* src/powerpc/new_exception_processing/remdeb.h: Regenerated.
* Fixed bug where resetting a timer that was not at the head
of one of the task timer chains resulted in the Timer Server
task waking up too far in the future.
* Added rtems_timer_get_information() directive to support testing.
* sp31/init.c, sp31/system.h, sp31/task1.c: Modified to test for
above condition.
* include/rtems/score/watchdog.h: Added WATCHDOG_MAXIMUM_INTERVAL.
* src/timerserver.c, include/rtems/rtems/timer.h,
* src/timergetinfo.c: New file.
* src/Makefile.am: Modified to reflect above.
* rtems/Makefile.am: Removed.
AC_CONFIG_SRCDIR(asm.h).
* Makefile.am: Merge in rtems/Makefile.am and
rtems/score/Makefile.am. Remove gensize. Require automake-1.5.
* rtems/score/.cvsignore: Add unixsize.h*. Add stamp-h*.
* configure.ac: Add AM_CONFIG_HEADER(rtems/score/unixsize.h).
* rtems/score/cpu.h: Replace CPU_CONTEXT_SIZE_IN_BYTES with
SIZEOF_CPU_CONTEXT.
* sp09/screen14.c, sp09/sp09.scn, sp30/init.c, sp31/init.c: Modified
because priority added as argument to rtems_timer_initiate_server().
* include/rtems/rtems/timer.h, src/timerserver.c: Add priority
* rtems/Makefile.am: New.
* rtems/.cvsignore: New.
* rtems/score/Makefile.am: New.
* rtems/score/.cvsignore: New.
* rtems/score/ppc.h: Relocated from shared/.
* rtems/score/ppctypes.h: Relocated from shared/.
* asm.h: Relocated from shared/.
* shared/Makefile.am: Removed.
* shared/asm.h: Removed.
* shared/ppc.h: Removed.
* shared/ppctypes.h: Removed.
* shared/.cvsignore: Removed.
* rtems_telnetd/pty.c: Move config.h to were it belongs.
Remove printf (Reported by Till Straumann
<strauman@SLAC.Stanford.EDU>).
* compilers/gcc-target-default.cfg: Add missing \.
Reported by Ilya Alexeev <ilya@continuum.ru>.
* include/rtems/system.h: Fix typo in yesterday's change:
RTEMS_MULTILIBS.
* include/rtems/system.h: Only include cpuopts.h when building a
multilib configuration. Some ports still need targopts.h but this
small modification lets those ports work non-multilib while
fixing being fixed for multilib.
* src/powerpc/excep_f.c: This patch addresses the following issues:
- exception handler needs to enable MSR_FP if the interrupted
thread is FP enabled.
- printk message for MSR fixed and added stacktrace
NOTE: this requires the stacktrace patch to
lib/libbsp/powerpc/shared/vectors/vector_init.c
(#ifdef DDEBUG only, however)
* src/powerpc/new_exception_processing/remdeb_svc.c: Corrected
macro using variable arguments.
* src/powerpc/new_exception_processing/remdeb.h,
src/powerpc/new_exception_processing/remdeb_xdr.c: Regenerated since
I updated the main RTEMS development machine to RedHat 7.2 and
apparently got a new version of rpcgen.
* ChangeLog: Deleted duplicate blank line.
* include/rtems/libio.h: Add #include <rtems/fs.h>.
Reflect changes due to using rtems/fs.h.
* include/rtems/libio_.h: Reworked.
* Added task-based timers to the Timer Manager. This added three
new directives:
- rtems_timer_initiate_server
- rtems_timer_server_fire_after
- rtems_timer_server_fire_when
In the process of doing this, a number of cleanups were made.
* src/timerserver.c, src/timerserverfireafter.c,
src/timerserverfirewhen.c: New files.
* include/timer/timer.h: Added new prototypes and supporting types.
* inline/rtems/rtems/timer.h, macros/rtems/rtems/timer.h: Enhanced
_Timer_Is_interval_class() to cover the class TIMER_INTERVAL_ON_TASK.
* src/Makefile.am: Accounted for new files.
* src/rtemstimer.c: Added initialization of _Timer_Server variable.
* src/timercancel.c, src/timerreset.c: Account for addition
of timer classes. Also corrected the headers.
* src/timercreate.c, src/timerdelete.c, src/timerfireafter.c,
src/timerfireafter.c, src/timerident.c: Corrected header.
* Makefile.am: Apply @subdirs. Remove POSIX_SUBDIRS. Remove
ITRON_SUBDIRS.
* configure.ac: Rework enable_unixlib handling.
Add RTEMS_MULTILIBS to cpuopts.h.
* include/Makefile.am: Add rtems/fs.h, rtems/userenv.h.
Add $(PROJECT_INCLUDE)/rtems. Remove libio_.h.
* asm.h: Remove #include <rtems/score/targopts.h>.
Add #include <rtems/score/cpuopts.h>.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP(RTEMS_BSP).
* src/getegid.c: Add #include <rtems/userenv.h>.
Remove #include <rtems/libio_.h>.
* src/geteuid.c: Ditto.
* src/getgid.c: Ditto.
* src/getlogin.c: Ditto.
* src/getuid.c: Ditto.
* lib/tftpDriver.clib/tftpDriver.c: Fix TFTP block number checking.
* vector/vector.S, irq/irq_asm.S: Make sure vectors work properly
in RAM and Flash based code. The code executed for the Flash
version runs in both cases (code in Flash/code in RAM) but as it
is less efficient than the one optimized for RAM, it put it inside
ifdef. A compilation error is generated if code is linked in Flash
with the correct ifdef set...
* irq/irq.c: Correct minor bug in mbx8xx interrupt handling.
Quoting Eric, "In theory it should be applied in each mpc8xx
related BSP but as I cannot test it plase maintainer/users
submit patch accordingly."
* Added tests for task-based timers. This included the new tests
sp30 and sp31.
* Makefile.am, configure.ac: Modified to reflect new tests and files.
* sp09/screen14.c, sp09/sp09.scn: Modified to add error checks
for task-based timer services.
* sp30/.cvsignore, sp30/Makefile.am, sp30/init.c, sp30/resume.c,
sp30/sp30.doc, sp30/sp30.scn, sp30/system.h, sp30/task1.c,
sp31/.cvsignore, sp31/Makefile.am, sp31/delay.c, sp31/init.c,
sp31/prtime.c, sp31/sp31.doc, sp31/sp31.scn, sp31/system.h,
sp31/task1.c: New files.
new directives:
* src/taskmode.c: Ensure the this service does not dispatch before
tasking is enabled at initialization time.
* inline/rtems/posix/mutex.inl (_POSIX_Mutex_Get_support): Corrected
name of routine in header.
* configure.ac: Remove RTEMS_OUTPUT_BUILD_SUBDIRS.
* rootfs/Makefile.am: Use include_rtems_HEADERS instead of H_FILES.
* src/imfs/imfs_load_tar.c: Add include <sys/types.h>.
Add include <sys/stat.h>. Add include <fcntl.h>.
* src/imfs/imfs_rmnod.c: Add include <stdlib.h>.
* libc/gxx_wrappers.c: Add #include <rtems/error.h>.
* include/Makefile.am: Remove EXTRA_DIST.
* configure.ac: Add RTEMS_CHECK_NETWORKING.
* wrapup/Makefile.am: Add install-hook.
Remove SIZE_RTEMS.
* include/rtems/fs.h: New, extracted from libio_.h.
* include/rtems/userenv.h: New. extracted from libio_.h.
* rtems/score/cpu.h: #include <rtems/bspIo.h>.
* optman/, optman/.cvsignore, optman/Makefile.am, optman/no-dpmem.c,
optman/no-event.c, optman/no-mp.c, optman/no-msg.c, optman/no-part.c,
optman/no-region.c, optman/no-rtmon.c, optman/no-sem.c,
optman/no-signal.c, optman/no-timer.c: Removed entire contents of
optman/ directory since it has been moved.
* optman/, optman/.cvsignore, optman/Makefile.am, optman/no-ext.c,
optman/no-io.c: Removed entire contents of optman/ directory since
it has been moved.
* optman/, optman/.cvsignore, optman/Makefile.am: Removed entire
contents of optman/ directory since it has been moved.
* .cvsignore: Added aclocal.m4 and configure.
* .cvsignore: New file.
* Makefile.am: Readded reference to wrapup.
* wrapup/.cvsignore: Readded.
* include/.cvsignore: New file.
* libc/Makefile.am: Add MULTISUBDIR support.
* libc/fcntl.c: Add #include <stdarg.h>.
* libc/privateenv.c: Add #include <stdlib.h>.
* bsp.am: Add line break, remove comment.
* configure.ac: Remove NETWORKING support.
* wrapup/Makefile.am: Remove NETWORKING support.
