* wrapup/Makefile.am: Use MKDIR_P instead of mkdir_p.
* Makefile.am: Remove shared/main.c.
* libchip/Makefile.am: Correct path to README.tulipclone.
* shmsupp/getcfg.c: Comment out npu (Unused).
* smc/smc.c: include bspIo.h for printk.
* libchip/ide/ata.c: Remove superfluous type casts.
* include/rtems++/rtemsMessageQueue.h, src/rtemsMessageQueue.cc: Make
compile by using size_t and uint32_t where appropriate.
* vmeUniverse/vmeUniverse.c: Use size_t for sizes.
* libchip/ide/ata.c, libchip/network/elnk.c, optman/rtems/no-msg.c:
* vmeUniverse/README.porting, vmeUniverse/README.universe:
updated, added more information for BSP implementors.
* vmeUniverse/VMEDMA.h (added): VME DMA API definition.
* vmeUniverse/bspVmeDmaList.h (added), vmeUniverse/bspVmeDmaListP.h (added),
* vmeUniverse/bspVmeDmaList.c (added):
Driver-independent code for linked-list DMA (public + private headers,
implementation).
* vmeUniverse/vmeUniverseDMA.h (added), vmeUniverse/vmeTsi148DMA.h (added):
interface to new DMA features of drivers.
* vmeUniverse/vme_amd_defs.h: Added definition for data-width
hint bits (VME_MODE_DBWxx).
* vmeUniverse/vmeTsi148.c: added DMA support. Added support for
data-width hint/modifier bits.
* vmeUniverse/vmeUniverse.c, vmeUniverse/vmeUniverse.h:
Added support for data-width hint/modifier bits.
Added support for xxx_BLT, xxx_MBLT address modifiers.
Restrict DBW to 32 in non-MBLT modes (except single-beat;
a comment is in README.universe). Updated DMA support to
implement new VMEDMA.h API. Added support for non-incrementing
VME addresses. Restrict data width to 32 for single-beat AMs
when the universe would use MBLT for DMA.
* shared/vme/VMEConfig.h:
Added more comments about the semantics of the various
symbols BSPs should define in this file.
Removed declarations of BSP_VMEInit(), BSP_VMEIrqMgrInstall().
* shared/vme/vmeconfig.c: declare BSP_VMEInit(),
BSP_VMEIrqMgrInstall() here.
* Makefile.am, shared/vme/README,
* shared/vme/vme_universe_dma.c (added): Added glue code
implementing the VMEDMA.h API using the vmeUniverse driver.
* Makefile.am, preinstall.am,
* vme/vmeconfig.c (removed), vme/VMEConfig.h (added):
cleaned up vme support - use files from libbsp/powerpc/shared/vme
and define BSP specifica in VMEConfig.h.
Use VME DMA support implemented by vmeUniverse and
libbsp/powerpc/shared/vme/vme_universe_dma.c
* irq/irq.c, include/gen2.h:
removed _BSP_vme_bridge_irq variable and BSP_PIC_DO_EOI definition.
Support for VME IRQ software priorities was incomplete/incorrect
on this BSP.
* Makefile.am, preinstall.am, include/bsp.h,
* vme/vmeconfig.c (removed), vme/VME.h (removed):
* Makefile.am, preinstall.am, include/bsp.h:
Added explanation for use of BSP_PIC_DO_EOI by
BSP implementors who derive from this 'include/bsp.h'.
* Makefile.am:
added new files in shared/vmeUniverse to EXTRA_DIST
* GT64260/MVME5500I2C.c: Eliminate u32.
* GT64260/MVME5500I2C.c, pci/pci.c: Eliminate unchar.
* console/fb_vga.c: Eliminate __u16, __u32.
* Makefile.am: Use MKDIR_P instead of mkdir_p.
* bootloader/Makefile.am: Use MKDIR_P instead of mkdir_p.
fixed synchronization bug between ata.c and bdbuf.c
* mvme5500/vme/VMEConfig.h, mvme5500/vme/VME.h,
* mvme5500/vme/vmeconfig.c:
removed copies of vmeconfig.c, VME.h - use generic
versions instead.
* ep1a/Makefile.am, ep1a/preinstall.am,
* motorola_powerpc/Makefile.am, motorola_powerpc/preinstall.am,
* score603e/Makefile.am, score603e/preinstall.am,
* shared/vme/VME.h:
moved VME.h from libbsp/powerpc/shared/vme to
libbsp/shared/vmeUniverse; eventually, this (and other)
VME API headers should migrate to cpukit.
* Makefile.am:
* vmeUniverse/vmeTsi148.c, vmeUniverse/vmeTsi148.h,
* vmeUniverse/vmeUniverse.c, vmeUniverse/vmeUniverse.h,
* vmeUniverse/vme_am_defs.h:
Added SLAC/Stanford Authorship Note / Copyright + Liability Disclaimer.
* libchip/i2c/i2c-2b-eeprom.c, libchip/i2c/i2c-2b-eeprom.h,
* libchip/i2c/i2c-ds1621.c, libchip/i2c/i2c-ds1621.h:
* mpc6xx/mmu/pte121.h, mpc6xx/mmu/pte121.c:
* ep1a/vme/vmeconfig.c, mvme5500/pci/pcifinddevice.c,
* mvme5500/startup/pgtbl_activate.c, mvme5500/vectors/bspException.h,
* mvme5500/vectors/exceptionhandler.c, mvme5500/vme/VME.h,
* mvme5500/vme/vmeconfig.c, score603e/vme/vmeconfig.c, shared/pci/pcifinddevice.c,
* shared/startup/pgtbl_activate.c, shared/startup/pgtbl_setup.c,
* shared/startup/probeMemEnd.c, shared/startup/sbrk.c, shared/vme/VME.h,
* shared/vme/VMEConfig.h, shared/vme/vme_universe.c, shared/vme/vmeconfig.c:
* Makefile.am: Use preinstall.am.
* smc/smc.c: Comment out sm_status (unused).
* bestcomm/load_task.c: Remove bogus casts.
* network/GT64260eth.c: Use ioctl_command_t as arg to ioctl functions.
* network/if_hdlcsubr.h: Remove K'n'R macros.
* network/network.c: Use ioctl_command_t as arg to ioctl functions.
* network/network.c: Use ioctl_command_t as arg in ioctl-functions.
* network/ne2000.c: Use ioctl_command_t as arg in ioctl-functions.
* 3c509/3c509.c, ne2000/ne2000.c, wd8003/wd8003.c: Use
* network/network.c (uti596_ioctl): Use ioctl_command_t.
