mpc55xx/include/fsl-mpc567x.h: Added EQADC as an alias to EQADC_A.
PR 1928/bsps:
* mpc55xx/include/fsl-mpc567x.h: Revert previous change.
* mpc55xx/misc/flash_support.c: Enable this file only for MPC55XX.
* libchip/network/sonic.c: Don't cast pointers to uint32_t.
* libchip/network/greth.c, libchip/network/open_eth.c
libchip/network/sonic.c: Eliminate evil typecasts.
* libchip/network/greth.h, libchip/network/open_eth.h,
libchip/network/sonic.h: Use void* for addresses.
PR 1933/cpukit
* shared/irq_asm.S: From code inspection I have found the following
issues (most SMP), and some improvements in irq_asm.S. I would need a
long test with interrupts to verify the interrupt handler better,
however I can not see that these patches hurt. Please see comment per
hunk below, One should go through the file to indent delay-slots
correctly, I have fixed some in the patch areas. An extra space is
added in front of delay slots to indicate a delay slot.
* shared/startup/bspstart.c: Comment out unused vars.
* shared/console/console.c: Remove stray local decl of "close".
* make/custom/rtl22xx_t.cfg: Remove USE_THUMB (Violates *.cfg
conventions, unused).
* ppc403/clock/clock.c (ClockOn): Define pvr only for "ifndef ppc405".
* ppc403/clock/clock.c (Install_clock): Remove unused var "pvr".
* new-exceptions/bspsupport/ppc_exc_prologue.c
(ppc_exc_create_branch_op): Comment out unused var "BRANCH_OP_LINK".
* mpc5xx/clock/clock.c: Make BSP_disconnect_clock_handler decl a
prototype.
PR 1928/bsps:
* mpc55xx/include/fsl-mpc567x.h (struct FLASH_tag): Extend SIZE to 4
bits.
PR 1920/bsp
* shared/helenos/kernel/sparc64/src/sun4u/takemmu.S,
shared/start/start.S, shared/startup/bspgetworkarea.c,
shared/startup/linkcmds: Fix BSP memory use to support more than 4 MB
of RAM.
PR 1919/bsp
* shared/startup/bsppredriverhook.c: New file.
PR 1919/bsp
* Makefile.am: Change install ISR callout to bsppredriverhook.
