path: root/c/update-tools/Makefile.in (follow)
* Part of the automake VI patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-02-181-3/+5
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1998-10-141-15/+20
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 1. Rtems contains some perl scripts that use hard-coded paths to /usr/bin/perl or /usr/local/bin/perl I have already fixed these problems by adding some checks to configure.in. While doing this, I also cleaned up some more autoconf related problems for generating shell scripts. This patch might seem a bit scary to you, but I am quite confident it won't break something (I've been testing it for almost a week now, however it might introduce typos for a limited number configurations I don't have access to - But it shouldn't be a problem for you to test them :-). I expect to get this finished tonight, hence you will very likely have the patch when you get up tomorrow. Changes: * Check for PERL and disable all PERL scripts if perl wasn't found. * Generate all KSHELL-scripts with autoconf instead of make-script * Automatic dependency handling for autoconf generated KSHELL or PERL scripts (make/rtems.cfg) Notes: * this patch contains new files and deletes some other files. * The patch is relative to rtems-4.0.0-beta4 with my previous rtems-rc-981014-1.diff patch applied. Testing: I tested it with sh-rtems and posix under linux. Now all targets which are touched by this patch and which are not used while building for sh-rtems and posix still need to be tested. AFAIS, only the sparc/erc32 BSP should be affected by this criterion. And if you like to, you should also consider testing it on a Cygwin32 and a Solaris host for one arbitrary BSP.
* Patches from Ralf Corsepius <corsepiu@faw.uni-ulm.de> and myself toJoel Sherrill1998-08-191-3/+3
| | | | | | | | | | | | | | | | | | | | | | | | make solaris target buildable. > 1. The ipc check fails since solaris does not define union semun. > The unix port code actually defines this type itself on solaris. Doing > the same thing lets it get configured. Then... > 2. It looks like BSDINSTALL is not defined properly. BSDINSTALL is defined in make/host.cfg.in as BSDINSTALL=@INSTALL@ @INSTALL@ is generated by autoconf's standard macro AC_PROG_INSTALL, which is widely used in almost any autoconf/automake configured package. In case there is really something wrong with it, then it must be considered a bug in autoconf. I can see a doubious fragment in AC_PROG_INSTALL, which is used when no appropriate bsd-install is found. Finally Ralf saw a problem with the find on solaris which I also saw and fixed.
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. Comments:Joel Sherrill1998-07-171-4/+4
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Added support for bsd "install" ($(BSDINSTALL)) to host.cfg.in, i.e. the standard "install" program that most packages (including automake) use. In Makefiles outside of rtems, "install" normally is referenced by $(INSTALL), but rtems already uses $(INSTALL) for install-if-change, hence I used $(BSDINSTALL) instead to keep up backward compatibility. * Removed references to @GREP@ etc. from host.cfg.in, as configure.in doesn't check for them (Minor cleanup). * Added installation flags INST*FLAGS to host.cfg.in, which should replace -m XXXX flags for installation calls. *Changes to gcc.cfg to enable it to build host programs from multiple sources files. Should not disturb existing sources, but neccessary. * There was a not-so-minor bug in the configuration files: "make install" and "make debug_install" don't work in all subdirectories!! I tried to fix this by adding "install" to MTARGETS in main.cfg, which seems to solve most of the problems. But there still seem to be rare (?) cases where "make debug_install" still seems to have problems. * Changes to many host related tool-Makefiles to demonstrate the abilities of INST*FLAGS, BSDINSTALL and the new rules in gcc.cfg. ..of cause ... but BSDINSTALL is THE standard method to install files in most program packages besides rtems. This part of the patch fixes some minor protection setting problems, but doesn't support TARGET_VARIANTS NOTE: I hope you will like the BSDINSTALL, INST*FLAGS stuff. It is a step to get rid of "install-if-change" and to rely on a more standard installation procedure. If you don't like BSDINSTALL, removing it from the patch isn't difficult- just grep for BSDINSTALL and replace BSDINSTALL with INSTALL or MKDIR. FINALLY: I still have another patch pending (well, not a complete patch yet, it's a partial patch to demonstrate the principle), which adds automatic rebuilding of files generated by autoconf/configure. At the moment I don't dare to submit it, because integrating this patch would require to modify all Makefile.ins because we'd need to add a new "include " line to each Makefile.in.
* This set of changes is the build of what was required to convert toJoel Sherrill1997-04-011-0/+37
