Sprout from rtems-4-9-branch 2008-09-24 17:16:13 UTC Joel Sherrill <joel.sherrill@OARcorp.com> '2008-09-24 Joel Sherrill <joel.sherrill@OARcorp.com>'
Cherrypick from rtems-4-9-branch 2009-09-15 05:32:51 UTC cvs2git <rtems-devel@rtems.org> 'This commit was manufactured by cvs2svn to create branch 'rtems-4-9-branch'.':
c/src/lib/libbsp/arm/smdk2410/include/.cvsignore
c/src/lib/libbsp/m68k/genmcf548x/include/.cvsignore
c/src/lib/libbsp/m68k/mcf52235/include/.cvsignore
c/src/lib/libbsp/m68k/mcf5329/include/.cvsignore
c/src/lib/libbsp/powerpc/mvme3100/include/.cvsignore
c/src/lib/libbsp/powerpc/virtex/include/.cvsignore
* preinstall.am: Regenerated.
* Makefile.am: Eliminates libcpudir.
PR 1323/bsps
* Makefile.am: Remove AM_CFLAGS += -msoft-float.
* Makefile.am: Remove empty HAS_NETWORKING conditional.
PR 1322/bsps
* include/bspopts.h.in: Remove.
PR 1322/bsps
* leaf.cfg: LINK.c and LINK.cc include LDFLAGS so do not include it in
make-exe and make-cxx-exe definitions. This was resulting in the
linker script being processed twice and breaking some BSPs.
* aclocal/prog-cc.m4: Remove pre-production testing CFLAGS.
* ACKNOWLEDGEMENTS, TOOL_TARGETS: Remove TI C4x and NIOS2 ports from
4.9 branch.
* aclocal/canonical-target-name.m4, aclocal/rtems-cpu-subdirs.m4:
Remove TI C4x and NIOS2 ports from 4.9 branch.
* c4x/.cvsignore, c4x/ChangeLog, c4x/Makefile.am, c4x/acinclude.m4,
c4x/configure.ac, c4x/c4xsim/.cvsignore, c4x/c4xsim/ChangeLog,
c4x/c4xsim/Makefile.am, c4x/c4xsim/README, c4x/c4xsim/bsp_specs,
c4x/c4xsim/configure.ac, c4x/c4xsim/preinstall.am,
c4x/c4xsim/clock/clock.c, c4x/c4xsim/console/console.c,
c4x/c4xsim/console/consolereserveresources.c,
c4x/c4xsim/console/debugio.c, c4x/c4xsim/console/simio.c,
c4x/c4xsim/include/.cvsignore, c4x/c4xsim/include/bsp.h,
c4x/c4xsim/include/simio.h, c4x/c4xsim/include/tm27.h,
c4x/c4xsim/start/start.S, c4x/c4xsim/startup/bspstart.c,
c4x/c4xsim/startup/linkcmds, c4x/c4xsim/startup/spurious.c,
c4x/c4xsim/timer/timer.c, c4x/c4xsim/tools/.cvsignore,
c4x/c4xsim/tools/ChangeLog, c4x/c4xsim/tools/Makefile.am,
c4x/c4xsim/tools/configure.ac, c4x/c4xsim/tools/runtest.in,
c4x/shared/bspspuriousinit.c, c4x/shared/c3xspurious.c,
c4x/shared/c4xspurious.c, nios2/.cvsignore, nios2/ChangeLog,
nios2/Makefile.am, nios2/README, nios2/acinclude.m4,
nios2/configure.ac, nios2/nios2_iss/.cvsignore,
nios2/nios2_iss/ChangeLog, nios2/nios2_iss/Makefile.am,
nios2/nios2_iss/bsp_specs, nios2/nios2_iss/configure.ac,
nios2/nios2_iss/nios2_iss.ptf, nios2/nios2_iss/nios2_iss.sh,
nios2/nios2_iss/preinstall.am, nios2/nios2_iss/times,
nios2/nios2_iss/clock/clock.c, nios2/nios2_iss/console/console.c,
nios2/nios2_iss/include/.cvsignore, nios2/nios2_iss/include/bsp.h,
nios2/nios2_iss/include/coverhd.h, nios2/nios2_iss/include/tm27.h,
nios2/nios2_iss/shmsupp/addrconv.c, nios2/nios2_iss/shmsupp/getcfg.c,
nios2/nios2_iss/shmsupp/lock.c, nios2/nios2_iss/shmsupp/mpisr.c,
nios2/nios2_iss/start/crtnn.s, nios2/nios2_iss/start/start.S,
nios2/nios2_iss/startup/bspclean.c,
nios2/nios2_iss/startup/bspstart.c, nios2/nios2_iss/startup/linkcmds,
nios2/nios2_iss/startup/main.c, nios2/nios2_iss/startup/setvec.c,
nios2/nios2_iss/timer/timer.c: Removed.
* leaf.cfg, compilers/gcc-target-default.cfg: Remove use of AM_LDFLAGS.
Ensure LDFLAGS works all the time. Clean up BSPs which defined their
own make-exe rules inappropriately.
added port init, added phy support
init mmu
i2c-driver: wait, 'til stop executed
* i2c/i2c.c: Remove rtems_boolean having crept in again.
* runtest.in: Work on .exe and .ralf files.
* runtest-bottom: Work on .exe and .ralf files.
* runtest.in: Update to support .exe or .ralf extension.
* mpc8xx/clock/clock.c, mpc8xx/console-generic/console-generic.c,
mpc8xx/timer/timer.c: Fix nested extern declaration warnings.
* .cvsignore, include/.cvsignore: New files.
* acinclude.m4: Add tqm8xx.
* ChangeLog: New file.
* mcf548x/include/Freescale_license.txt: Convert to UNIX CR/LF style,
eliminate characters with 8th bit set.
updated mscan CAN driver
* mcf548x/include/mcf548x.h: Convert to Unix file format.
* libchip/ide/ata.h: Convert to Unix file format.
* shared/comm/i386-stub.c: Include stdbool.h.
* libchip/serial/mc68681.c, libchip/serial/mc68681_p.h,
libchip/serial/ns16550.c, libchip/serial/ns16550_p.h,
libchip/serial/serial.h, libchip/serial/serprobe.c,
libchip/serial/sersupp.h, libchip/serial/z85c30.c:
Convert to "bool".
* libchip/i2c/spi-flash-m25p40.c, libchip/i2c/spi-fram-fm25l256.c,
libchip/i2c/spi-memdrv.h: Convert to "bool".
* libchip/rtc/ds1375-rtc.h, libchip/rtc/ds1375.c,
libchip/rtc/mc146818a.c, libchip/rtc/mc146818a.h,
libchip/rtc/rtc.h, libchip/rtc/rtcprobe.c: Convert to "bool".
