2012-05-04 | Remove CVS-Ids. | Ralf Corsépius | 2 | -6/+0 | |
2012-05-04 | Remove CVS-Ids. | Ralf Corsépius | 2 | -8/+0 | |
2012-05-04 | Remove CVS-Ids. | Ralf Corsépius | 2 | -7/+0 | |
2012-05-03 | nds/linkcmds - Remove execute permission | Joel Sherrill | 1 | -0/+0 | |
2012-05-03 | libcpu misc m68k and sh - Correct formatting and remove weird Id strings | Joel Sherrill | 6 | -59/+41 | |
2012-05-03 | General - Remove extraneous blank line in license message | Joel Sherrill | 98 | -85/+0 | |
Many files had an extra blank line in the license text found in the file header. This patch removes that line. * The license and distribution terms for this file may be * found in the file LICENSE in this distribution or at * * http://www.rtems.com/license/LICENSE. The script that did this also turned off execute permission when it was turned on incorrectly. | |||||
2012-05-03 | Libcpu misc files - Remove execute permission on source files. | Joel Sherrill | 10 | -0/+0 | |
2012-05-03 | rtems-message_queue.adb - Convert DOS to UNIX CF/LF | Joel Sherrill | 1 | -245/+245 | |
2012-05-02 | smdk2410 - Remove odd $Id$ | Joel Sherrill | 1 | -2/+0 | |
2012-05-02 | gp32 - Remove odd $Id$ | Joel Sherrill | 1 | -3/+0 | |
2012-05-02 | pc386 - Remove odd $Id$ | Joel Sherrill | 7 | -14/+0 | |
2012-05-02 | libchip hcms29xx - Remove odd $Id$ and clean up file header | Joel Sherrill | 5 | -17/+1 | |
2012-05-02 | score603e - Remove bad $Id$ and clean up file header | Joel Sherrill | 1 | -4/+6 | |
2012-05-02 | libcpu/m68k/mcf532x - Remove bad $Id$ and clean up file header | Joel Sherrill | 1 | -3/+3 | |
2012-05-02 | libchip z85c30 - Remove bad $Id$ and clean up file header | Joel Sherrill | 1 | -4/+6 | |
2012-05-02 | LEON3 - Remove bad $Id$ and clean up file header | Joel Sherrill | 1 | -4/+6 | |
2012-05-02 | LEON2 - Remove bad $Id$ and clean up file header | Joel Sherrill | 1 | -4/+6 | |
2012-05-02 | MRM332 - Remove incorrect $Id$ string and correct file header | Joel Sherrill | 2 | -2/+26 | |
2012-04-26 | bsps/stackalloc: Add initialization hook | Sebastian Huber | 2 | -16/+23 | |
2012-04-24 | bsp/mpc55xxevb: Enable stack allocator | Sebastian Huber | 6 | -4/+10 | |
2012-04-24 | bsps/stackalloc: Use stack section symbols | Sebastian Huber | 5 | -55/+26 | |
2012-04-24 | bsps/powerpc: Add no cache section | Sebastian Huber | 14 | -89/+78 | |
2012-04-24 | bsp/mpc55xxevb: Change early MMU settings | Sebastian Huber | 3 | -17/+28 | |
Add internal SRAM sections with cache enabled to early MMU settings. The internal SRAM initialization will use the early MMU settings. This allows applications to use cache inhibited areas in the internal SRAM. | |||||
2012-04-23 | bsp/lpc24xx: Fix define name | Sebastian Huber | 1 | -1/+1 | |
2012-04-20 | bsps/arm: Make the Clock_isr() static again | Sebastian Huber | 1 | -1/+1 | |
2012-04-20 | bsps: Avoid rtems_irq_hdl_param type usage | Sebastian Huber | 1 | -2/+1 | |
Not every clock interrupt service routine is installed with this API. Remove also the prototype to allow drivers to make this routine static. | |||||
2012-04-20 | bsp/genmcf548x: Enable FPU in BSP startup code | Sebastian Huber | 1 | -13/+5 | |
2012-04-20 | bsp/genmcf548x: Fix BSP options | Sebastian Huber | 1 | -3/+4 | |
2012-04-20 | bsps/arm: Remove superfluous include | Sebastian Huber | 1 | -1/+0 | |
2012-04-19 | s3c24xx shared: Clock driver clean up and ISR Handler Prototype Correction. | Joel Sherrill | 1 | -23/+11 | |
2012-04-19 | pxa255 shared: Clock driver clean up and ISR Handler Prototype Correction. | Joel Sherrill | 1 | -16/+8 | |
2012-04-19 | mc9328mxl shared: Clock driver clean up and ISR Handler Prototype Correction. | Joel Sherrill | 1 | -31/+18 | |
2012-04-19 | lpc22xx shared: Clock driver clean up and ISR Handler Prototype Correction. | Joel Sherrill | 1 | -58/+53 | |
2012-04-19 | at91rm9200 shared: Clock driver clean up and ISR Handler Prototype Correction. | Joel Sherrill | 1 | -23/+19 | |
2012-04-19 | lpc shared: Clock driver clean up and ISR Handler Prototype Correction. | Joel Sherrill | 1 | -1/+1 | |
2012-04-19 | armv7m shared: Clock driver clean up and ISR Handler Prototype Correction. | Joel Sherrill | 1 | -1/+2 | |
2012-04-19 | nds: Clock driver clean up and ISR Handler Prototype Correction. | Joel Sherrill | 1 | -15/+8 | |
2012-04-19 | gba: Clock driver clean up and ISR Handler Prototype Correction. | Joel Sherrill | 1 | -32/+25 | |
2012-04-19 | edb7312: Clock driver clean up and ISR Handler Prototype Correction. | Joel Sherrill | 1 | -19/+14 | |
2012-04-19 | Clock Driver Shell - Correct PIC IRQ Prototype. | Joel Sherrill | 1 | -2/+2 | |
2012-04-19 | LEON3: rename console/debugputs.c to printk_support.c | Daniel Hellstrom | 2 | -1/+1 | |
2012-04-19 | LEON3: added TX-wait-complete and CR on NL support for UART | Daniel Hellstrom | 2 | -6/+23 | |
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> |
