path: root/c/src (follow)
* Added on 4.5-branchJoel Sherrill2000-05-018-0/+0
* New files.Joel Sherrill2000-04-294-0/+8
* New files added as part of librpc upgrade.Joel Sherrill2000-04-2928-0/+0
* New files added as part of librpc upgrade.Joel Sherrill2000-04-29156-0/+0
* New directory added as part of librpc upgrade.Joel Sherrill2000-04-2946-0/+0
* New files added on 4.5 branch.Joel Sherrill2000-04-284-0/+0
* New file.Joel Sherrill2000-04-131-0/+367
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-13346-0/+1244
| | | | adds .cvsignore.
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-13435-0/+1488
| | | | adds .cvsignore.
* Removed.Joel Sherrill2000-04-071-18/+0
* New file. Copied from i386ex BSP as missing from submission.Joel Sherrill2000-04-051-0/+18
* New files from John Cotton <John.Cotton@nrc.ca> and Charles-AntoineJoel Sherrill2000-04-053-0/+3223
| | | | | | | | | | | | | | | | | | | | | Gauthier <charles.gauthier@nrc.ca>. The power supply in their VMEbus cage died so it was submitted at this point. It passes ttcp which is a really good sign but they would like to do more testing and cleanup once their hardware is functional again. Please contact them if you are interested in using or fixing this driver. As their comments indicate, the performance is actually quite good even at this point as indicated by the ttcp results. Please note that this is by no means a final version. The code is still fairly ugly, and will require some further fixing. On the bright side, what is attached works. I finally ran the test programs successfully with optimized code and data cache enabled: netdemos worked, but failed on the UDP transfer (runs out of buffers). ttcp worked, with something like 1036 KB/sec Rx, 952 KB/sec Tx. tftp worked
* New file from Ralf Corsepius <corsepiu@faw.uni-ulm.de> as part ofJoel Sherrill2000-04-031-0/+56
| | | | | rtems-rc-4.5.0-7.diff. This file is being added to the main branch in hopes that it will be easier to deal with the full merge later.
* Added routines to get and set C3x IOF register. The code is conditionallyJoel Sherrill2000-03-011-13/+71
| | | | compiled and there is no comparable code for the C4x.
* BSP now compiles and links with CAVSL board information. This includesJoel Sherrill2000-02-294-10/+5
| | | | | | | | | | linkcmds updated, simio references removed, and switch to libchip for serial ports from simio. Added a MEMORY_MAP file to capture information about the various addresses on this board. In addition, many of the beta patches are now included.
* Fixed typo.Joel Sherrill2000-02-281-1/+1
* New port of RTEMS to TI C3x and C4x.Joel Sherrill2000-02-221-0/+44
* New port of RTEMS to TI C3x and C4x.Joel Sherrill2000-02-2247-0/+5488
* Increased block size to 128 and added comments based on feedback fromJoel Sherrill2000-02-113-3/+39
| | | | Java folks including Oscar Martinez de la Torre <omt@wm.estec.esa.nl>.
* Patch from Eric Norum <eric@cls.usask.ca> based on working withJoel Sherrill2000-02-113-1/+45
| | | | | | | | | | | | | | | | | | | | Bob Wisdon <bobwis@ascweb.co.uk> and Chris Johns <ccj@acm.org> to resolve a random network lockup problem. ckinit.c: Occasional network lockups have been noted when the PIT has a higher interrupt request level than the CPM. The SCC1 bit in the CISR is set even though the SCC1 interrupt handler is not active. This blocks interrupts from SCC1 (and all other CPM sources) and locks up the system. It has not been determined whether the error is within the 68360 or in the RTEMS interrupt support assembler code. The solution, for now, is to set both PIT and CPM interrupt request levels to the same value (4). network.c: Set CPM transmitter buffer pointer (_tbptr) to beginning of frame before restarting transmitter. Don't retire transmitter buffer descriptors belonging to the restarted frame.
* Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-08130-441/+354
* Fixed typo.Joel Sherrill2000-02-081-1/+1
* Patch from Eric Norum <eric@cls.usask.ca> to remove race conditionsJoel Sherrill2000-02-081-3/+9
| | | | when setting up receive buffer descriptors and when unmasking interrupts.
* Incorrect error status returned. Noted by Andrew KlossnerJoel Sherrill2000-02-041-1/+1
| | | | <andrew@pogo.wv.tek.com>.
* Changed behavior to match that expected by EPICS test code. Reported byJoel Sherrill2000-02-031-2/+1
| | | | Eric Norum <eric@cls.usask.ca>.
* Patches rtems-rc-20000118-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-0348-804/+1301
| | | | | | | | | | | | | | | | | that contains the automake files for libnetworking plus a couple of minor fixes. [Now only one unused/unsupported Makefile.in remains (./c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in).] To apply: patch -p1 < rtems-rc-20000118-7.diff /bin/sh rtems-rc-20000118-7.rm /bin/sh rtems-rc-20000118-7.add ./bootstrap Notes: * I have tested this one by building all BSPs for m68k, powerpc, sh and unix with toolchains built since last weekend. * I did not touch libnetworking's directory layout.
* Fixed spelling errors.Joel Sherrill2000-02-031-2/+2
* Patch rtems-rc-20000118-6.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-021-4/+3
| | | | | | | | | | | | | | | | that contains: The workarounds related to the issues with ppc/helas403 (triggers a nasty bug in automake-2.14) and mcp750.cfg (Which is basically broken) To apply: patch -p1 < rtems-rc-20000118-6.diff ./bootstrap Note: * Though this patch is small, ./bootstrap is absolutely necessary. * Now your CVS source tree is identical to my local CVS.
* Patches rtems-rc-20000118-5.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-0110-269/+113
| | | | | | | | | | | | | | | | | | | | | | | | | that contains: * The fix for the gen68360/network/Makefile.am * automatically set permissions to 755 to scripts/buildall and scripts-ada/buildall (I remembered a trick to achieve this :). * automake support for libbsp/* and libcpu/* (Attn: This part will finally break old-style configuration for all non-public cpus) NOTES: * This patch has only been tested for a random selection of BSPs (I haven't rebuilt all toolchains yet). * This patch is against rtem-cvs as of this morning (MET). To apply: patch -p1 <rtems-rc-20000118-5.diff cvs rm -f ./c/src/lib/libbsp/Makefile.in cvs rm -f ./c/src/lib/libbsp/shmdr/Makefile.in cvs rm -f ./c/src/lib/libcpu/Makefile.in cvs add ./c/src/lib/libbsp/Makefile.am cvs add ./c/src/lib/libbsp/shmdr/Makefile.am cvs add ./c/src/lib/libcpu/Makefile.am ./bootstrap
* Removed references to non-existent include files.Joel Sherrill2000-01-311-1/+1
* Spelling corrected.Joel Sherrill2000-01-311-1/+1
* Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff fromJoel Sherrill2000-01-31572-14860/+8322
| | | | | | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de> that contain: * Modifications, (minor) corrections, cleanups to most existing Makefile.ams * Adds automake support to all remaining BSPs which have not yet been converted to automake. * Makefile.am for all remaining wrapup/Makefile.ams
* Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-31139-140/+0
| | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams).
* Ralf Corsepius <corsepiu@faw.uni-ulm.de> caught some files in CVSJoel Sherrill2000-01-311-1/+0
| | | | that should not have been.
* Patch rtems-rc-20000118-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-3141-162/+19
| | | | | | | | | | | | | | that contains: * cleanups to configuration files * A reworked gccnewlib.spec.in: I have reformated it for enhanced readability and added more rtems-base packages. It now should be free of any installation conflicts (If there still remain some, they should be regarded as bugs). * A fix to the bin2boot RTEMS_BSP issue (make RTEMS_BSP="pc386 pc486" now works). * removes libbsp/bare/wrapup * Further cleanups
* Modification to properly support BSP aliases (pc[456]86).Joel Sherrill2000-01-311-4/+4
* Suggested modification from Rosimildo da Silva <rdasilva@connecttel.com>Joel Sherrill2000-01-311-9/+10
| | | | to make the BSP boot on netboot.
* Added AC_SUBST(RTEMS_BSP) so the makefiles properly honor theJoel Sherrill2000-01-311-0/+1
| | | | BSP alias on the tools.
* BSP now links although this change is untested.Joel Sherrill2000-01-311-3/+7
* Patch from John M. Mills <jmills@tga.com> to include moreJoel Sherrill2000-01-281-0/+6
| | | | information on hardware settings.
* Added after report from Quality Quorum <qqi@world.std.com> thatJoel Sherrill2000-01-271-0/+5
| | | | pc686.cfg was not present.
* No longer incorrectly references mips.Joel Sherrill2000-01-263-22/+8
* Patch rtems-rc-20000118-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-2622-331/+823
| | | | | | | | | | | | | | | | | | | | that converts the a29k to automake. This patch contains * An initial merger of the libcpu/a29k stuff you sent yesterday. AFAIS, most code inside them seems to be empty stubs. One file even contains a function called mips_*** which might indicate that this part might contain mips code or the code the initial porter used as template for porting. Unfortunately, I don't know anything about the a29k so I can't comment on the details. * A dummy bsp_specs to libbsp/29k/portsw * An update to the automake files related to the a29k. Note: * This patch is completely untested, because I don't have a toolchain for it. * The files in libcpu/a29k include bsp.h => The libbsp vs. libcpu-issue hits again.
* Directive rtems_task_variable_get() added by Eric Norum.Joel Sherrill2000-01-233-1/+86
* Wrong BSP referenced.Joel Sherrill2000-01-232-2/+2
* Removing unused file accidentally left in CVS. Discovered byJoel Sherrill2000-01-233-269/+0
* Patch from Eric Norum <eric@cls.usask.ca> at the request of JakeJoel Sherrill2000-01-212-66/+112
| | | | | | | Janovetz <janovetz@tempest.ece.uiuc.edu> to return a status from network initialization rather than panic'ing. It changes a bunch of rtems_panics to printfs and returns a status from rtems_bsdnet_initialize_network().
* Patch from Eric Norum <eric@cls.usask.ca> to implement this:Joel Sherrill2000-01-216-21/+25
| | | | | | | | | | | | | | | | | | | | I'd like to propose a change to RTEMS task variables that I think would make them more useful. I think that it is early enough in their existence to still make changes to their API. 1) Change type from `int' to `void *'. 2) Add extra argument to task_variable_add -- if non-NULL, a pointer to a `destructor' function to be called when the task exits. This function would be called with that task's value of the task variable as its argument. In many cases, the `dtor' function could be `free'. rtems_status_code rtems_task_variable_add ( rtems_id tid, void **ptr, void (*dtor)(void *)); rtems_status_code rtems_task_variable_delete (rtems_id tid, void **ptr); This would be all we'd need to cleanly and efficiently support C++ per-thread exception information without dragging in all that POSIX API stuff.
