* | Added ka9q tcpip stack and network driver for the gen68360. This effort | Joel Sherrill | 1997-04-09 | 35 | -132/+1020 |
| | | | | | | | | | | | | | was done based on the 3.6.0 release and had to be autoconf'ed locally. It is turned on is the bsp enables it and it is not explicitly disabled via the configure option --disable-tcpip. As many warnings as possible were removed locally after the code was merged. Only the gen68360 and mvme136 bsps were compiled this way. The ka9q port and network driver were submitted by Eric Norum (eric@skatter.USask.Ca). The network demo programs are not included in the tree at this point. | ||||
* | added cast to eliminate warning. | Joel Sherrill | 1997-04-08 | 1 | -1/+1 |
* | corrected printf specifications and added casts as necessary to eliminate | Joel Sherrill | 1997-04-07 | 7 | -72/+79 |
| | | | | warnings. | ||||
* | added ifdef to avoid warning for unused variable. | Joel Sherrill | 1997-04-07 | 1 | -2/+6 |
* | corrected integer only definitions of "FP CHECK" routines to eliminate | Joel Sherrill | 1997-04-07 | 1 | -3/+10 |
| | | | | warnings. | ||||
* | changed signed int to unsigned int to eliminate a warning. | Joel Sherrill | 1997-04-07 | 2 | -2/+2 |
* | removed noreturn attribute to eliminate warnings. | Joel Sherrill | 1997-04-07 | 5 | -10/+35 |
* | commented out sccs_id's to eliminate warnings. | Joel Sherrill | 1997-04-07 | 4 | -12/+28 |
* | added prototype and return statement to eliminate warnings. | Joel Sherrill | 1997-04-07 | 1 | -0/+4 |
| | | | | main.c: added return statement to eliminate a warning. | ||||
* | removed reference to no_bsp. | Joel Sherrill | 1997-04-07 | 2 | -8/+20 |
| | | | | added prototypes. | ||||
* | commented out sccs_id to eliminate warnings | Joel Sherrill | 1997-04-07 | 2 | -8/+20 |
* | added or fixed includes of page_table.h to eliminate warnings. | Joel Sherrill | 1997-04-07 | 3 | -2/+5 |
* | added cast to eliminate warning | Joel Sherrill | 1997-04-07 | 3 | -4/+5 |
* | added prototype for delay. | Joel Sherrill | 1997-04-07 | 1 | -0/+1 |
* | added global statement for start entry point | Joel Sherrill | 1997-04-07 | 2 | -0/+2 |
* | removed noreturn from prototype to avoid warnings. | Joel Sherrill | 1997-04-07 | 6 | -6/+55 |
* | added cast to eliminate warning. | Joel Sherrill | 1997-04-07 | 1 | -1/+1 |
* | added return statement to avoid warning. | Joel Sherrill | 1997-04-07 | 1 | -0/+2 |
* | added initialization of variable to eliminate warning. | Joel Sherrill | 1997-04-07 | 2 | -2/+2 |
* | added include of unistd.h to eliminate warning for no prototype for write(). | Joel Sherrill | 1997-04-07 | 1 | -0/+1 |
* | added ifdef around variables to eliminate warnings when cross | Joel Sherrill | 1997-04-07 | 1 | -0/+2 |
* | added "ifndef" to avoid redefinition warning. | Joel Sherrill | 1997-04-07 | 2 | -0/+4 |
* | added volatile to Switch_necessary structure member to avoid warning. | Joel Sherrill | 1997-04-07 | 1 | -2/+2 |
* | added test to avoid spurious error | Joel Sherrill | 1997-04-07 | 1 | -1/+1 |
* | added prototype for missing routine. | Joel Sherrill | 1997-04-07 | 1 | -0/+4 |
* | added "return" to eliminate warning. | Joel Sherrill | 1997-04-07 | 1 | -0/+2 |
* | added "ifndef" to avoid redefinition warning | Joel Sherrill | 1997-04-07 | 5 | -0/+10 |
* | added prototypes for two assembly language routines to eliminate warnings. | Joel Sherrill | 1997-04-07 | 1 | -0/+9 |
* | commented out sccs_id to eliminate warning. | Joel Sherrill | 1997-04-07 | 4 | -12/+26 |
* | added plea for someone to implement software stack switching for m68000-ish | Joel Sherrill | 1997-04-07 | 1 | -0/+3 |
| | | | | cores. | ||||
* | Replaced warning message for cpus which do not have hardware support | Joel Sherrill | 1997-04-07 | 1 | -2/+3 |
| | | | | | for an interrupt stack. Hopefully this will encourage someone to implement software stack switching on the m68k. | ||||
* | initialized variable to eliminate warning | Joel Sherrill | 1997-04-07 | 1 | -1/+3 |
* | changed signed int to unsigned to eliminate warning | Joel Sherrill | 1997-04-07 | 1 | -1/+1 |
* | added "ifndef" for ASM to avoid redefinition warnings. | Joel Sherrill | 1997-04-07 | 1 | -0/+2 |
* | corrected one of the references to an environment variable which | Joel Sherrill | 1997-04-02 | 1 | -1/+1 |
| | | | | is no longer used since autoconf is in place. | ||||
* | corrected printf format to avoid warning | Joel Sherrill | 1997-04-02 | 7 | -11/+11 |
* | initialized variables or removed unused variables to remove warnings | Joel Sherrill | 1997-04-02 | 3 | -4/+3 |
* | was checking for null cpu_table -- short have been checking configuration | Joel Sherrill | 1997-04-02 | 1 | -1/+1 |
| | | | | table. | ||||
* | This set of changes is the build of what was required to convert to | Joel Sherrill | 1997-04-01 | 431 | -227/+22053 |
| | | | | | | | | | | | | | | | | | | | | GNU autoconf. This is the first large step in allowing an RTEMS user to perform a one-tree build (per crossgcc FAQ) including RTEMS in the build process. With this change RTEMS is configured in built in the same style as the GNU tools, yet retains the basic structure of its traditional Makefiles (ala Tony Bennett). Jiri Gaisler (jgais@wd.estec.esa.nl) deserves (and received) a big thank you for doing this. There are still issues to be resolved but as of this commit, all target which can be built on a linux host have been using a modified version of the source Jiri submitted. This source was merged and most targets built in the tree before this commit. There are some issues which remain to be resolved but they are primarily related to host OS dependencies, script issues, the use of gawk for hack_specs, and the dependence on gcc snapshots. These will be resolved. | ||||
* | Fixed symbols. | Joel Sherrill | 1997-03-21 | 1 | -2/+6 |
* | added decrementer entry. | Joel Sherrill | 1997-03-21 | 1 | -0/+17 |
* | Removed Fake input ifdef code. | Joel Sherrill | 1997-03-21 | 1 | -15/+0 |
* | Fixed timerisr symbol. | Joel Sherrill | 1997-03-21 | 1 | -2/+2 |
* | Rewrote to avoid references to C symbols from assembly. This entirely | Joel Sherrill | 1997-03-21 | 1 | -5/+9 |
| | | | | circumvents the problem of leading underscores. | ||||
* | Fixes incorrect reference to start symbol. | Joel Sherrill | 1997-03-21 | 1 | -1/+1 |
* | updates from John Gwynne | Joel Sherrill | 1997-03-11 | 2 | -0/+358 |
* | updates from John Gwynne | Joel Sherrill | 1997-03-11 | 21 | -92/+778 |
* | modified _Chain_Insert_unprotected to have the form required to be used | Joel Sherrill | 1997-03-11 | 2 | -4/+4 |
| | | | | as the sole statement in an if or else statement | ||||
* | swapped increment of _ISR_Nest_level and _Thread_Dispatch_disable_level | Joel Sherrill | 1997-03-11 | 1 | -1/+1 |
