path: root/c/src (follow)
* Ensure that when -msoft-float is specified for multilib builds, thatJoel Sherrill2000-06-121-1/+2
| | | | | something indicates this. Eventually this needs to be merged into gcc.
* Works on Solaris and Linux.Joel Sherrill2000-06-121-8/+6
* Removed references to printk as part of moving it to a more shareableJoel Sherrill2000-06-126-171/+6
| | | | location in libc.
* Added printk as a generic, shared routine.Joel Sherrill2000-06-127-3/+367
* New file. This is a simple termios console driver which is sufficientJoel Sherrill2000-06-121-0/+148
| | | | to do polled IO on a single port with VERY little support code.
* Added i960sim BSP which (ignoring the 3 instructions not supportedJoel Sherrill2000-06-1218-0/+641
| | | | by gdb 5.0's i960 simulator) is enough to run hello world.
* Merge lossage. Apparently the DOS/UNIX CRLF issue got lost.Joel Sherrill2000-06-121-1438/+1438
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121429-10219/+81741
* New file.Joel Sherrill2000-05-241-0/+0
* New file added on 4.5 branchJoel Sherrill2000-05-082-0/+0
* New file added on 4.5 branchJoel Sherrill2000-05-081-0/+0
* Added on 4.5 branch.Joel Sherrill2000-05-034-0/+0
* Added on 4.5-branchJoel Sherrill2000-05-018-0/+0
* New files.Joel Sherrill2000-04-294-0/+8
* New files added as part of librpc upgrade.Joel Sherrill2000-04-2928-0/+0
* New files added as part of librpc upgrade.Joel Sherrill2000-04-29156-0/+0
* New directory added as part of librpc upgrade.Joel Sherrill2000-04-2946-0/+0
* New files added on 4.5 branch.Joel Sherrill2000-04-284-0/+0
* New file.Joel Sherrill2000-04-131-0/+367
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-13346-0/+1244
| | | | adds .cvsignore.
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-13435-0/+1488
| | | | adds .cvsignore.
* Removed.Joel Sherrill2000-04-071-18/+0
* New file. Copied from i386ex BSP as missing from submission.Joel Sherrill2000-04-051-0/+18
* New files from John Cotton <John.Cotton@nrc.ca> and Charles-AntoineJoel Sherrill2000-04-053-0/+3223
| | | | | | | | | | | | | | | | | | | | | Gauthier <charles.gauthier@nrc.ca>. The power supply in their VMEbus cage died so it was submitted at this point. It passes ttcp which is a really good sign but they would like to do more testing and cleanup once their hardware is functional again. Please contact them if you are interested in using or fixing this driver. As their comments indicate, the performance is actually quite good even at this point as indicated by the ttcp results. Please note that this is by no means a final version. The code is still fairly ugly, and will require some further fixing. On the bright side, what is attached works. I finally ran the test programs successfully with optimized code and data cache enabled: netdemos worked, but failed on the UDP transfer (runs out of buffers). ttcp worked, with something like 1036 KB/sec Rx, 952 KB/sec Tx. tftp worked
* New file from Ralf Corsepius <corsepiu@faw.uni-ulm.de> as part ofJoel Sherrill2000-04-031-0/+56
| | | | | rtems-rc-4.5.0-7.diff. This file is being added to the main branch in hopes that it will be easier to deal with the full merge later.
* Added routines to get and set C3x IOF register. The code is conditionallyJoel Sherrill2000-03-011-13/+71
| | | | compiled and there is no comparable code for the C4x.
* BSP now compiles and links with CAVSL board information. This includesJoel Sherrill2000-02-294-10/+5
| | | | | | | | | | linkcmds updated, simio references removed, and switch to libchip for serial ports from simio. Added a MEMORY_MAP file to capture information about the various addresses on this board. In addition, many of the beta patches are now included.
* Fixed typo.Joel Sherrill2000-02-281-1/+1
* New port of RTEMS to TI C3x and C4x.Joel Sherrill2000-02-221-0/+44
* New port of RTEMS to TI C3x and C4x.Joel Sherrill2000-02-2247-0/+5488
* Increased block size to 128 and added comments based on feedback fromJoel Sherrill2000-02-113-3/+39
| | | | Java folks including Oscar Martinez de la Torre <omt@wm.estec.esa.nl>.
* Patch from Eric Norum <eric@cls.usask.ca> based on working withJoel Sherrill2000-02-113-1/+45
| | | | | | | | | | | | | | | | | | | | Bob Wisdon <bobwis@ascweb.co.uk> and Chris Johns <ccj@acm.org> to resolve a random network lockup problem. ckinit.c: Occasional network lockups have been noted when the PIT has a higher interrupt request level than the CPM. The SCC1 bit in the CISR is set even though the SCC1 interrupt handler is not active. This blocks interrupts from SCC1 (and all other CPM sources) and locks up the system. It has not been determined whether the error is within the 68360 or in the RTEMS interrupt support assembler code. The solution, for now, is to set both PIT and CPM interrupt request levels to the same value (4). network.c: Set CPM transmitter buffer pointer (_tbptr) to beginning of frame before restarting transmitter. Don't retire transmitter buffer descriptors belonging to the restarted frame.
* Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-08130-441/+354
* Fixed typo.Joel Sherrill2000-02-081-1/+1
* Patch from Eric Norum <eric@cls.usask.ca> to remove race conditionsJoel Sherrill2000-02-081-3/+9
| | | | when setting up receive buffer descriptors and when unmasking interrupts.
* Incorrect error status returned. Noted by Andrew KlossnerJoel Sherrill2000-02-041-1/+1
| | | | <andrew@pogo.wv.tek.com>.
* Changed behavior to match that expected by EPICS test code. Reported byJoel Sherrill2000-02-031-2/+1
| | | | Eric Norum <eric@cls.usask.ca>.
* Patches rtems-rc-20000118-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-0348-804/+1301
| | | | | | | | | | | | | | | | | that contains the automake files for libnetworking plus a couple of minor fixes. [Now only one unused/unsupported Makefile.in remains (./c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in).] To apply: patch -p1 < rtems-rc-20000118-7.diff /bin/sh rtems-rc-20000118-7.rm /bin/sh rtems-rc-20000118-7.add ./bootstrap Notes: * I have tested this one by building all BSPs for m68k, powerpc, sh and unix with toolchains built since last weekend. * I did not touch libnetworking's directory layout.
* Fixed spelling errors.Joel Sherrill2000-02-031-2/+2
* Patch rtems-rc-20000118-6.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-021-4/+3
| | | | | | | | | | | | | | | | that contains: The workarounds related to the issues with ppc/helas403 (triggers a nasty bug in automake-2.14) and mcp750.cfg (Which is basically broken) To apply: patch -p1 < rtems-rc-20000118-6.diff ./bootstrap Note: * Though this patch is small, ./bootstrap is absolutely necessary. * Now your CVS source tree is identical to my local CVS.
* Patches rtems-rc-20000118-5.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-0110-269/+113
| | | | | | | | | | | | | | | | | | | | | | | | | that contains: * The fix for the gen68360/network/Makefile.am * automatically set permissions to 755 to scripts/buildall and scripts-ada/buildall (I remembered a trick to achieve this :). * automake support for libbsp/* and libcpu/* (Attn: This part will finally break old-style configuration for all non-public cpus) NOTES: * This patch has only been tested for a random selection of BSPs (I haven't rebuilt all toolchains yet). * This patch is against rtem-cvs as of this morning (MET). To apply: patch -p1 <rtems-rc-20000118-5.diff cvs rm -f ./c/src/lib/libbsp/Makefile.in cvs rm -f ./c/src/lib/libbsp/shmdr/Makefile.in cvs rm -f ./c/src/lib/libcpu/Makefile.in cvs add ./c/src/lib/libbsp/Makefile.am cvs add ./c/src/lib/libbsp/shmdr/Makefile.am cvs add ./c/src/lib/libcpu/Makefile.am ./bootstrap
* Removed references to non-existent include files.Joel Sherrill2000-01-311-1/+1
* Spelling corrected.Joel Sherrill2000-01-311-1/+1
* Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff fromJoel Sherrill2000-01-31572-14860/+8322
| | | | | | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de> that contain: * Modifications, (minor) corrections, cleanups to most existing Makefile.ams * Adds automake support to all remaining BSPs which have not yet been converted to automake. * Makefile.am for all remaining wrapup/Makefile.ams
* Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-31139-140/+0
| | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams).
* Ralf Corsepius <corsepiu@faw.uni-ulm.de> caught some files in CVSJoel Sherrill2000-01-311-1/+0
| | | | that should not have been.
* Patch rtems-rc-20000118-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-3141-162/+19
| | | | | | | | | | | | | | that contains: * cleanups to configuration files * A reworked gccnewlib.spec.in: I have reformated it for enhanced readability and added more rtems-base packages. It now should be free of any installation conflicts (If there still remain some, they should be regarded as bugs). * A fix to the bin2boot RTEMS_BSP issue (make RTEMS_BSP="pc386 pc486" now works). * removes libbsp/bare/wrapup * Further cleanups
* Modification to properly support BSP aliases (pc[456]86).Joel Sherrill2000-01-311-4/+4
