* | 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-14 | 2 | -6/+5 |
| | | | | | * aclocal/canonicalize-tools.m4: Don't check for NM, OBJCOPY, SIZE, STRIP. | ||||
* | 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-14 | 2 | -0/+5 |
| | | | | * bsp.am: DISTCLEANFILES = include/bspopts.h. | ||||
* | 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-14 | 4 | -6/+14 |
| | | | | * Makefile.am: Reflect changes to bsp.am. | ||||
* | 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-14 | 5 | -2/+14 |
* | 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-14 | 92 | -55/+250 |
* | 2004-02-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-13 | 11 | -144/+56 |
| | | | | | | | | | | | * librdbg/include/Makefile.am: Merge-in librdbg/include/rdbg/i386/Makefile.am, librdbg/include/rdbg/m68k/Makefile.am, librdbg/include/rdbg/Makefile.am, librdbg/include/rdbg/powerpc/Makefile.am. * librdbg/include/rdbg/i386/Makefile.am, librdbg/include/rdbg/m68k/Makefile.am, librdbg/include/rdbg/Makefile.am, librdbg/include/rdbg/powerpc/Makefile.am: Remove. * configure.ac: Reflect changes above. | ||||
* | 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-12 | 2 | -4/+8 |
| | | | | * configure.ac: Use AS_HELP_STRING(ada). | ||||
* | 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-12 | 5 | -11/+32 |
| | | | | | | | | * aclocal/bspopts.m4: Use AS_HELP_STRING. * aclocal/bsp-configure.m4: Require autoconf-2.59. Use AC_CONFIG_HEADERS. * aclocal/check-custom-bsp.m4: Add bspkit-support. * aclocal/enable-rtemsbsp.m4: Use AS_HELP_STRING. | ||||
* | 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-12 | 26 | -26/+78 |
| | | | | * acinclude.m4: Regenerate. | ||||
* | 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-12 | 26 | -13/+65 |
| | | | | * configure.ac: RTEMS_CHECK_BSPDIR([$RTEMS_BSP_FAMILY]). | ||||
* | 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-12 | 2 | -0/+5 |
| | | | | * Makefile.am: include local.am. | ||||
* | 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-12 | 2 | -1/+5 |
| | | | | * aclocal/version.m4: 4.6.99.0. | ||||
* | 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-12 | 3 | -30/+8 |
| | | | | | * Makefile.am: Don't include host.am. * automake/compile.am: Further cleanups. | ||||
* | .cvsignore: Remove (Unused). | Ralf Corsepius | 2004-02-12 | 27 | -54/+0 |
* | Fixup .cvsignore | Ralf Corsepius | 2004-02-12 | 1 | -2/+0 |
* | 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-12 | 2 | -16/+4 |
| | | | | * automake/lib.am: Remove (Unused). | ||||
| | | | | * Makefile.am: Cosmetics. | ||||
* | 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-12 | 3 | -92/+25 |
| | | | | | * wrapup/Makefile.am: Don't include lib.am. * automake/compile.am: Use automake compilation rules. | ||||
* | 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-12 | 84 | -44/+212 |
| | | | | * Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE. | ||||
| | | | | * Makefile.am: Add start*.bin to CLEANFILES. | ||||
* | 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-12 | 2 | -1/+4 |
| | | | | * Makefile.am: Remove startup/linkcmds. | ||||
| | | | | * Makefile.am: Don't include lib.am. | ||||
* | 2004-02-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-10 | 2 | -200/+5 |
| | | | | | PR 575/bsps * startup/linkcmds: Remove. | ||||
* | 2004-02-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-09 | 7 | -6/+8 |
| | | | | | | | | * libnetworking/pppd/Makefile.am, libnetworking/rtems_servers/Makefile.am, libnetworking/rtems_telnetd/Makefile.am, libnetworking/rtems_webserver/Makefile.am, optman/Makefile.am, support/Makefile.am: Don't include lib.am. | ||||
* | 2004-02-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-09 | 5 | -13/+10 |
| | | | | | | | * libchip/Makefile.am: Don't include lib.am. * librdbg/src/i386/Makefile.am, librdbg/src/m68k/Makefile.am, librdbg/src/powerpc/Makefile.am: Don't include lib.am. Remove unnecessary EXTRA_DISTs. | ||||
* | 2004-02-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-09 | 4 | -3/+5 |
| | | | | | * Index: m68040/Makefile.am, mcf5206/Makefile.am, shared/Makefile.am: Don't include lib.am. | ||||
* | 2004-02-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-09 | 2 | -18/+24 |
| | | | | * wrapup/Makefile.am: Convert to automake-building rules. | ||||
* | 2004-02-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-09 | 2 | -1/+4 |
* | 2004-02-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-09 | 2 | -1/+5 |
| | | | | * Makefile.am: Add $(TMPINSTALL_FILES) to all-local. | ||||
* | 2004-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-02-08 | 2 | -1/+6 |
| | | | | * vectors/vectors.h: Force globalExceptHdl into bss section. | ||||
* | 2004-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-02-08 | 2 | -1/+14 |
| | | | | * Makefile.am: Add irq.h and vectors.h | ||||
* | 2004-02-06 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-02-06 | 2 | -6/+64 |
| | | | | | * Makefile.am: Split startup into multiple .rels without reorganizing the source. | ||||
* | 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-06 | 2 | -13/+22 |
* | 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-06 | 4 | -16/+31 |
* | 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-06 | 2 | -10/+17 |
* | 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-06 | 2 | -9/+19 |
* | 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-06 | 8 | -38/+75 |
* | 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-06 | 2 | -2/+18 |
| | | | | | * configure.ac: Add powerpc's <bsp>/wrapup/Makefile.am detection hack. | ||||
* | 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-06 | 6 | -5/+5 |
| | | | | | * mpc505/Makefile.am, mpc6xx/Makefile.am, mpc8260/Makefile.am, mpc8xx/Makefile.am, ppc403/Makefile.am: Don't include .../lib.am. | ||||
* | 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-06 | 4 | -2/+8 |
| | | | | * Makefile.am: Don't include .../lib.am. | ||||
* | 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-06 | 4 | -3/+5 |
| | | | | | * i960ca/Makefile.am, i960ka/Makefile.am, i960rp/Makefile.am: Don't include .../lib.am. | ||||
| | | | | | * sh7032/Makefile.am, sh7045/Makefile.am, sh7750/Makefile.am: Don't include .../lib.am. | ||||
* | 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-06 | 5 | -10/+6 |
| | | | | | | * mongoosev/Makefile.am, r46xx/Makefile.am, tx39/Makefile.am: Don't include .../lib.am. Remove ACLOCAL_AMFLAGS. * shared/Makefile.am: Don't include .../lib.am. | ||||
* | 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-06 | 4 | -6/+16 |
| | | | | | * Makefile.am: Pickup files from ../../sparc/shared instead of ../shared. Reformat. | ||||
* | 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-06 | 2 | -2/+7 |
| | | | | | * Makefile.am: Pickup files from ../../c4x/shared instead of ../shared. Reformat. | ||||
* | 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-06 | 6 | -8/+28 |
| | | | | | * Makefile.am: Pickup files from ../../arm/shared instead of ../shared. Reformat. | ||||
* | 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-06 | 6 | -3/+18 |
| | | | | | * Makefile.am: Pickup files from ../../sh/shared instead of ../shared. Reformat. | ||||
* | 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-06 | 4 | -10/+22 |
| | | | | | * Makefile.am: Pickup files from ../../i386/shared instead of ../shared. Reformat. | ||||
* | 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-06 | 28 | -34/+112 |
| | | | | | * Makefile.am: Pickup files from ../../m68k/shared instead of ../shared. Reformat. | ||||
* | 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-06 | 2 | -1/+5 |
| | | | | * Makefile.am: Pick up ../mvme167/network/network.c. |
