path: root/c/src (follow)
* 2008-09-08 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-09-081-0/+4
| | | | * ChangeLog: New file.
* 2008-09-08 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-09-082-31/+137
| | | | | * mcf548x/include/Freescale_license.txt: Convert to UNIX CR/LF style, eliminate characters with 8th bit set.
* Derive time base clicks from bus frequencyThomas Doerfler2008-09-081-1/+1
* added new bsp for tqm8xxThomas Doerfler2008-09-081-0/+4
* some mpc8xx maintenanceThomas Doerfler2008-09-081-0/+7
* maintenanceThomas Doerfler2008-09-082-2/+1
* added new BSP for TQM8xx boardsThomas Doerfler2008-09-0826-0/+7160
* added support for flexible PLL in MPC866 and friendsThomas Doerfler2008-09-081-4/+38
* corrected parameters for done signallingThomas Doerfler2008-09-082-7/+7
* corrected parameters inside i2c driver for done signallingThomas Doerfler2008-09-084-17/+28
* corrected parameters in i2c driver for done signallingThomas Doerfler2008-09-087-30/+59
| | | | updated mscan CAN driver
* 2008-09-08 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-081-0/+4
| | | | * mcf548x/include/mcf548x.h: Convert to Unix file format.
* Convert to Unix file format.Ralf Corsepius2008-09-082-4109/+4109
| | | | * libchip/ide/ata.h: Convert to Unix file format.
* 2008-09-07 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-071-0/+4
| | | | * shared/comm/i386-stub.c: Include stdbool.h.
* Include stdbool.h.Ralf Corsepius2008-09-071-0/+1
* 2008-09-07 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-071-0/+5
| | | | | | | | * libchip/serial/mc68681.c, libchip/serial/mc68681_p.h, libchip/serial/ns16550.c, libchip/serial/ns16550_p.h, libchip/serial/serial.h, libchip/serial/serprobe.c, libchip/serial/sersupp.h, libchip/serial/z85c30.c: Convert to "bool".
* Convert to "bool".Ralf Corsepius2008-09-0724-80/+80
* 2008-09-07 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-071-0/+2
| | | | | * libchip/i2c/spi-flash-m25p40.c, libchip/i2c/spi-fram-fm25l256.c, libchip/i2c/spi-memdrv.h: Convert to "bool".
* 2008-09-07 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-071-0/+3
| | | | | | * libchip/rtc/ds1375-rtc.h, libchip/rtc/ds1375.c, libchip/rtc/mc146818a.c, libchip/rtc/mc146818a.h, libchip/rtc/rtc.h, libchip/rtc/rtcprobe.c: Convert to "bool".
| | | | | * libchip/ide/ata.c, libchip/ide/ata_internal.h, libchip/ide/ide_ctrl_cfg.h: Convert to "bool".
| | | | | * libchip/display/disp_hcms29xx.c, libchip/display/disp_hcms29xx.h: Convert to "bool".
| | | | | * libchip/network/if_fxp.c, libchip/network/if_fxpvar.h: Convert to "bool".
| | | | | * libchip/shmdr/fatal.c, libchip/shmdr/shm_driver.h: Convert to "bool".
* Convert to "bool".Ralf Corsepius2008-09-072-3/+3
* 2008-09-06 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-061-0/+10
| | | | | | | | | | * mpc5xx/irq/irq.c, mpc83xx/spi/mpc83xx_spidrv.c, new-exceptions/cpu.c, new-exceptions/raw_exception.h, new-exceptions/bspsupport/ppc_exc_hdl.c, ppc403/clock/clock.c, ppc403/clock/clock_4xx.c, ppc403/console/console.c, ppc403/console/console.c.polled, ppc403/console/console405.c, ppc403/tty_drv/tty_drv.c: Convert to "bool".
* Convert to "bool".Ralf Corsepius2008-09-0635-123/+121
* 2008-09-06 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-061-0/+5
| | | | | * interrupt/interrupt.h, serial/spi.h, serial/twi.h, serial/uart.h: Convert to "bool".
* Minor "bool" fixes.Ralf Corsepius2008-09-061-1/+1
* 2008-09-06 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-061-0/+4
| | | | * irq/irq.c: Minor "bool" fixes.
* 2008-09-06 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-061-0/+4
| | | | * startup/m68k-stub.c: Convert to "bool".
| | | | * shared/gdbstub/m68k-stub.c: Convert to "bool".
* changesRalf Corsepius2008-09-061-0/+4
| | | | * irq/irq.c: Convert to "bool".
| | | | * startup/bspstart.c: Convert to "bool".
| | | | * console/console.h: Convert to "bool".
* 2008-09-06 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-061-2/+2
| | | | * console/config.c, console/console.h: Convert to "bool".
| | | | * irq/irq.c, startup/bspstart.c: Convert to bool.
* Convert to bool.Ralf Corsepius2008-09-062-5/+5
| | | | | * bestcomm/bestcomm_glue.c, ide/pcmcia_ide.c, tod/todcfg.c: Convert to "bool".
| | | | | * ide/pcmcia_ide.c, irq/irq.c, startup/bspstart.c, startup/bspstart.c.nocache: Convert to "bool".
| | | | * misc/interr.c: Convert to "bool".
| | | | * tod/todcfg.c: Convert to "bool".
| | | | * ide/ide.c: Convert to "bool".
| | | | * spi/mc68360_spidrv.c: Convert to "bool".
| | | | * shared/comm/i386-stub.c, shared/irq/irq.c: Misc. "bool" changes.
* Misc. "bool" changes.Ralf Corsepius2008-09-062-3/+3
* Convert to Unix file format.Ralf Corsepius2008-09-061-316/+316
* 2008-09-05 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-09-054-106/+8
| | | | | | | | * sh7032/clock/ckinit.c, sh7045/clock/ckinit.c, sh7750/clock/ckinit.c: The Shared Memory Driver no longer requires the special IOCTL in Clock_control. This was a hack which has existed since before the Classic API Timer Manager was implemented. All implementations of and references to Clock_control were removed.
