* | Fixed some weird line duplications. Thanks to Chris Johns. | Joel Sherrill | 1997-10-06 | 1 | -18/+9 |
* | Increased interrupt stack space. | Joel Sherrill | 1997-10-06 | 1 | -1/+1 |
* | Fixed comment. | Joel Sherrill | 1997-10-06 | 2 | -2/+2 |
* | Make Post an atomic operation. | Joel Sherrill | 1997-10-06 | 4 | -4/+24 |
* | Added _Thread_Enable_dispatch to already_timedout path on Wait_support. | Joel Sherrill | 1997-10-06 | 1 | -2/+3 |
* | If the specified time period is less than a clock tick, then | Joel Sherrill | 1997-10-05 | 1 | -1/+4 |
| | | | | it is arbitrarily assumed to be 1 clock tick. | ||||
* | fixed typo | Joel Sherrill | 1997-09-30 | 1 | -1/+1 |
* | Fixed typos. | Joel Sherrill | 1997-09-30 | 1 | -1/+1 |
* | Uncommented gettimeofday_r to resolve missing symbol. | Joel Sherrill | 1997-09-21 | 2 | -4/+0 |
* | Cleaned up as part of adding the Monitor test. | Joel Sherrill | 1997-09-21 | 36 | -56/+44 |
* | Added Monitor test. | Joel Sherrill | 1997-09-21 | 4 | -1/+192 |
* | Bug fix from Eric Norum: | Joel Sherrill | 1997-09-19 | 2 | -2/+0 |
| | | | | | | | | | | | After weeks of trying to figure why my RTEMS/KASQ server crashes now and then I found a nasty bug I introduced in adding multiple-driver support to libio. The bug only affects `add-on' driver classes (like the networking code). Old-style file descriptors were not affected. The bug cleared 32 bytes of memory (unspecified location) whenever a `close' of a socket was performed! I was clearing an IOP I hadn't allocated -- and the pointer wasn't initiallized, either! | ||||
* | Merged changes from Eric Norum: | Joel Sherrill | 1997-09-18 | 3 | -16/+32 |
| | | | | | | | | | | | | | Enable 68360 watchdog. The watchdog control register is a `write-once' register, so the watchdog has to be enabled in the boot roms if it is to be used at all. To make the change transparent I added a default feed of the watchdog to the clock interrupt handler. This can be overridden if the application wants to handle the watchdog. The only difficulty with this change is that an application has to either include the clock driver or handle the watchdog explicitely. I don't think this is much of a problem since I am pretty sure that almost every application includes the clock driver. | ||||
* | updated | Joel Sherrill | 1997-09-16 | 2 | -8/+22 |
* | syslog added | Joel Sherrill | 1997-09-15 | 1 | -1/+2 |
* | eliminated potential for overfilling buffer on read | Joel Sherrill | 1997-09-15 | 19 | -19/+0 |
* | Fix from Eric Norum. Here is the comment: | Joel Sherrill | 1997-09-03 | 1 | -2/+2 |
| | | | | | | Enable SDMA operation during FREEZE. It seems that disabling SDMA during freeze makes the SMC channels work erratically. | ||||
* | Fixed IO Manager calls to remove an argument which was used in 3.2.1 | Joel Sherrill | 1997-08-28 | 2 | -64/+9 |
| | | | | but not in newer RTEMS. | ||||
* | Switched to new style which does not require hackspecs.awk. | Joel Sherrill | 1997-08-28 | 20 | -580/+260 |
* | Added RTEMS_IO_ERROR status code. | Joel Sherrill | 1997-08-28 | 4 | -2/+6 |
* | Added IO_Error status code and fixed No_Memory error number. | Joel Sherrill | 1997-08-28 | 1 | -3/+5 |
* | Corrected reference to LIBC_LIBM to work on all targets. | Joel Sherrill | 1997-08-27 | 1 | -1/+1 |
* | Added error numbers and changed default error code from 0 to -1 for | Joel Sherrill | 1997-08-27 | 2 | -14/+18 |
| | | | | error number mapping. | ||||
* | Modified to support the BSP family concept. | Joel Sherrill | 1997-08-27 | 11 | -21/+21 |
* | Modified to have correct address for vector table on multiple models. | Joel Sherrill | 1997-08-27 | 2 | -0/+10 |
* | Patches from Chris Johns to clean up test. | Joel Sherrill | 1997-08-26 | 5 | -19/+52 |
* | removed -lm | Joel Sherrill | 1997-08-26 | 1 | -1/+1 |
* | Corrected to compile with egcs. | Joel Sherrill | 1997-08-26 | 2 | -5/+5 |
* | Corrected bug per Katsutoshi Shibuya's report: | Joel Sherrill | 1997-08-22 | 1 | -2/+2 |
| | | | | | | | The definition of "BEGIN_DATA" should not be null; should be ".data". Also, the definition of "BEGIN_BSS" should be ".bss". For this error, the compiled object has codes that write on the text segment area. It is fatal when the code runs on ROM. | ||||
* | Removed assert condition when not initialized or there are 0 periods. | Joel Sherrill | 1997-08-22 | 2 | -0/+10 |
* | Moved reentrant wrappers into their own file. | Joel Sherrill | 1997-08-22 | 5 | -9/+96 |
* | Fixed iop/memory leak bug reported by Dan Dickey. | Joel Sherrill | 1997-08-22 | 2 | -2/+12 |
* | Removed redundant stanza. | Joel Sherrill | 1997-08-22 | 1 | -2/+0 |
* | Fixed infinite recursion bug in PTHREAD_MUTEX_INITIALIZER. | Joel Sherrill | 1997-08-22 | 1 | -10/+15 |
* | Added commit about missing support for condition initializer. | Joel Sherrill | 1997-08-22 | 2 | -0/+2 |
* | start no longer a global symbol per Eric Norum's request. | Joel Sherrill | 1997-08-22 | 2 | -2/+12 |
| | | | | | | | | | | Also, I ran across a nasty problem the first time I tried downloading and running an application compiled with the new snapshot. To make a very long story short, the `start' in ...../m68k/gen6860/start360/start360.s must not be global. The change is simple -- just remove the .globl start from start360.s. | ||||
* | Switched to new version of mc68681.h | Joel Sherrill | 1997-08-04 | 1 | -29/+29 |
* | moved mc68230.h from main include directory to motorola | Joel Sherrill | 1997-08-04 | 1 | -1/+1 |
* | new implementation of mc68681.h | Joel Sherrill | 1997-08-04 | 2 | -144/+582 |
* | Fixed type | Joel Sherrill | 1997-08-04 | 1 | -1/+1 |
* | Corrected typo | Joel Sherrill | 1997-08-04 | 9 | -9/+9 |
* | Corrected descent to a hardcoded directory and made it dependent on the cpu ↵ | Joel Sherrill | 1997-08-04 | 1 | -1/+1 |
| | | | | model | ||||
* | Fixed typo and removed duplicated code | Joel Sherrill | 1997-08-04 | 1 | -4/+1 |
* | First attempt at values for PPC | Joel Sherrill | 1997-08-04 | 3 | -0/+9 |
* | Trying to support all models | Joel Sherrill | 1997-08-04 | 1 | -20/+4 |
* | Trying to support all models. | Joel Sherrill | 1997-08-04 | 1 | -0/+6 |
* | consolex built for all models. | Joel Sherrill | 1997-08-04 | 1 | -8/+4 |
* | moved header files into the motorola and zilog subdirectories | Joel Sherrill | 1997-08-04 | 8 | -9/+8 |
* | Correcting difference between mvme162lx and mvme162. All versions have | Joel Sherrill | 1997-08-04 | 1 | -0/+5 |
| | | | | four serial ports. | ||||
* | moved header files into the motorola and zilog subdirectories | Joel Sherrill | 1997-08-04 | 4 | -5/+7 |
