path: root/c (unfollow)
2008-09-172008-09-17 Miao Yan <yanmiaobest@gmail.com>Joel Sherrill3-4/+14
* bsplibc.c, bsppost.c: Merge GSOC project code to add simple device only filesystem (devfs), optionally completely drop out filesystem, and to clean up disabling newlib reentrancy support. This dropped 17K from the minimum.exe for sparc/sis and arm/rtl22xx_t now has a 15K code space.
2008-09-172008-09-17 Miao Yan <yanmiaobest@gmail.com>Joel Sherrill2-2/+11
* startup/bspstart.c: Merge GSOC project code to add simple device only filesystem (devfs), optionally completely drop out filesystem, and to clean up disabling newlib reentrancy support. This dropped 17K from the minimum.exe for sparc/sis and arm/rtl22xx_t now has a 15K code space.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-0/+49
* bspgetworkarea.c: New file. This implementation should be useable by most BSPs if they provide the proper support in their linker script.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill4-47/+14
* Makefile.am, startup/linkcmds: Use top level shared bsp_get_work_area() implementation. * startup/bspgetworkarea.c: Removed.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-44/+4
* shared/m68kbspgetworkarea.c: Removed.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill4-11/+16
* Makefile.am, startup/bspstart.c, startup/linkcmds: Use top level shared bsp_get_work_area() implementation.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill33-59/+114
* Makefile.am, startup/linkcmds, startup/linkcmds_ROM: Use top level shared bsp_get_work_area() implementation.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill4-13/+18
* Makefile.am, startup/linkcmds, startup/linkcmdsflash: Use top level shared bsp_get_work_area() implementation.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill10-26/+38
* Makefile.am, startup/linkcmds, startup/linkcmdsflash, startup/linkcmdsram: Use top level shared bsp_get_work_area() implementation.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill4-8/+13
* Makefile.am, start/start.S, startup/linkcmds: Use top level shared bsp_get_work_area() implementation.
* Makefile.am, startup/linkcmds, startup/linkcmds.flash: Use top level shared bsp_get_work_area() implementation.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill6-14/+20
* Makefile.am, startup/bspstart.c, startup/init548x.c, startup/linkcmds, startup/linkcmds.m5484FireEngine.flash: Use top level shared bsp_get_work_area() implementation.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill7-42/+41
* Makefile.am, include/bsp.h, startup/init68360.c, startup/linkcmds, startup/linkcmds.bootp, startup/linkcmds.prom: Use top level shared bsp_get_work_area() implementation.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill6-4/+42
* startup/bspgetworkarea.c, startup/linkcmds.base: Do some prep work in anticipation of gen5200 and gen83xx being able to shared bsp_get_work_area() implementation.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill4-42/+9
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill4-39/+14
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill12-125/+31
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill8-90/+22
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill4-43/+12
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill8-82/+22
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill4-36/+10
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill4-41/+9
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill5-45/+11
* Makefile.am, include/bsp.h, startup/linkcmds: Use top level shared bsp_get_work_area() implementation. * startup/bspgetworkarea.c: Removed.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill4-80/+8
* shared/bspgetworkarea.c: Removed.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill9-7/+24
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill5-4/+13
* Makefile.am, startup/linkcmds, startup/linkcmds-le, startup/linkcmds-le.coff: Use top level shared bsp_get_work_area() implementation.
* Makefile.am, startup/linkcmds, startup/linkcmds.sim: Use top level shared bsp_get_work_area() implementation.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill5-21/+15
* Makefile.am, startup/linkcmds, startup/linkcmds.rom, startup/linkcmds.rom2ram: Use top level shared bsp_get_work_area() implementation.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill5-11/+17
* Makefile.am, startup/linkcmds, startup/linkcmds.ram, startup/linkcmds.rom: Use top level shared bsp_get_work_area() implementation.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill3-46/+8
* Makefile.am: Use top level shared bsp_get_work_area() implementation. * startup/bspgetworkarea.c: Removed.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-1/+5
* shared/include/nvram.h: Fix typo.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill3-1/+28
* clockdrv_shell.c: Remove unnecessary includes of rtems/libcsupport.h and rtems/libio.h. * bspstart.c: New file.
* clock/clock.c: Remove unnecessary includes of rtems/libcsupport.h and rtems/libio.h.
* clock/ckinit.c: Remove unnecessary includes of rtems/libcsupport.h and rtems/libio.h.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill4-163/+8
* startup/bspstart.c: Removed.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-4/+5
* shared/bspstart.c: Remove unnecessary includes of rtems/libcsupport.h and rtems/libio.h.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-1/+7
* clock/ckinit.c: Add use of bsp_get_work_area() in its own file and rely on BSP Framework to perform more initialization. Remove unnecessary includes of rtems/libio.h and rtems/libcsupport.h. All SuperH BSPs now share a common bsp_start() implementation.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-1/+6
* shared/clock/clock.c: Remove unnecessary includes of rtems/libcsupport.h and rtems/libio.h.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-2/+5
* irq/FPGA.c: Remove unnecessary includes of rtems/libcsupport.h and rtems/libio.h.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill12-63/+174
* Makefile.am, startup/bspstart.c: Add use of bsp_get_work_area() in its own file and rely on BSP Framework to perform more initialization. Remove unnecessary includes of rtems/libio.h and rtems/libcsupport.h. * startup/bspgetworkarea.c: New file.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill30-36/+75
* startup/bspstart.c: Remove unnecessary includes of rtems/libcsupport.h and rtems/libio.h.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill3-7/+6
* clock/clock.c, startup/bspstart.c: Remove unnecessary includes of rtems/libcsupport.h and rtems/libio.h.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill4-23/+51
* Makefile.am, startup/bspstart.c: Split out bsp_get_work_area() into its own file and use BSP Framework to perform more initialization. * startup/bspgetworkarea.c: New file.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill9-11/+15
* clock/ckinit.c, startup/bspstart.c: Remove unnecessary includes of rtems/libcsupport.h and rtems/libio.h.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill3-68/+9
* shared/m68kbspgetworkarea.c: Add use of bsp_get_work_area() in its own file and rely on BSP Framework to perform more initialization. Remove unnecessary includes of rtems/libio.h and rtems/libcsupport.h. * shared/m68kpretaskinghook.c: Removed.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill10-67/+42
* Makefile.am, configure.ac, startup/bspstart.c, startup/linkcmds: Add use of bsp_get_work_area() in its own file and rely on BSP Framework to perform more initialization. Remove unnecessary includes of rtems/libio.h and rtems/libcsupport.h.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill7-75/+66
* Makefile.am, configure.ac, startup/linkcmds: Add use of bsp_get_work_area() in its own file and rely on BSP Framework to perform more initialization. Remove unnecessary includes of rtems/libio.h and rtems/libcsupport.h. * console/debugio.c, startup/bsppredriverhook.c: New files. * startup/bspstart.c: Removed.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill18-194/+43
* Makefile.am, configure.ac, clock/ckinit.c, startup/linkcmds: Add use of bsp_get_work_area() in its own file and rely on BSP Framework to perform more initialization. Remove unnecessary includes of rtems/libio.h and rtems/libcsupport.h. * startup/bspstart.c: Removed.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill5-29/+12
* Makefile.am, configure.ac, clock/ckinit.c, startup/bspstart.c: Add use of bsp_get_work_area() in its own file and rely on BSP Framework to perform more initialization. Remove unnecessary includes of rtems/libio.h and rtems/libcsupport.h.
